Old Dec 28, 2001, 11:06 AM
YARDC is offline
Find More Posts by YARDC
Cincinnati, OH
Joined May 2000
F-15 intake question?
I'm designing a twin MF 480 and have a question regarding intake. I usually keep the intake around 90% of the FSA but I am confused with the F-15.
If I make a square intake @ 90% FSA (~1 11/16 X 2 3/4in ) then cut it at an angle to simulate the F-15 intake (when viewed from the side) the perimiter intake area is huge (9+sq/in each)?
Is this correct? Or do I need to fiqure the 90% FSA in the angled intake?
Also the ducts are very long .... consider this, would one recommend something other than 90% FSA for intake? More... less?
Thanks in advance and I'll get pics of the project up soon.
YARDC is offline Find More Posts by YARDC
Old Dec 28, 2001, 01:00 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Re: F-15 intake question?
Originally posted by YARDC
I'm designing a twin MF 480 and have a question regarding intake. I usually keep the intake around 90% of the FSA but I am confused with the F-15...
I ran into this dilemma while designing the Flanker. It's got the same sort of intake.
I decided that the oncoming air wouldn't see the angle of the intake, only the straight-on dimensions, so I designed it as if the inlet was square, not angled.
I couldn't say for sure, but if the intake is long-ish, then add 10% to the inlet size.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Dec 28, 2001, 01:15 PM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
Are there any good websites or threads that explain ducting, inlets, etc? I'm new to EDF, and any help would be appreciated. Thanks, Hans
flybike is offline Find More Posts by flybike
Old Dec 28, 2001, 01:24 PM
YARDC is offline
Cincinnati, OH
Joined May 2000
Thanks Dan ... this is what I thought. Going the other route (making them 90% FSA with angle) would make the inlets smaller than scale which didn't make sence to me.
Hans ... do a search on inlets or ducting on this site. There is a lot of good info out there. I just could'nt find much on square ducting with the angle.
Regards
Old Dec 29, 2001, 02:19 AM
GlasairAllen is offline
Find More Posts by GlasairAllen
I'll fly anything...
GlasairAllen's Avatar
United States, CA, Palm Springs
Joined Aug 2001
Re: Re: F-15 intake question?
Dan
Dan,
You are exactly correct... when measuring inlet area you do need to consider the cross section that the incoming air will see. You can get real technical and figure out the angle of attack the plane will fly at and figure that in, but usually the front view drawing of the plane is close enough.
GlasairAllen is offline Find More Posts by GlasairAllen
Question F-15 Parkjet Question? dhelms9138 Pusher Prop Jet Models 5 Feb 01, 2006 06:06 PM
Question Kress Jets F-15 ducting question stevebarrow Electric Ducted Fan Jet Talk 30 Jun 07, 2004 11:43 PM
Question on EJF F-15 jet_jer Electric Ducted Fan Jet Talk 31 Aug 01, 2003 05:32 AM
What ever happened to the F-15 and F-22 kits from EJF realdeal Electric Ducted Fan Jet Talk 1 Jul 09, 2001 07:06 PM
Nick Ziroli F-15 or others for twin project? realdeal Electric Ducted Fan Jet Talk 2 Jun 19, 2001 07:44 PM
