Old Apr 10, 2004, 11:27 PM
Jinx is offline
Find More Posts by Jinx
Joined Mar 2004
Took the slow stick out today.. =(
Tried to fly my slow stick today after a week of perperation, the wind was really pissing me off, it would NOT stop.. i dont really know how fast it was blowing, but it was gushing every 10 to 15 seconds enough to move the stick while it was on the ground, almost flip it over.. i guess it really has to be dead calm to fly these things? I didnt realize that and tried to take it up twice.. first time it came down 2 seconds or less after take off crashed nose first.. and chip off about a 1/2 an inch from the farthest corner of the backside of the wing.. i dont think it will hurt it trying to fly since its such a small peice.. mistakenly tried to put superglue on it when i remembered, HEY doesnt super glue EAT styrophome?! so now i'm going to have to use elmers glue to fill in the missing styrophome now.. SIGH!
Also i had a hell of a time with the servo's.. before my first attempt at flight, when i got out to the field all of a sudden the rudder and elevator were totally off!! it looked as tho i was pushing up and right on my controll stick they were so bad! they were fine looking in the car before i walked them out there.. i couldn't figure out what was the deal.. so i took of the wing, adjusted the micro dubro conncetors and slide the rods down a bit.. there back to straight again.. First flight.. CRASH they were OFF AGAIN had to take off the wing adjust them again.. tried a second flight.. crash (not as bad as the first flight) OFF AGAIN!! repeat steps..
I decided to give up after 2 crashse only 5 feet off the ground becuase the wind was turning the plane and just about flipping it over.. i couldn't controll it, it was like someone was shaking your plane and your trying to stabalize it.. very very very frustrating to say the least...
Are my servo's stripped? is that whats going on? I cant figure out why it kept being off.. when i turned on the Tx and looked at the servo's they were in the CORRECT positions (arms lined up to where they should be) just that the flaps where way off! (allways in the same direction too).. my only thought is i didnt screw on the durbo connectors hard enough? but i dont see how hard i'd have to go, i practactly bend the rods as i'm turning the screws with as much leverage as i can get on those things..
another fun thing.. since i decided to screw in my stabliziers onto the aluminum frame.. those screws dont like to stay in there probably becuase i couldn't get a 1mm bit and i had to use a little.. this is more of a rant.. WHY do they make the screws 1mm when they dont make a damn 1mm bit? I must have called 4 hardware stores and 3 hobby stores.. I knew the hardware stores wouldn't have them but i had to try cuz all the hobby stores would say was "we have one just BARELY smaller and JUST barely bigger but we dont carry 1mm" almost like they dont make it.. I just dont understand why companies have to use SPECIALIZED parts when one size either way would have been just fine and alot more readily available.. that makes this whole thing alot more frustrating then it needs to be.. If i had got the stick up, i would have had no controll becuase my elevator was about to fall off..
I dont know if anyone else has had as frustrating of a time as I have with the small stick but i was really hoping for a relaxing day of flying, when all i really got was a day full of cursing the damn wind for not stopping for 1 second, i've never seen such a suddle but still effective wind blow ALL DAY and never let up.. SIGH!
Jinx is offline Find More Posts by Jinx
Old Apr 10, 2004, 11:44 PM
jamin is offline
Find More Posts by jamin
Big 3D
jamin's Avatar
Lufkin, TX
Joined Feb 2003
your seros are sliding on the fuselage stick. That is what is messing up you surfaces. That is also changing you CG. Makes it very hard to fly
jamin is offline Find More Posts by jamin
Old Apr 10, 2004, 11:53 PM
sarge is offline
Find More Posts by sarge
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
I don't see how the servos could slide on the fuse if they are installed properly. Jinx posted a picture, and they seemed to be attached correctly. I wonder if he might have the larger size Dubro connectors. That would allow the control rods to slip inside the connectors, even when the set screw is tight.
sarge is offline Find More Posts by sarge
Took the slow stick out today.. =( Jinx Parkflyers 178 May 16, 2004 07:24 PM
Took the slow stick out today.. =( Jinx Parkflyers 4 Apr 11, 2004 05:57 AM
Slow stick out of control... isvana Parkflyers 0 Sep 22, 2003 01:19 AM
Slow Stick pics today, take off at 11,000 MSL eBird Aerial Photography 29 Aug 20, 2003 10:04 PM
Slow Stick Arrives TODAY! Hank_Scorpio Electric Plane Talk 62 Mar 31, 2003 10:04 AM
