Old Apr 06, 2004, 01:24 AM
tdavis is offline
Find More Posts by tdavis
Props and Baby Food!
tdavis's Avatar
Hartsville, SC
Joined Jan 2004
Question
white 4 1/2 foot gliders from WalMart.. conversion?
hey guys, forgive me if this has already been discussed... but I was wanting to make a steerable glider out of my "WALMART foam glider".. It's the big 4 1/2 foot one...
I noticed that the current CG point is right at the trailing end of the wing where it meets the fuse.. If I were to add batteries, servos, and a receiver to the plane, I'm assuming I should keep that CG there?
I'm sure I'm not the first to do this, so you guys that's tried it before, let me know before I start hacking it up!
Also, stop me if this is a waste of time! (not that I'd be all that upset for wasting $5 to build something that ended up just being trash)
But if noone's really had any luck with this, let me know..
Thanks!
Trey
tdavis is offline Find More Posts by tdavis
Old Apr 06, 2004, 06:42 AM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Heres what I do with the 4 1/2 foot wally mart kiddie gliders....
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Apr 06, 2004, 10:13 AM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
I converted one to tow up with a Slow Stick. Since this picture, I've added some ailerons for greater stearing control.
I have my CG mid-wing and it's too far back still. I'm putting in a larger Rx pack to add more weight in the nose.... hopefully closer to 1/3 chord.
Oh... unless you have the "swept wing" version, then I think it does go right at the TE where the wing meets the fuse.
It flies great!
Darren
Darren Hintze is offline Find More Posts by Darren Hintze
Old Apr 06, 2004, 11:59 AM
tdavis is offline
tdavis's Avatar
Hartsville, SC
Joined Jan 2004
Yeah, mine is the swept-wing... good idea with the tow-plane.. I may keep that in mind! Get my buddy to carry me up! Well, maybe I'll carry him up, since my SS has a lot more power than his!
I found several threads on here about converting these planes. Seems alot of people are mounting motors to them too.. I'm having a hard time deciding which direction to go with it right now!
I like that pattern on the wing of the SS.. Simple yet beautiful! Is that paint or covering?
Old Apr 06, 2004, 03:49 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
Check this out
If you go here you'll find of one the first foam glide conversions
At this site it converts to either a flying wing or a cool poly wing pusher.
http://www.acesim.com/rc/
Here in the zone one of the easiest conversions I've seen is here:
http://www.rcgroups.com/forums/showt...ght=dirt+cheap
pcaffeldt is offline Find More Posts by pcaffeldt
Old Apr 06, 2004, 05:15 PM
Tight is Right
Joined Dec 2001
Thanks.
It's Krylon shorts paint. I always paint my Slow Sticks. That was my first SS.... I'm on #3 now
Darren
Old Apr 06, 2004, 05:20 PM
Tight is Right
Joined Dec 2001
Dang, wouldn't let me edit and add a pic... here's SS #2, again Krylon shorts on homemade floats.
Discussion 4 1/2 foot toystore glider conversion nelsonmay10 Foamies (Kits) 10 Feb 21, 2007 08:12 PM
$1.24 actuator coil from Walmart jsenner Scratchbuilt Indoor and Micro Models 46 Mar 03, 2005 07:58 PM
4 1/2" diameter dummy engine on ebay JerryHall Scale Kit/Scratch Built 1 Aug 14, 2004 11:03 PM
2 new gliders from FVK... Vic Peh Electric Sailplanes 2 Sep 17, 2003 12:06 PM
(4) 1/2/3 cell Lithium chargers - $16.00 each Danny Troy Aircraft - Electric - Airplanes (FS/W) 8 Oct 20, 2002 08:47 PM
