Wing Retainer System
Keep those wings on without loose hardware
Simple Wing Retaining System
Setting up and tearing down a sailplane with multiple wing panels is not the most fun part of your day. Who wants to spend time tightening set screws or taping up those outboard panels when you could be flying. This Wing Retaining System is a nice clean solution. Once installed, just slide your panel into place and the plastic fastener will lock the wing on. A plastic wedge tool is supplied to easily separate the panels when you're ready to pack it back up.
Check out the Wing Retainer System at Esprit Model.
Old Jun 10, 2014, 08:20 PM
gotime360 is offline
Find More Posts by gotime360
It's GoTime all the Time
gotime360's Avatar
United States, CA, Portola
Joined Nov 2011
Varry COOL
gotime360 is offline Find More Posts by gotime360
Old Jun 10, 2014, 11:34 PM
Rayven is offline
Find More Posts by Rayven
Lift is good
Rayven's Avatar
Olympic Penninsula, WA
Joined Dec 2001
How do you get at the retainer slot when its buried inside the inboard and outboard panels? I can see how you can get at the root if you have access inside the fuselage (which I do on most of my big gliders.
Rayven is offline Find More Posts by Rayven
Old Jun 11, 2014, 04:31 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Couple of hooks and a rubber band are cheap.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Jun 11, 2014, 01:01 PM
gordonbw is offline
Find More Posts by gordonbw
gordonbw's Avatar
Canada, ON, Toronto
Joined Oct 2000
These are OK but a bit brittle. I have already replaced one set due to dropping a wing panel, as the plastic retainer clip snapped off. My advice is to order extras when you buy the product.
gordonbw is offline Find More Posts by gordonbw
Last edited by gordonbw; Jul 02, 2014 at 12:46 PM. Reason: Trying to be more positive...
Old Jul 20, 2014, 07:54 AM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
I tape the wings to seal the air gap.
Hoot is offline Find More Posts by Hoot
Old Jul 20, 2014, 09:53 AM
MicroRotors is offline
Find More Posts by MicroRotors
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
+1
The only true fail safe way.
Regards
Bill
MicroRotors is offline Find More Posts by MicroRotors
Latest blog entry: My New Toy!
Old Jul 21, 2014, 09:28 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I am not sure I understand how these work or how you disconnect them. I might still use tape to seal the gap but a more secure way to connect the wing sections might be desirable anyway.
Would it work on a Radian type wing where the wings join inside the fuse?
aeajr is offline Find More Posts by aeajr
Old Jul 21, 2014, 09:59 AM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
The pins snap into the socket. You remove the wing by inserting the wedge between the wing root and fuselage and prying them apart. With the Radian, you would have some difficulty getting the wedge between the two wing panels, since it's inside the fuselage. I also think the foam would make a poor edge to pry against with the wedge.
Wazmo is online now Find More Posts by Wazmo
Old Jul 21, 2014, 11:19 AM
fa2 is offline
fa2
Find More Posts by fa2
fa2
Joined Jan 2010
use tape, my brothers - it's cheap, easy, and it works - the best pilots just use tape!
fa2 is offline Find More Posts by fa2
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 4 Mar 26, 2012 04:44 PM
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 2 Dec 03, 2011 08:41 PM
For Sale Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 May 28, 2011 01:17 PM
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 Mar 31, 2011 11:27 PM
Sold Wing Retainer System & Wing Lock Set iflytailies Aircraft - Sailplanes (FS/W) 0 Feb 14, 2011 09:37 PM
