Old May 29, 2014, 08:18 PM
Soma is offline
Find More Posts by Soma
Australia, QLD, Brisbane
Joined Sep 2012
Warpquad - Acro & FPV
www.warpquad.com
- String Theory Acro Frames
- MotoWii FC
- 'Z'-Pod FPV Concept
230mm String Theory Frame
--- Full Details ---
Soma Warpquad (2 min 46 sec)
4S Maiden...
Warpquad 230mm 4S Maiden Session (1 min 49 sec)
I'm going to start trying to keep up with videos here too!
New one from BOP with the 5mm 230mm arms...
WarpQuad 230 KDE motros runnning 4s (2 min 42 sec)
One from Bird Of Prey! Amazing flying with the Maggie!
Kingfisher 230 WarpQuad under attack (2 min 23 sec)
No Shoes!
Warpquad SS2204 KISS Uncut / Bonus Crashes (2 min 19 sec)
270mm String Theory Frame
Warpquad 270mm Frame (4 min 31 sec)
Incredible flying from Quadmovr!!!...
http://www.rcgroups.com/forums/showthread.php?t=2215755
warpquad270mm mn2206 2000kv 7x2.4 cf prop kiss esc proto 18a nanowii 3s1250 35c crash (2 min 45 sec)
These are his builds here...
http://www.rcgroups.com/forums/showt...3#post29105251
And more here...
http://www.rcgroups.com/forums/showp...postcount=3382
200mm String Theory Frame
Warpquad 200mm Maiden Session (4 min 22 sec)
MotoWii FC
--- Full Details --- (and details below from Moto Moto)
MotoProto One (4 min 22 sec)
Warpquad 'Z'-Pod FPV Concept
--- More pics ---
Designed for fast forward flight, in high power FPV craft, so you can see where you're going.
Pros
- Mass is centralised as close as possible to the centre of gravity
- Centre of gravity is as close as possible to the centre of the prop disks
- FPV weight is centred on the 'Z' axis and balanced by the lipo
- Symmetric for even Pitch / Roll response and easy tuning
- Both cameras are tilted back 30 degrees
- Both cameras have prop free vision
- The camera becomes level in steady forward flight
- Ground is in the lower 1/5th of the screen, with a 2.8 lens, on take off and low hover
- Removable and transferable between frames
- Power is only connection between frame and pod
- Connected with cable ties to break free in a hard crash
- Mass dampened and isolation mounted
- Antenna's radiation pattern is level in FFF and placed well clear of obstruction
- Off the self parts
- Lightweight
- Aerodynamic - it does make a difference!!!
Cons at the moment...
It's a hack
Dubious RX placement
VTX is exposed in a crash
Pod needs improved aerodynamics
Antenna extension cable needs a double right angle (on its way)
Better suited in size to the 270mm frame at the moment
Need better lipos!
The next step is head tracking. First a single servo on pitch, working up to a 3 axis brushless gimbal More details to come...
Warpquad 'Z'-Pod FPV Maiden (3 min 56 sec)
Thanks for reading, more details are to follow. If you are interested in reading more on the development of the acro frames it started being quietly discussed from here...
*** Please note these are frames only. Hobby level skills are required for construction (see below)
Soma is offline Find More Posts by Soma
Soma is offline
Joined Sep 2012
Construction Video Series... Warpquad String Theory frame.
Carbon Finishing...
Warpquad Carbon Finishing (11 min 31 sec)
Additional notes...
- Use a fresh square of sandpaper for each part.
- Some plates are sized so the screws thread through the lower plate and then thread into the arms. The top plates are looser so they slip over the screws. If your plates are labeled top and bottom, this is the reason. It is to keep tolerances as tight for the firmest frame possible.
- There is a spare high tensile / stainless steel screw included in the fastener pack to thread through the carbon before using the alloy screws.
Epoxying Motor Wires...
Sunnysky X2204S 2300KV Motor Wire Epoxy (4 min 12 sec)
Power Loom Construction...
Warpquad Power Loom (13 min 11 sec)
New power loom method here...
http://www.rcgroups.com/forums/showp...postcount=1250
Also, a fifth set of smaller wires can be added to run the FC directly from the lipo distribution point to keep the voltage as clean as possible.
