Old Apr 13, 2004, 03:39 AM
Protocooler is offline
Find More Posts by Protocooler
sloping addict
Protocooler's Avatar
France
Joined Feb 2003
Upcoming new F5B motors (up 200A) from Electronic Models
Hi; for information:
under test from 2003 french champion (Michel Uzan) are 3 new high power motors upcoming from Electronic Model ( http://www.electronicmodel.com/ )
They do not feature on website yet.
They sound promising:
the FAI motor is even lighter by 35g than the Ariane W (carbon matrix) motor and consumes 16A less to turn a 17 * 18 under 18 cells at the same speed than the Airane W. It turns it at 170A (with a 17*18, not usual 16*16 or 16*17)
Specs communicated:
FAI version: kV 3300, 5.2:1, weight 250g, Prop RFM 17*18, consumption 100 to 200A. If new next rule is indeed 16 cells they might have to rewind it (?).
F5F (10 cells) version: kV 6300, 6.7:1, 230g, 100-200A
F5B-7 version: kV 6300, 5.2:1, 230g, 100-200A
No other info available yet... I don't know the RPMs the prop is really turning at. But it seems EM is catching up good with the very best.
I'd like to see that in flight !
...Proto
Protocooler is offline Find More Posts by Protocooler
Old Apr 13, 2004, 05:16 AM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
I use their Chronos 40 with Reisenauer 5:1 gearbox. Its currently in my Stork 2Pro E where it will pull vertically, although I dont, on 10xgp3300 and 18x12.
They don't match the gearbox to the motor as well as the Hackers, however the motor has better inbuilt cooling. Their outrunner also gives excellent performance in sports planes.
Right now, probably because of the gearbox cost, they haven't been price competitive with the Hackers, at least since the $US depreciated.
From the gearbox specs you are quoting it looks as if they are moving to the Maxon gearboxes. Historically they have had lower wind motors geared less highly.
davidleitch is offline Find More Posts by davidleitch
Old Apr 13, 2004, 05:21 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Originally Posted by davidleitch
They don't match the gearbox to the motor as well as the Hackers...
The new motors are quite different in looks. I'll posts pic's this evening...
WimH is offline Find More Posts by WimH
Old Apr 13, 2004, 11:35 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
Originally Posted by WimH
The new motors...
Here's the pic:
Old Apr 13, 2004, 12:01 PM
WimH is offline
WimH's Avatar
Joined Dec 2001
Originally Posted by Protocooler
the Ariane W (carbon matrix) motor ...
Proto
What motor is that??? How's your selfmade glider doing???
Old Apr 13, 2004, 01:31 PM
ClausT is offline
Find More Posts by ClausT
ClausT's Avatar
Skodsborg, Denmark
Joined Jan 2001
Like many other F5B specialities, you need to know what to ask for...
It is in the top of the pricelist here:
http://www.carbon-vertrieb.com/shop/...&categoryTop=3
This is what i have seen:
ClausT is offline Find More Posts by ClausT
Old Apr 13, 2004, 01:46 PM
WimH is offline
WimH's Avatar
Joined Dec 2001
Ah, the Ariane WM.... Looks a bit like the MEB (Bloch) they used to do:
or even more like the "carbonized" kontronik they used to have. I suppose this one is a rebuilt Kontronik FAI 18 then? They certainly are not throwing the specs around...
Old Apr 13, 2004, 02:23 PM
sayno2glo is offline
Find More Posts by sayno2glo
I plan to take over world
sayno2glo's Avatar
Helsinki, Finland
Joined Jul 2002
Is that melted and crashed or what?
/Antti
sayno2glo is offline Find More Posts by sayno2glo
Old Apr 13, 2004, 02:32 PM
ClausT is offline
ClausT's Avatar
Skodsborg, Denmark
Joined Jan 2001
The beauty is inside
Gearbox housing is integrated with the motorhousing, output pinion is cut directly in the motor shaft, the usual disc holding the three small gearwheels is weight reduced etc.
In 2002 the donor motor for the rebuild was a Hacker.
Old Apr 13, 2004, 02:39 PM
Sebastien is offline
Find More Posts by Sebastien
Brussels, Belgium
Joined Nov 2000
I don't think the blue EM motors are sold out... only 15 or 20 were built......
Sebastien is offline Find More Posts by Sebastien
Old Apr 13, 2004, 05:03 PM
sloping addict
France
Joined Feb 2003
Well, seems we are talking motors (more than) twice the price of a hacker B40 FAI !
Ariane-Carbon-Competition 6,7:1 is listed at 425 Euros... If EM sells at a reasonable cost and they hold same perf at lower amps and lower weight, they could have a real winner.
Wim, are you a beta tester for EM, or did they really start selling those motors ?
Is that a Robbe Planeta Power gearbox ? How many watts can it stand ?
My selmade glider has not moved much: business trip + hollydays trip + I made a 3D EPP parkflier in between... However I am ready to move on again:
- I have installed balsa inserts around wing screws areas
- I have re-cut some badly done wing joiners plywood supports and just sarted to glue them, then I will finalize wing servos installation in cores and cut the wing skins.
- I have found a working vacuum pump motor, just need to plug it (=> this week)
- I have some good carbon strips (20 mm wide) for wings reinforcements in the middle
=> I will try to skin the wings and rudder / elevator over next 2-3 weeks / Week ends.
One more week for linkages etc, then it shall be ready for a maiden (at last !). I see more and more winch launches and electro gliders, and days with bad wind orientation, and I have no plane that's good in such uses, so I am really motivated to finish that up first priority...
Old Apr 14, 2004, 02:25 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
I wish... 't was a photo Sebastien ( an EM dealer) got from Fabrice Noro (=EM) and forwarded to the Belgian "F5B crowd". In his post he seems to indicate that the first batch of these is already sold out, and obviously there's not much
chance of a second one?
The gearbox is an "EM" gearbox, looks like the Robbe planeta a bit, but is probably different inside. afaik Robbe planeta's only existed in 3.7 . Should be good for 2000-3000W short time I guess...
Discussion New brushless controllers SPIN from Jeti up to 200A Protocooler High Performance 3 Aug 26, 2006 02:15 AM
a great new kit from Laser Models! CrazyMike Fuel Plane Talk 7 Oct 30, 2002 07:47 AM
New Scale Spit from World Models kelvin Scale Kit/Scratch Built 29 Oct 28, 2002 05:12 PM
New design from Mountain Models CoClimber Parkflyers 29 Dec 11, 2001 11:42 PM
New F5B rules & motors rafaelABN Electric Sailplanes 16 May 11, 2001 02:34 AM
