Old Apr 08, 2004, 01:52 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
One Hour CD ROM Construction Part 5
continued from here http://www.rcgroups.com/forums/showt...5&pagenumber=1
Part 5 already!
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Apr 08, 2004, 01:58 AM
Joined Dec 2003
For those looking for past threads:
Part 1: http://www.rcgroups.com/forums/showt...hreadid=127606
Part 2: http://www.rcgroups.com/forums/showt...hreadid=174595
Part 3: http://www.rcgroups.com/forums/showt...hreadid=204419
Part 4: http://www.rcgroups.com/forums/showt...5&pagenumber=1
Old Apr 08, 2004, 03:41 AM
jjkwang is offline
Find More Posts by jjkwang
MSDP
Daegu, Korea (South)
Joined Jul 2001
Let's make CD ROM!!!! NOOOOO, CD ROM brushless motor!!!
Thanks all for share.
Jae-Kwang
jjkwang is offline Find More Posts by jjkwang
Old Apr 08, 2004, 06:48 AM
Erik Johansson is offline
Find More Posts by Erik Johansson
Gothenburg, Sweden
Joined Jan 2001
Originally posted by rysium
Thanks Ron,
You are the 'guru' so I though I'd better ask before I do something stupid. So I guess for my project (high torque DD) 24 magnets would give me more torque with about 5-6grams penalty. If I can get away with 12 magnets (for lighter and for cheaper motor), I will stick to it. However if I will not get my 20oz thrust I will have to addanother 12 magnets (6grams and 4 bucks more).
I will let youi know the results.
Richard
Why not try a 14-pole motor? I plan to do just that when my stators arrive. With 4mm wide and 1.5mm thick magnets.
Winding according to the table Ron posted should be: ACaBAbCBc
/Erik
Erik Johansson is offline Find More Posts by Erik Johansson
Old Apr 08, 2004, 07:49 AM
plumb is offline
Find More Posts by plumb
Look what I did:D
plumb's Avatar
orlando,Fl
Joined Mar 2003
three doesnt divide into 14 too well. cant see how youll get more torque youll have magnets opposing a phase. right?
plumb is offline Find More Posts by plumb
Old Apr 08, 2004, 07:50 AM
Gothenburg, Sweden
Joined Jan 2001
IŽll let Ron explain that.
But as you can see a special winding is needed and yes, it does work.
The LRK motors are either 14 pole too, FWIW.
/Erik
Old Apr 08, 2004, 08:37 AM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
LRK are 14 magnet pole yes, but also 6 or 12 statorpoles. This makes the equation completely different.
KreAture is offline Find More Posts by KreAture
Old Apr 08, 2004, 08:55 AM
Gothenburg, Sweden
Joined Jan 2001
Yes of course, I was just considering what he said about that 3 (phases) doesnŽt divide into 14 too well.
IŽm not getting into the technical discussion without more info so IŽll hope that Ron can explain this. I know he have discussed in in other threads and in the table he posted the 9 teeth / 14 pole combination was not marked as a "bad combination", so I trust that until itŽs proven wrong.
http://fast-results.com/lnl/nutpol.htm
/Erik
Old Apr 08, 2004, 09:15 AM
mbcone is offline
Find More Posts by mbcone
Albuquerque Intl, New Mexico, United States
Joined Jun 2003
I just built a 14 pole motor and it definitely works. Now I am waiting on different batteries for more detailed results. So far I have tried it with 3 cells and it pulls 6.2 amps WOT with a GWS 10x6 HD. Want to try it with 2 cells and a SF prop. - Brian
mbcone is offline Find More Posts by mbcone
Old Apr 08, 2004, 10:01 AM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
The latest one I 've built turns a 10x6 DD at 2.9 amps. It has 12 -12 x 4 x1 magnets and doublestacked stator. The magnet spacing is to wide at only about 60% coverage.
Bill Bergman is offline Find More Posts by Bill Bergman
Old Apr 08, 2004, 10:03 AM
mbcone is offline
Joined Jun 2003
This is quite addicting!
Old Apr 08, 2004, 10:07 AM
Houston, Tx.
Joined Jan 2003
yep
Old Apr 08, 2004, 10:31 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
Re: One Hour CD ROM Construction Part 5
Originally posted by arx_n_sparx
couldn't find the wire, Tony, but this tubing looks interesting......
Go to page 715 of their online catalog. The magnet wire is at the bottom of the page.
Tony
t-turley is offline Find More Posts by t-turley
Old Apr 08, 2004, 10:33 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
But as you can see a special winding is needed and yes, it does work. The LRK motors are either 14 pole too, FWIW.
Guys, the table is not mine, it's from Ludwig Retzbach (the 'R' in lrk). It's all about pole/magnet overlap, which pole should attract and which pole should repel. If a coil attracts a magnet it will repel the magnet if you wind it the other way round.
Groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Apr 08, 2004, 10:45 AM
t-turley is offline
Joined Mar 2001
I found this on page 107 of the McMaster-Carr catalog:
#50295K29
Metric Seamless Carbon Steel Tubing 12 mm OD, 9 mm ID, 1.5 mm Wall, 6' Length
$ 14.65 Each
They have a range of metric sizes. I know very little about metallurgy, so would carbon steel tubing in short lengths be suitable for motor mounting?
Tony Turley
One hour CD ROM motor construction PART2 Takao Shimizu Power Systems 754 Sep 08, 2010 12:12 PM
One hour CD ROM construction part 7 rysium Power Systems 806 Dec 18, 2006 02:58 AM
One hour CD ROM construction part 6 arx_n_sparx Power Systems 1050 Mar 10, 2005 07:08 PM
One hour CD ROM motor construction PART 4!! t-turley Power Systems 555 Jun 07, 2004 07:33 PM
One hour CD ROM motor construction PART3 rysium Power Systems 511 Mar 22, 2004 01:03 PM
