ReadyMadeRC FPV Camera and Pan and Tilt
In this review we build the Pro Pan and Tilt and test the Pro 700N FPV camera from RMRC.
These two FPV units work together to make your FPV experience better.
Pro 700N - 700TVL WDR CCD (NTSC)
I was looking to upgrade my FPV cam and pan and tilt on my Penguin aerial platform. The word from Tim at ReadyMadeRC is that he feels the Pro 700N is one of the best FPV cams out there. The retail price is $149.99. While I have yet to attempt low light FPV flying I can say the Pro 700N was a big jump up from my old Fat Shark unit.
One interesting thing about this camera is that it has 960 horizontal pixels of resolution but standard definition video is limited to 700 TVL. So while this camera has a higher TVL it can only really be rated as a 700 TVL.
The camera also has built in menu buttons on the back. That means you can tweak your settings on the fly unlike some cameras that have to have an external button pad connected to make changes. Don't be too quick with changing the settings. RMRC ships each unit with the settings they feel work best for the 700N.
RMRC Pro700N and Pan and Tilt (6 min 57 sec)
It also has 5-15V input range. This allowed me to plug it directly into my flight controller (FY 41AP) for power. My old camera needed a UBEC for power.
Specifications
  • 1/3" Sony 960H Ex-view HAD CCD II, EFFIO-P DSP
  • Composite video output
  • Pixels: PAL: (H)1024x(V)596; NTSC: (H)1028x(V)508
  • 700 TV Line
  • 0.06Lux/F1.2; 0.01Lux/F2.0
  • Standard 3.6mm optic lens
  • On-screen controls for setting camera parameters
  • S/N Ratio: More Than 50dB (AGC off)
  • DNR: 2D DNR (Digital Noise Reducer)
  • Integrated line-level microphone
  • RCA equipped A/V cable
  • Video Output: 1Vp-p 75 Oms , Negative
  • Audio Output: 300mV at 600 Oms
  • 2.1mm x 5.5mm DC Power Jack
  • 1.3 ounce (36 grams).
  • Micro Size, 1.2 (H) x 1.2 (W) Inch [30 x 30mm].
  • Power Consumption: DC 5V-15V, 150mA-50mA
Click here to learn more and purchase.
Pro Camera Pan and Tilt Kit
The Pro Pan and Tilt is carbon fiber reinforced plastic that starts at $34.99. The pieces are cut well and it goes together without a hitch. Be sure to make sure you have each piece put together the right way before you hit it with CA. You can accidentally get some pieces backward. The design works like a standard pan and tilt but with an extended travel servo or a servo stretcher you can get a 360 degree pan. The pan is mounted to a metal mechanism rotating on precision bearings for better durability.
The camera mount works with full size FPV cams including the RMRC-420, RMRC-480, RMRC-540, RMRC-600XV, RMRC-700XV. It also has a cutout in the back for the menu buttons (nice!).
You can mount smaller cameras with double stick tape.
Build Photos
Manual for the pro pan and tilt.
Old Jun 27, 2014, 07:36 AM
Werner_Molder is offline
Find More Posts by Werner_Molder
Joined Sep 2004
Hi, very interesting topic !! and product ...BUT....
I need please to know about how did you connected directly these two servos channels into your FY41AP ?, you mean maybe directly into two free channels of your RX receiver right ?, because Feiyu Tech do not recommend to connect servos directly into the Rx. Please I need your answer at hmr190@gmail.com
regards
Hugo.
Werner_Molder is offline Find More Posts by Werner_Molder
Old Jun 27, 2014, 07:43 AM
Jim T. Graham is offline
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
I clipped the red lead going to the RX from the FY unit and powered the RX with a lipo and UBEC.
Jim T. Graham is offline Find More Posts by Jim T. Graham
Administrator
Old Jun 27, 2014, 07:50 AM
Administrator
Joined Mar 2002
Here is a post showing how to do that.
Administrator
Old Oct 03, 2014, 08:35 AM
John Snow is offline
Find More Posts by John Snow
Joined Aug 2014
I found SurveilZone just sell $111 the same camera? is it the same? http://www.surveilzone.com/dc5v-sony...s-audio-hs1173
John Snow is offline Find More Posts by John Snow
Sold (12) GoPro Hero3 + FPV Camera Pan & Tilt Version 2 (second run) crd FPV Equipment (FS/W) 26 Nov 18, 2013 02:55 PM
Sold CXN - GoPro + FPV Camera Pan & Tilt (Version 2) crd FPV Equipment (FS/W) 16 Nov 11, 2013 12:26 PM
Sold ReadyMadeRC Antenna pan/tilt assembly kit Papajeff FPV Equipment (FS/W) 0 Oct 08, 2013 09:19 AM
Sold xv600 readymaderc camera with pan and tilt kit DarbTech FPV Equipment (FS/W) 3 Mar 05, 2013 03:13 PM
Sold Readymaderc Easy Star FPV Pan/Tilt Pod Kit Mikey636 FPV Equipment (FS/W) 1 Feb 14, 2011 03:19 PM
