Old Apr 05, 2004, 12:52 PM
David A Ramsey is offline
Find More Posts by David A Ramsey
New Jersey, USA
Joined May 2003
Boeing 727 Engine No. 2 Question
For those who are more intimate with 727 history, I have a question as to the intake opening of the center engine, No. 2.
While researching TWA 727-100's on www.airliners.net, I came across 2 photos that showed an obvious OVAL opening. One photo was a graveyard TWA in older livery. I've been assuming the opening was round. The plastic model I'm using (Hasegawa kit) is round.
Could older models have been oval and later models changed to round?
Thank you, David
David A Ramsey is offline Find More Posts by David A Ramsey
Old Apr 05, 2004, 01:57 PM
DaveA is offline
Find More Posts by DaveA
Lawrence, Kansas
Joined Dec 2001
On the few times I paid attention to the #2 inlet of the 727's I rode in, the inlets were noticably oval. Can't help with the new/old model question, heaven knows if they were new or old when I flew in them.
DaveA is offline Find More Posts by DaveA
Old Apr 05, 2004, 05:27 PM
New Jersey, USA
Joined May 2003
DaveA,
Appreciate the observation. Thanks
Old Apr 05, 2004, 05:55 PM
viscount is offline
Find More Posts by viscount
Connecticut
Joined Apr 2004
David
I believe the round inlets the #2 engine of 727s is the -100 series (short fuse). The oval inlets were on the -200 and later 727s (long fuse).
John
viscount is offline Find More Posts by viscount
Old Apr 05, 2004, 06:22 PM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
At Least We Know the DHL Inlet is ROUND
This is from www.Airliners.Net and all three inlets are round. I found this under "Boeing 727" A search under "Boeing 727-100" shows aircraft with round inletsand many of the aircraft in the 727-200 search results have round inlets. That is not conclusive, however, because in at least one instance I have found the same plane in all three sets of search results.
However, I recall when the 727 first fcame to Buffalo, NY and it seems as if the center engine did have an oval inlet. I think the engines have all been upgraded since for noise reduction as well as efficiency reasons and the newer ones require increased airflow, hence larger inlets.
As a bit of trivia, the 727's came to Buffalo before the 707's did because the runways weren't long [or strong] enough for the 707's.
Pete G.
P_J_Glor is offline Find More Posts by P_J_Glor
Old Apr 05, 2004, 06:25 PM
P_J_Glor is offline
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
DHL Follow-up.
The prior post didn't work, so here is the link for the DHL 727:
DHL 727
Pete G.
Old Apr 05, 2004, 06:38 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
My dad's a 727 Captain...
He just said "oval on 100's and round on 200's..."
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Apr 05, 2004, 07:07 PM
P_J_Glor is offline
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Well, there you go....
I guess he would know.
Pete G.
Old Apr 05, 2004, 08:23 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, he's been around them for a while. Flew 'em at Eastern and now at FedEx..
Old Apr 05, 2004, 09:46 PM
Eddie P is online now
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
I've got some 727 time too
The 727-100 (short body) had oval inlets on the #2. The -200 (stretched fuselage) all had round inlets. The Stretched -200 had larger engines that the -100, and I believe that was the reason for the change, in addition to the fact that the more air restricted oval inlet had a reputation of causing a few compressor stalls - in other words, an air starved jet. Later "advanced" -200's had larger engines yet, but the revised round inlet remained unchanged.
Long live the trimotor!
Eddie P is online now Find More Posts by Eddie P
Old Apr 06, 2004, 06:49 AM
New Jersey, USA
Joined May 2003
Thank you Eddie P, Tram, P_J_Glor, and Viscount for that info.
I've just completed the only 727-100 for GWS, EDF-50s with a round inlet on No. 2 engine inlet. My plastic reference model was a 727-200. I chose the 727-100 for less overall weight and only 68 passenger windows cut from Solite, in a TWA Livery. While only a stand-off scale, some details are nice to maintain.
Thanks to all. David
Old Apr 06, 2004, 12:04 PM
P_J_Glor is offline
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
727 pix
David --
Based on your outstanding Lear 23, for which I have plans and the Flying Models issue with the construction article, I would love to see at least photos of your 727, and hopefully news of test flights and another construction article for FM.
Don't keep us in the dark.
Pete G.
Old Apr 06, 2004, 12:45 PM
New Jersey, USA
Joined May 2003
P_J_Glor:
Your are very kind.
Will post 1 picture only later today. After it flys - it better - I'll start a thread. Thanks for your interest.
David
Old Apr 06, 2004, 02:06 PM
New Jersey, USA
Joined May 2003
727-100 PHOTO
Ok, here's my 727-100 with a round inlet on engine no. 2. I still have a few details to add.
45" wing span. Weight as shown, without battery, 9.8oz. With a 2S, 1500 Lipo, the flying weight should be close to 12.5oz.
GWS, EDF 50s, GWS RX and 2 GWS pico servos for aileron and flying stab. Castle Pixi 7-P ESC.
All balsa with solite covering and graphics.
Old Apr 07, 2004, 02:10 PM
Official Boat Bum
Eddie P's Avatar
Joined Mar 2000
Outstanding!!
Boeing 727 Engines 1 & 2 Question David A Ramsey Scale Kit/Scratch Built 25 Dec 15, 2007 04:53 PM
Boeing 727 airfoil/wing design question David A Ramsey Electric Ducted Fan Jet Talk 12 Dec 12, 2007 03:34 PM
Full Size Boeing 727 Pilots - Adverse Yaw Question David A Ramsey Scale Kit/Scratch Built 66 Jul 12, 2007 03:27 PM
Question B-2 question omega blood Parkflyers 4 Jan 15, 2002 10:55 PM
Hobby Lobby Miss 2 Question xjohnx Parkflyers 7 Nov 23, 2001 02:02 AM