ESC Prep...
Warpquad ESC Prep (5 min 33 sec)
Arm Assembly...
Warpquad Arm Assembly (12 min 51 sec)
*** I'm now recommending heatshrinking the arm first, then following the standard procedure. This for an extra layer of insulation to protect the ESC from the carbon. *** 10mm heatshrink just fits over the arm, 12mm would be ideal.
Main Assembly...
Warpquad Main Assembly (10 min 59 sec)
Main Assembly Amendment...
At times there are top and bottom plates marked. During QC if some are tighter tolerance I make them lower plates, and the slip fitting ones tops. The lower ones require the screw to thread through. They fit nice and tight but the threads will still slip to pull up tight on the arms. The top plates are looser so they can slip over the tops of the threads in final assembly.
The arms are sized similarly. The motor screw holes are a slip fit while the frame side holes at times require the included hi tensile steel screw to thread through them first (so you don't wear out the alloy screws). This is all in an endeavour to keep the frame as tight as possible given any variables at hand.
To assemble, thread the screws through the lower plate until the ends just protrude, and then start them into the arm. Keep the gap even between the two and evenly pull in the gap as the heads reach the lower plate.
Final Assembly...
Warpquad Final Assembly (11 min 2 sec)
Low Profile Motor Pins for Quadcopter FC Board...
Low Profile Pins for Quadcopter FC (5 min 11 sec)
Old May 29, 2014, 08:19 PM
Moto Moto is offline
Find More Posts by Moto Moto
Herd WarpSquad
Moto Moto's Avatar
United States, AL, Guntersville
Joined Dec 2012
MotoF3 STM32F3 Flight Controller
The MotoF3 is an integrated flight controller, power distribution board and frame plate for the Warpquad 200/230/270 frames. The board has a 32-bit STM32F3 CPU with 256K of program flash for compatibility with Cleanflight or Betaflight firmware using the MOTOLAB board target. On-board features include 2Mbyte SPI flash memory for blackbox data logging, audio buzzer, and a 4S compatible switching power supply. Interfaces include PPM, SBUS, Spektrum SAT, and two external UART channels (in addition to the third UART dedicated for SBUS/SAT). The built-in DFU USB device is used to avoid conflict with UART interfaces. Four PWM outputs for motors plus two additional PWM signals for servo passthrough are provided.
The MotoF3 greatly simplifies assembly by eliminating the need for a spider-style wiring harness. The LIPO battery and ESCs all connect directly to the board.
Note: We strongly recommend the "Moto Sammich" style construction for maximum structural integrity, using 18 or 20mm bolts and the full Warpquad frame plate as a top cover.
These boards can be ordered with Warpquad kits on ImpulseRC's website here:
http://impulserc.com/motof3-flight-controller-pdb
or as in integrated frame/flight controller kit here:
http://impulserc.com/warpquad-motowi...e-kit-4mm-arms
Assembly Instructions
Soma's build video for the MotoF3/Warpquad frame kit
MotoF3 Build (11 min 44 sec)
Additional Assembly Notes
The bottom side of the PCB contains the power distribution circuitry. It is covered by solder mask which provides some electrical isolation, but it is necessary to use additional insulation between the board and the carbon-fiber Warpquad arms. A layer of electrical tape on the arms trimmed to the outline of the arms seems to work well.
Solder a lipo pigtail into the two holes at the bottom of the board. 14ga wire is recommended. Lipos up to 4S may be used. Solder the ESC + and - battery leads to the pads on each corner of the board. Observe the polarity markings on all connections. Some ESCs will require crossing the power leads. Solder the signal wire of the ESCs to the small pads between the power leads.
Receiver connections for SBUS or Spektrum SAT devices use the 3-pin connections labelled as such. 1.5mm JST sockets may be installed on top or bottom of the board. If installed on the bottom, the SAT connector pin order will be reversed from standard.
For receiver installation under the top cover, make sure the receiver isn't smashed into the ICs on the flight controller. That will usually require removing the header pins or connector on the receiver and attaching the wires directly to the PCB, as here:
PPM receivers will connect to the labelled header pins. Install the buzzer on the board observing polarity.
