Old Apr 14, 2004, 11:17 PM
falconpilot is offline
Find More Posts by falconpilot
Arkansas
Joined Apr 2004
Shock Flyer - ETEC's -2S, 2S2P, or 3S 1200?
One more time everyone..What kind of performs and weights and times can I expect running these different packs. Motor is AXI 2208/34(broke down and bought one- now I have both the 2208/34 and/26), CC Phoniex 25, Hitec 55's and hitec 6-Electron rx...All reply's greatly appreicated!!! Jim
falconpilot is offline Find More Posts by falconpilot
Old Apr 14, 2004, 11:45 PM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
In my experience the 34 does better with 3s packs. - also you would be hard pressed to get it over 10 amps with a lower pitched prop - so you could use a CC10 to save some weight.
Go to http://www.flyingmodels.org/motortest/Link_e.htm - look at the amp draws and thrust for the various props on 3s and 2s. That will give you a really good starting place.
LTChip is offline Find More Posts by LTChip
Old Apr 14, 2004, 11:53 PM
Arkansas
Joined Apr 2004
LTCHIP,
Thanks for the responce..I am currently flying the CC 10 at this time and may continue to use it....Jim
rob mueller is offline
Find More Posts by rob mueller
ok, maybe it is a toy
rob mueller's Avatar
Alberta, Canada
Joined Oct 2002
Hi falcon. Honest suggestion is the...
http://www.pfmdistribution.com/secur...om.asp?recid=5
...Apogee Lipoly 830 pack, in 3S1P configuration. Our Shocky's have less weight and 10.5 proven constant discharge.
rob mueller is offline Find More Posts by rob mueller
Nemesis Shock Flyer had it's maiden woody uk 3D Flying 1 Dec 18, 2005 06:41 PM
FS: Himax 4100, p10 micro, etec 3s 1200's foss1997 Aircraft - Electric - Airplanes (FS/W) 7 Mar 06, 2004 09:08 AM
2S or 3S Etec 1200 Napolean B. Batteries and Chargers 20 Jan 26, 2004 04:05 PM
WTB ETEC 2s or 3s 1200 packs mlehman Aircraft - Electric - Airplanes (FS/W) 7 Dec 06, 2003 10:58 PM
Is 2s2p = 2(2s)p or 2(2p)s? HankF Batteries and Chargers 19 Jul 02, 2003 04:19 PM
