Trenton Nj Rr Stat, New Jersey (excl EWR), United States
Joined Sep 2003
I put the battery in the nose opened up the front compartment a little to fit the 3 lipo's pack. I took 1/32" balsa and made new ailerons and covered them with colored tape. I used HS 55's servos and put them side by side right behind the battery. I put reciever and the speed control in the big area behind the servos. I had made another motor mount out of lite ply the one that came with the kit was not usuable for my motor. I tried balancing based on thier numbers and I needed to put in an ounce of weight in the front. When I tried it out it was to heavy in the front so I removed the weight and left it alone and it was just right with no other weight. I hand lanched it at a 45 degree angle and it flew right out of my hand no problems. Throwing it up that way you clear the prop no problem. I will take some pic's of the inside and out and post them so you can see what I have tried to describe.
Miami, Fl
Joined Nov 2003
thank you.. so can you measure for me exactly where yours is balanced now?.. I want to duplicate it..
Herm Quote:
Joined Sep 2003
The way it ended up balanced was:
from the fuse on the leading edge measure 61/2" and from that point 2" back. That should give you a good starting point if you glassed the fuse. Hope that helps and good luck. Mine is flying real nice so far no problems. I will post some pictures if I can get the manage attachments button to work. Right now it will not let me attach pictures and I did attach pictures before so I am not sure what the problem is. |
Joined Sep 2003
I have a couple of pitures to let you see how it came out. Still flies great. Had a mis-hap. A li-poly battery shorted out and before I could get it out of the plane it melted the foam.
Since I had it glassed it now just weights less but still flies great.
Happened to run across this on the Great Planes Site while doing a firebat search
Firebat R/C Pusher Jet ARF (GPMA1400/1405) Tech Note Helpful tips to be sure your first flights with your Firebat are successful: After assembly, go through the assembly sequence again to check your work and setup. 1. Check that the stock propeller is on the correct way, with "printing" on prop facing the back of the plane. (NOTE: The optional propeller in the manual can be used for tractor and pusher models. As this is a pusher model, you need to turn the prop around backwards to use it on this model.) 2. Check that the propeller pushes the air back towards the rear of the plane. If not, reverse the leads to the motor. 3. Triple-check the balance point, make sure the balance is where it is supposed to be before flying. 4. Make sure battery is charged the full 4 hours prior to the first flight when using the wall charger included with the deluxe version. Setting up your servos and motor will use some battery power, so, before your first flights, holding the model, run the motor until the electronic speed control cuts off the power. This will discharge the battery so you can let the pack cool, then recharge 4 hours before the first flight. 5. Make sure the canards are set at neutral/centered per the instructions before flying, and that the leading edges move up when the elevator stick is pulled back on the transmitter. 6. Check ailerons for correct movement. 7. Do not attempt rapid climbs after hand launches. The Firebat is a delta wing model. Delta wing aircraft have a very high drag at low airspeeds. Allow the model to accelerate before climbing. Note that canard aircraft are stall resistant, not stall proof. The will not spin readily, but when they run out of airspeed, they need altitude and engine power to translate into energy to resume forward controlled flight. 8. ALWAYS range check the radio system before flying, with the motor off, and also with the motor running. 9. Remember, adding excess weight will affect the way the Firebat flies. Painting is an easy way to add weight. Do NOT add anything to your Firebat if at all possible. 10. The motor and battery recommended for the Firebat will provide flight times of 5-10 minutes. Both the motor and battery will be hot at the end of this time. If a larger battery is used, it will increase the run time and could cause the motor to overheat. Be sure to allow at least 10 minutes for cooling between flights. We do not recommend a larger capacity battery for this reason. 11. If your Firebat has poor performance check the voltage at the motor and the thrust. The voltage should be at least 7.5 volts with the motor at full power (be careful to avoid the spinning prop). An inproper battery, small wires or the ESC can cause low voltage. To check the thrust put the Firebat on a household scale wit the nose down (a digital scale is best). Note the weight of the model. Using care to avoid the prop, run the motor at full power and again note the weight. The difference is the thrust, which should be at least 9.6 oz. (300 g). 12. Check the thrust angle of the motor. There should be no up or down thrust. Great Planes Model Manufacturing |
Been almost 2 years since I have flown R/C regularly and haven't owned any R/C equipment since last Oct/Nov...got an electrifly Edge 540 for Christmas and a Firebat off Ezone. Got the Edge built, can't wait to have a Firebat again!
http://amtjim.rchomepage.com/FBX.WMV |
| Thread Tools | |
| Triplane plans on short final | cayuse | Parkflyers | 135 | Jun 18, 2006 11:19 PM |
| Alert Fokker Triplane kit on short final | cayuse | Parkflyers | 19 | Apr 02, 2004 10:05 PM |