For Blackbox data logging using the on-board flash, set blackbox_device=SPIFLASH in the Configurator CLI.
Firmware installation instructions are detailed here:
http://www.rcgroups.com/forums/showp...30&postcount=1
Technical support for setup questions and troubleshooting is available on this thread:
http://www.rcgroups.com/forums/showthread.php?t=2537379
Historical MotoWii Documentation
This information applies only to the discontinued MotoWii board, retained here as an archive.
Notes on MultiWii configuration and installation are here:
http://www.rcgroups.com/forums/showthread.php?t=2230193
Custom MultiWii Sketch
This board differs from any of the standard MultiWii boards and requires a customized version of the MultiWii code. The source code for the "sketch" for MultiWii 2.3 for MotoWii is attached. In Arduino, select "Leonardo" as the board type. These sketches are based on a snapshot of MultiWii later than 2.3 that runs the looptime faster, around 2200uS instead of 2600 in the MultiWii 2.3 release.
Change History:
V2 has the ESC calibration high throttle duration increased from 3 to 8 seconds to work with slow-starting ESCs like some versions of BLHELI.
MultiWii_MotoWii_RevB_V2
V3 has KISS 125uS Oneshot mode support selectable with #define ONESHOT. This will work on any PROMICRO target including NanoWii and Flip Pro. Oneshot mode requires shorting the 125uS option jumpers J1 on the ESCs.
V3 also has the FAILSAFE_OFF_DELAY reduced from 20 seconds to 5 seconds so the motors will stop quicker in a failsafe.
MultiWii_MotoWii_RevB_V3
MotoWii connects to receivers using Spektrum satellite or PPM-SUM interfaces. The sketch is preconfigured for SPEKTRUM 2048 using the header labeled SAT. The S, G and V pins are signal, ground and Vcc (3.3V). To use PPM-SUM instead, connect to the header labeled G, V and PPM for ground, Vcc, and signal. Comment the SPEKTRUM define and uncomment the required PPM_SUM define in the sketch. (Do NOT uncomment #define PPM_ON_THROTTLE - that does not apply to this microcontroller.)
ESC Calibration
The sketches linked above support automatic ESC calibration without reloading the sketch. This requires installation of a two-pin header on the connector labeled "CAL" on the board. The ESCs are properly calibrated to the range of the MINCOMMAND to MAXTHROTTLE values in the sketch.
To perform calibration:
1) REMOVE THE PROPELLERS The calibration function sends full throttle signals to the ESCs and the potential for disaster exists unless the props are removed.
2) Install a shorting jumper on the CAL header.
3) Connect a lipo. Wait for the beeping to complete, in about ten seconds. Note: The motors will not spin during calibration.
4) Disconnect the lipo and remove the jumper. Calibration is complete.
Moto Moto is offline Find More Posts by Moto Moto
Old May 29, 2014, 08:20 PM
Soma is offline
Joined Sep 2012
Tools Required
Soldering station - adjustable temperature.
- 0.8mm Round Tip
- 4mm Chisel Tip
- Solder 60/40 Tin/Lead
- Solder Wick 2-3mm wide
- Distilled water for tip cleaning pad
Diamond Files
http://www.hobbyking.com/hobbyking/s...ic_Alloy_.html
http://www.hobbyking.com/hobbyking/s..._File_Set.html
Wet & Dry Sandpaper 240 & 600 Grit (and sanding pad)
(Local Hardware)
2.5mm Hex Driver
http://www.hobbyking.com/hobbyking/s...rewdriver.html
1.5mm Hex Driver - For motor shaft set screws
5.5mm Nut Driver
http://www.hobbyking.com/hobbyking/s...mm_5_5mm_.html
8mm Nut Driver
http://www.hobbyking.com/hobbyking/s..._7mm_8mm_.html
Wire Cutters
http://www.hobbyking.com/hobbyking/s...e_Cutters.html
Knife Blades
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
100% Isopropyl Alcohol
(Local Hardware)
http://www.bunnings.com.au/diggers-1...cohol_p1564443
Blue Loctite
http://www.loctiteproducts.com/threadlockers.shtml
Servo Tester (or just use your RX)
http://www.hobbyking.com/hobbyking/s...h=servo+tester
ESC Calibration Cable
http://witespyquad.gostorego.com/spe...ion-cable.html
http://www.quadcopters.co.uk/esc-thr...-hub-694-p.asp
Heat Gun
http://www.hobbyking.com/hobbyking/s...earch=heat+gun
http://www.amazon.com/Iso-Tip-7975-M...=5336432818-20
http://www.amazon.com/s/ref=nb_sb_no...=5336432818-20
Grease
http://www.amain.com/product_info.ph...Mobil-1-Grease
Scorpion Motor Bearing Oil
http://www.hobbyking.com/hobbyking/s...aring_Oil.html
or Sewing Machine Oil
http://www.walmart.com/ip/Singer-Sew...-4-oz/19398733
DuBro Prop Balancer - I still havent found a magnetic balancer of high enough quality
http://shop.dubro.com/p/tru-spin-pro...ncer-qty-pkg-1
NITTO Electrical Tape
https://www.google.com.au/search?q=n...w=1680&bih=935
Blade Balancing Tape - For hubs, but do not use on these high speed applications!
