Detroit Willow Run, Michigan, United States
Joined Sep 2002
Graupner Piper Cub J-3 Conversion
Hobby Lobby has a Piper Cub J-3 that I would like to convert it to electric. http://www.hobby-lobby.com/pipercubj3.htm I know that E-Zone has an electric conversion with a Jeti 45-3 Brushless using 16 CP-2400 cells. This article was written in Feb of 2003. http://www.rcgroups.com/links/index.php?id=4066 My question is: With all the new technology, Thunder Power lipo’s and AXI outrunners, would there be a better setup for this Cub.
Graupner Cub Specs are as follows: Wingspan: 72” 690 sq. in. wing area Length: 40” Weight: Hobby-Lobby states that the flying weight for gas is 6.5 lbs. Radio: 4 channels: Ailerons, Elevator, Rudder, and Throttle This will be my first conversion so I could us all your recommendations. I have been flying for a couple of years now and have flown indoor and out. Parkflyers and Zagi’s. Thanks PDS |
Kirby |
I'm installing an AXI 4120/14 with a Phoenix 80 ESC and a 10 cell GP3300 pack. The Phoenix 80 is overkill because with a 14x10 prop the AXI on 10 cells should draw about 40 amps, giving me a little over 400 watts in. The finished model should weigh around 6 pounds. It should fly the model very well. Good luck with yours. Bill Sanford |
I was looking at the AXI 4120 14 with 16 cells. Propped for about 500 watts. After the search engine was running again, I was going to see if anyone had done a coversion using an endo setup. The AXI looks like it would be a very clean installation without a gearbox. I've had the GP GD600 and it is hit and miss. Tim |
Worcester, Massachussetts, United States
Joined Feb 2003
Hi all .....
I just recieved the new Hobby Lobby catalog # 43. and on page 38 they are showing the Graupner 72" Cub with an AXI 412014 outrunner, aluminum motor mount, Jeti Advance 40 Amp ESC, 2-6 CELL cp-2400SCR battery packs (in series I presume), a prop shaft adaptor and APC (?) 13 X 8E thin electric prop. It is to be noted that it comes complete with fuel tank ... so I'm sure it's the same nitro powered airplane that's been around a while, just shiped with the electric power goodies. As I recall, in the review that was done on E-Zone (Fitz Walker maybe??), getting the battery packs in was accomplished through the firewall bulkhead, which would mean taking the prop and cowl off after every flight. It would be nice to put a hatch under the fuse, but the Cub style "double wire" landing gear might complicate that. AUW is 7.3 lbs. Just for reference, my 7 cell 2600 MaH Sanyo packs are just about exactly 1 lb. each. OBTW, all the stuff, including a Hitec Flash 6 radio and a cheezy charger is $ 779.00 plus shipping. I checked their website a minute ago, and this combo is not yet listed there, but it's in the catalog that came in the mail today. Happy and SAFE flying, Russ
Lititz,PA U.S.A.
Joined Nov 2001
J-3 Cub
Hey guys,
I just completed a Blackhorse J-3 Cub,same exact model as the Graupner just a different label. I'am using an AXI 4120/14,Jeti Advanced 70 amp OPTO speed control,14 CP-2400 cells and a APC 13 by 6.5 prop. All up wight is 118ozs. and it flys very well. Climbs are excellent and to date (6 flights so far) have gotten 6 1/2 min. flights out of her with millamps to spare. For an ARF,I was very impressed with the quaility of the plane,great covering job too. As for the brushed geared motor systems,they would fly it but there is something to be said for not having to change brushes every three months or so. If you can afford it,go with the AXI,you won't be sorry. Besides,if your in this hobby for the long haul,you'll get your money back in the sheer fun of flying them. Geeee |
United States, IL, Chicago
Joined Dec 1996
Idle thoughts PDS
Ferrites work real well if you don't "wring them out" - keep within their limits and don't abuse them. Most decent brushless will run to their stated limits at least. Cubs don't need a lot of power - that one in my avatar is Sig's 1/5th scale kit. 84.5" span - which is 'scale;, the 81" BARF Cubs are merely "IMAA legal". It flies fine on 16 cells at 8lb 2oz, could probably drop to 14 cells, but don't have the time to mess with fixing what ain't broke. I get around 15 mins of Cub-ish flight on 3000 mA nimh. I charge its battery inside the Cub - access thanks to Sig's superb kit is through the scale cabin door and window. Are you happy either pulling a lipo out of the model to charge it, or charging it in place (do you fancy your model and motor going up in flames???) Cubs all fly great! If you want to be different without a lot of work, look up a yellow Cub and make up some "real" N numbers rather than the imaginary ones that come in the kit. Or look some more and find one of the J3's the USN bought early WW2 - basically yellow with military markings. Mine is a 'real' colour scheme, though I suspect it's not really a scale military scheme, rather it's how someone painted their Cub on restoration... Good luck with her Dereck |
Joined Feb 2003
Well .....
I found the page on the Hobby Lobby site with the "electrified" version of the Graupner slimer Cub. Either they just added it, or I wasn't looking hard enough the first time !? This will be my "winter project" with skis and floats. Link below: http://www.hobby-lobby.com/j3cub.htm Happy and SAFE flying, Russ
Were you able to get the battery pack inside of the fuse to get the CG balanced or did you have cut the firewall out and have the battery sticking out like how they had it on ezone? Let me know how you got that worked out. Better yet, photos would be nice if all possible. Aloha to all on RCGroups |
| Thread Tools | |
| Off Site NIB SDM Piper Cub J-3 RTF! | skid_68 | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 31, 2006 11:51 AM |
| Off Site SDM Piper Cub J-3 RTF NIB | skid_68 | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 17, 2006 06:26 PM |
| Yippee! Scale plan for a Piper Cub J-3 | SiPet | Scale Electric Planes | 6 | Oct 19, 2005 09:36 PM |
| FS: Sig Piper Cub J-3 | mpatzig | Aircraft - Fuel - Airplanes (FS/W) | 2 | Nov 21, 2003 04:35 PM |
| Graupner Piper Cub J-3 | Peter Young | Fuel Plane Talk | 6 | Aug 25, 2002 09:15 PM |
