Apr 13, 2004, 06:41 AM
Joined Jan 2002
Originally Posted by lynnpreston
Is it ok to connect multiple identical Li-po packs in parallel and charge them all at once ... For example, if I have four 2000 mah packs, normally I would have to charge each in turn at 2 amps. However, if I connected them all in parallel using a parallel connector, could I charge them all at once at up to 8 amps? ... I just wanted to see if anyone else is doing it. It would sure cut down on charge time.
I use a variable up to 20 amp, 30 volt regulated DC power supply to do that.
Nominally identical packs may not be, for a number of reasons, so I also check the initial amperage into each pack with a Sears clamp-on digital ammeter. In your case, it should be about 2 amps for each pack.
- RD