http://www.amain.com/product_info.ph...hassis-Ballast
5 Minute Epoxy - (Only if motor wires require it)
(Local Hardware or Supermarket)
https://www.hobbyking.com/hobbyking/...0&currentPage=
Warpquad Electronics...
Ideally the frame was designed for the Flyduino Nanowii FC and KISS 12 /18A ESCs...
http://www.flyduino.net/home
Nanowii...
http://flyduino.net/Multikopter-FC-Multiwii_1
KISS ESCs...
http://www.rcgroups.com/forums/showthread.php?t=2083052
Have a look at witespy's store for great electronics!...
Have a look at witespy's store...
Flip Pro...
http://witespyquad.gostorego.com/fli...contoller.html
(Get the satellite plug soldered on, and request right angle pins on only the first 4 motor outputs)
Power jumper config...
Support thread...
http://www.rcgroups.com/forums/showthread.php?t=1876602
Reciever...
You only need a satelite RX with the Flip Pro, but you also need one normal RX to bind them. Get this...
http://witespyquad.gostorego.com/rec...with-uart.html
And then for future boards you just need more of these...
http://witespyquad.gostorego.com/rec...-receiver.html
LemonRX support thread...
http://www.rcgroups.com/forums/showthread.php?t=1773138
ESC's...
Ready to assemble onto the Warpquad
http://witespyquad.gostorego.com/spe...onk-naked.html
Soma is offline
Joined Sep 2012
Links to Builds...
Daryoon
1. WarpQuad arrival
2. XT60 connector mod and power distribution source
3. Motor wire runs and color hardware
4. ESC configuration and mounting + flash port and antenna relocation
5. She flies
6. Blutooth PID tuning
7. HK Frame Comparison
Warthox
With KISS ESCs
Quadmovr
Hanni
http://www.rcgroups.com/forums/showp...postcount=6342
Flits
Here's Flits's mod of the Z-Pod using the impossibly small TBS 500mW VTX
foobarbazqux
http://www.rcgroups.com/forums/showp...&postcount=542
Final Glide's Franken-Warp
http://www.rcgroups.com/forums/showp...&postcount=556
V1
And V2!!!
DarkShot's
http://www.rcgroups.com/forums/showt...1#post28762106
And that one flying!!!
Warpquad 8/13 (2 min 21 sec)
Another from BOP...
Kingfisher WarpQuad 230 Playing (1 min 37 sec)
I've so lost track of all the great builds! The thread has been moving so quick. Hopefully I'll catch up sometime!
Last edited by Soma; Nov 09, 2014 at 08:06 PM. Reason: Added Quadmovr's build blog link
Old May 29, 2014, 08:36 PM
Brainstorm is offline
Find More Posts by Brainstorm
Team WarpSquad
Brainstorm's Avatar
Côte d'Ivoire
Joined Jun 2012
Yahoo!! Bring on the Wave of Warpquads, Soma!
Brainstorm is offline Find More Posts by Brainstorm
Old May 29, 2014, 08:49 PM
nate25j is offline
Find More Posts by nate25j
Quad On!!
nate25j's Avatar
United States, AL, Auburn
Joined Dec 2012
Let's do this
FPV action!!! Very nice!
nate25j is offline Find More Posts by nate25j
Old May 29, 2014, 08:52 PM
Soma is offline
Joined Sep 2012
Ha!
