Old Dec 28, 2001, 06:34 PM
epilot is online now
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Pager motor test results
Here are the results of my pager motor tests for your viewing pleasure:
Motor: Pager motor from BG Micro (USD 1.75)
Gear: 4:1 using module 0.25 gears from WES (USD 3.00)
Prop: U-80 (USD 1.00)
Total weight: 3 grams
Volts: 4.95
Amps: 0.30
Thrust (grams): 9.5
Volts: 3.75
Amps: 0.22
Thrust (grams): 5.5
Volts: 2.50
Amps: 0.15
Thrust (grams): 3.0
Conclusion: This is a very powerful little motor when used with 4 cells and the low current consumption would indicate that it is reasonably effiecient. Motor barely gets warm and I checked the brushes in one after an hour of running and they still loked fine. I have tried a larger gear ratio and larger props, but performance increase was not worth the extra effort IMHO. The motor likes to rev and does NOT like a heavy prop. Since the motor works best with 4 cells it can either be used with a DC-DC converter running from 1 cell or in multis running of 4 cells. A twin with 4x70mah NiMH should work well because current consumption is with the capabilities of the small NiMHs.
I hope you find this information useful.
Michael
epilot is online now Find More Posts by epilot
Old Dec 29, 2001, 05:33 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Michael,
yes, that is very useful. I believe that I can soon build a DC-DC-booster/ESC combination that is quite powerful and efficient (I'm fighting with the software at the moment). With that one would be very independent from a certain input voltage level to power the higher-voltage pager motors. Plus, the output is DC, so no problems with coreless motors.
Where do you get the U-80 props from? What all-up weight do you believe to lift with ~10g of thrust? 25g? Maybe 30g?
jberg is offline Find More Posts by jberg
Old Dec 29, 2001, 01:33 PM
epilot's Avatar
Joined Nov 2000
Hi Jochen
I'd like to hear more about your DC/DC converter.
I got my U-80 props from Free Flight supplies in the UK. I will be ordering some stuff from Flitehook soon and they also have U-80 props. I can send you their pricelist and you can put whatever you need on my order. I have some more pager motors on the way from the US and can spare a few if you are interested. I'm also waiting for some of the small GWS props to see how they compare to the U-80.
I memory serves me right the geared KP-00 in my 24 gram model produces app. 8-9 grams of thrust and this is adequate. In terms of power 1.5 to 2 watts is sufficient for 25 grams model weight.
Brgds
Michael
Old Dec 29, 2001, 02:49 PM
jberg is offline
jberg's Avatar
Joined Feb 2001
Michael,
my booster can pull up to 2A from any source, takes away 20-25% of power and puts the rest out at almost whatever voltage level you want. I designed it originally to supply a 1524 with 9-10V and 0.9A from two Tadiran cells as a power system for a "Tiny". That would be about the maximum power. All lower power and voltage levels are easier, of course, and will give better efficiency. Think of 5V/0.6A for a very long time to an N-20 from one of the Li-Polymer cells you know very well - you get it? (BTW, it's a real pity that the Tadirans are discontinued, their quite low inner resistance would have been a great advantage.) Weight will be at about 3g (booster and ESC). But - it does not yet work completely as I want it to. I'm working on it (job comes first ).
Think farther: a dual actuator driver made from one PIC soldered to the back end of a GWS R4P receiver, supplied by the same 5V that drive the N-20 or pager motor - the only missing thing here is *time* at the moment.
Dividing shipping costs from USA or whereever by two and adding 1,50 Euro for a "Päckchen" would be a great idea. I am strongly interested in the pricelist (you still have my email and snailmail address?).
New 12mm Motor Test Results MRI Medusa Research 137 Dec 12, 2005 10:16 PM
Micro Brushless Motor Test Results Gordon Johnson Scratchbuilt Indoor and Micro Models 46 Jul 11, 2005 11:12 AM
Motor Prop Test Results! tallflyer GWS (Grand Wing Servo) 0 May 07, 2004 11:52 AM
M-20 and N-20 Motor/Gearbox/Prop Test Results cybermike Scratchbuilt Indoor and Micro Models 27 Jul 30, 2003 12:03 PM
Motor Thrust test results paulaac Power Systems 0 Jan 25, 2002 02:45 AM
