| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Leave me alone!
The Ultimate Slow Stick Help Thread - Part 4
It's time for a part 4
The others can be found here: Part 1: http://www.rcgroups.com/forums/showt...hreadid=122951 Part 2: http://www.rcgroups.com/forums/showt...15#post1502315 Part 3: http://www.rcgroups.com/forums/showp...61&postcount=1 Carry on ![]() Martin |
#2 |
Balsa!!!
Pulling it off? So easily? Isn't that quite weak?
I'd use epoxy instead. ALSO: how do you put the micro control horns into the control surfaces? Last edited by csisfun; Apr 11, 2004 at 12:40 PM. |
#3 | |
Been There! Done That!
BTW I have posted pics of the plastic slide ons and thrust mod on my website under Present Hanger. boomer www.boomerseflight.com |
#4 |
Location: Seattle/Tacoma Sea/Tac, Washington, United States
Bent Dihedral Brace
I got my buddy box late last week and got an opportunity to let the kids take my prized slow stick for a test fly over the weekend. It was kind of windy, but I have been having a lot of fun playing stringless kite so we went out to take a couple of trips around the back pasture.
The 9 year old did quite a bit of porpoiseing but finally was able to do a few figure eights up high, the 5 year old decided that the best and only thing the Slow Stick did was loop, one after the other…With some wind and the continuous looping I could see that there might be an issue, then the 19 year old asked me if it could only loop one direction, hmm, I don’t know, let’s find out. An outside loop later I decided it was time to bring it down and asses the damage. I pulled the wing braces off and took a picture to show the difference from stock angle to where it ended up, it also managed to crack the wing right in the center, but nothing a little epoxy could not fix. I now have a new set of brass braces and a little extra stranded packing tape along with a liberal dose of epoxy in the center of the wing. Brad Flying Money Pit |
#5 |
Off 2 The Edge of Reality
No actually, you guys are using hot glue all of the time. If you attach the GWS horn like normal I put a good drop where the two plastic joints meet. Not something I would want to have in the long run, but for a few test flights it holds just fine for a plane this light.
#6 |
Engine
I see some of the s/s with the motor mounted below the fuse and some above the fuse what difference does it make?
Jerico |
#7 | |
Allons, Randy |
#8 |
#9 |
Anyone seen Aeropenguin latley?
I need to order some of those brass dihedral braces. Had my first wing-fold incident. ![]() Anyone have much luck with repairing the wing and flight thereafter? Pretty much just cracked it down the center. Of course, lost a prop and motor! Nothing like having it happen about 45 ft in the air.. OUCH... |
#10 |
try this
Make from 1/32nd or 1/16th plywood as shown in the photo, smear 5 min epoxy on one side and hold in place till set. Color with red maker.
Allons, Randy |
#11 |
I like that!! How was the weight diff?
Have you ever had to do a wing repair after the folding? Trying to decide if it is worth fixing.. >shrugs< Still a Newbie. |
#12 |
Help for an eclectically challenged individual
Ok, time to get educated. I thought I kinda understood how all this electric stuff worked, and I mean kinda.. I wanted to support the LHS so I scooted on down there and picked myself up a Thunder Power 3S 1900 battery, I just love my TP 2S 1900 and thought it would be good to start getting ready for my brushless setup.
I am running the stock 300 with the D gearbox that it came with and figure I have a good 20 hours on the motor so it is probably getting close to end of life, why not speed things up with more voltage. Here I am, climbing like there is no tomorrow when the motor seems to sputter, hmm I think, then nothing, bubkiss, nada, I am chasing the darn thing on foot. “Landed” over at the neighbors, luckily their fence slowed it down A little tape on the horizontal stabilizer and it is back in business.The only thing I can figure out is I was pulling to many amps for my speed controller, it is the GWS300, rated at 8 normal 15 peak.. Anyone have any thoughts? My 7.4 volt has never caused any probs, but this 11.1 sure has. The other question is should I go Nipi, or something else for the brushless setup, and what size prop/gearbox if not a Nipi? Brad The Flying Money Pit |
#13 |
Renegade, the LHS can order a complete set of wings for this plane for $12. I saw every kind of damage that could be possible to these wings in he past 2 days, almost all of them were fixed with epoxy. I think the guys are just bending their own brass tubing for those wing braces rather than buying them premade. If this helps any as well, a lot of the guys had Himax 2025 motors in thier planes and stock gear box. I forget what prop they were using though.
I adjusted my control surfaces today, and now I have a much better sweep. I also topped off my LiPo pack for a flight tommorow. |
#14 | |
Never folded a wing so I never had one to repair, but , I'm sure this will work. If your wing is already broken yuo dont have a lot to loose. I wouldnt even bother replaceing the alum. joiner. Allons, Randy |
#15 |
hi Guys,
Does anyone know how to fasion a new front wing mount Saddle, The black plastic part that hold the front part of the wing to the fuse w/ rubber band. I broke mine into a million pieces when i did a power dive into the mud. and no one is carrying stock in the world! sigh... any help will be appreciated. Thanks Ken |
| Thread Tools | |
| The Ultimate Slow Stick Help Thread Part 7 | boomerace | Beginner Training Area (Aircraft-Electric) | 517 | Apr 27, 2005 01:04 PM |
| The Ultimate Slow Stick Help Thread - Part 6 | Ron H | Beginner Training Area (Aircraft-Electric) | 544 | Feb 16, 2005 10:59 AM |
| The Ultimate Slow Stick Help Thread - Part 5 | boomerace | Beginner Training Area (Aircraft-Electric) | 793 | Sep 13, 2004 09:01 AM |
| The Ultimate Slow Stick Help Thread - Part 3 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 639 | Apr 11, 2004 12:17 PM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 11:35 AM |