That was Flits's first time flying in a month, first session with the copter, flying my control setup, and trying not to crash my prototype
He's a madman! Top Pilot That's him trying to take it easy!
We were all surprised how easy it is to adapt to the angled cam. It just feels right. It just doesn't hover very well.
But as a wise man said "Hovering gets you nowhere"
Old May 29, 2014, 08:56 PM
nate25j is offline
Quad On!!
nate25j's Avatar
Joined Dec 2012
Originally Posted by Soma View Post
Ha!
Haha very true! Looks awesome...definitely outside the box thinking there!
Old May 29, 2014, 09:04 PM
Soma is offline
Joined Sep 2012
Thanks mate, we're all surprised how well it works.
Its different, and won't be for everyone, but for what it does it does it very well. Particularly the way it handles like an acro copter
Off to do more testing now
Cheers all!
Old May 29, 2014, 09:18 PM
EArHog is offline
Find More Posts by EArHog
Alien WarpSquad
EArHog's Avatar
Joined Feb 2013
Originally Posted by soma View Post
but as a wise man said "hovering gets you nowhere"
Hee hee!
EArHog is offline Find More Posts by EArHog
Old May 29, 2014, 09:22 PM
EArHog is offline
Alien WarpSquad
EArHog's Avatar
Joined Feb 2013
On a more serious note...
One of my 3S Nano-Techs shows up as a 2-cell battery when I put the voltage checker on the balance lead. Same indication when I put it on the charger. I put the DMM on the main plug and get 7.6 volts.
Can it be fixed? Can it be flown (even if as a 2S)?
Old May 29, 2014, 09:34 PM
JustinL is offline
Find More Posts by JustinL
Team Warpsquad
United States, FL, Jacksonville
Joined May 2005
Wow the fpv looks like it will be fast and furious New thread looks great too. Anyone with issues seeing the small stuff soldering as I do, I just picked this up and it is working great! You can get up to 6x magnification with it. I'm using the 2.5x while prepping my new esc to install and it is so easy to see what I'm doing now and much easier to keep solder from getting where it shouldn't. The solder tips I finally got help too. The chisel tip is much better for getting the larger wires off the esc than the single medium tip I trudged through the initial build with.
Description:
http://www.ebay.com/itm/9892c-2LED-H...E:L:OU:US:1120
JustinL
JustinL is offline Find More Posts by JustinL
Old May 29, 2014, 09:51 PM
EArHog is offline
Alien WarpSquad
EArHog's Avatar
Joined Feb 2013
Attachment 6808061
JustinL
Wow, $8. Is it shipped BG slow from you-know-where? Weeks?
Seeing better would help, for sure. But stopping my hand from shaking and bouncing all over the place while I'm trying to set the iron down on that one tiny little spot is a bigger issue for me.
Old May 29, 2014, 10:01 PM
DarkShot is offline
Find More Posts by DarkShot
Team Warpsquad
DarkShot's Avatar
Canada, ON, Brantford
Joined Dec 2013
Congrats on finalizing everything and getting the ball rolling!
Can't wait for the Motoboards to come in stock, I might very well get one with one of those beautiful frames
DarkShot is offline Find More Posts by DarkShot
For Sale Qx9 carbon fiber acro fpv quad awdspider Aircraft - Electric - Multirotor (FS/W) 14 Jun 06, 2014 06:12 PM
New Product Phoenix Flight Gear 242 Carbon Fiber Flight Ring for Acro/FPV Z06 Tony Mini Multirotors 13 Apr 14, 2014 09:34 PM
Sold Warpquad 230mm Acro nate25j Aircraft - Electric - Multirotor (FS/W) 2 Apr 14, 2014 07:25 AM
New Product Phoenix Flight Gear 328 Flight Ring Carbon Fiber Frame For FPV/Acro Z06 Tony Multirotor Talk 3 Jan 22, 2014 08:50 PM
Discussion Quadcopter with FPV in Acro or Level Mode ? dezeubby Multirotor Electronics 10 Dec 15, 2013 09:13 AM
