Old Apr 15, 2004, 07:39 PM
farmington, mn
Joined Sep 2003
i stripped the bolt in my gws retacts...now what?
ok i was just puting the finished touches on my formosa and i noticed that the little set screw in my blue gws retacts that hold on to the gear wire is stripped. i put these retacts in the wing with a HUGE amount of epoxy so they wouldn't come out on a hard landing so now i'm at a loss to figure out how to re-thread plastic. anyone have any ideas on that to do
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Apr 15, 2004, 07:42 PM
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
get a tap that is similar or same size (a new set screw if you can't find a tap that is the same), and put the set screw on another side of the gear holder?
Phreakish is offline Find More Posts by Phreakish
Old Apr 15, 2004, 07:49 PM
San Jose, CA
Joined Jun 2002
What a shame, this is just an idea that might work, at least it is worth a try. Pick up at your local car parts store, A Permatex "FORM-A-THREAD" set and not only fill in the threads but also inject some in the hole and reinstall the wire and the set screws. I am not positive but I see no reason for this not to work as I have used it to build new threads (on much larger parts) and if you follow the directions it will really be strong. Again I have not had to use it in this application but if I had to I would not hesitate to try it myself. Sure hope you can work this out and when you do how about posting a picture of the setup! GUD FLYING.......Dick
Dick is offline Find More Posts by Dick
got my slow stick .... now what. logan5 GWS (Grand Wing Servo) 10 Mar 25, 2008 11:37 AM
Out grown my Zagi 400 now what? Zagijim Foamies (Kits) 5 Dec 10, 2003 07:58 PM
bought a gws edf75 now what can I use it in? Cliff Smith Electric Ducted Fan Jet Talk 11 Oct 21, 2003 06:45 PM
Missing parts in my GWS kit thunderbyte Parkflyers 7 Jul 04, 2003 10:33 AM
Need a new battery pack for my GWS p51 and Zero What should I get? jayboy Parkflyers 3 Jan 03, 2003 02:12 PM
