Espritmodel.com Heli Air
Old Apr 04, 2004, 08:56 PM
West Chester, OH USA
Joined Jan 2000
Building and Flying the Radical RC Micro-Stik
Hi All,
I haven't seen any posts on this new plane yet, so I thought that some of you might be interested in seeing this kit being built and flown. After seeing my friend Don Belfort’s beta version fly, I knew that I wanted one for myself. The kit was just released by Radical RC about a week ago, so I picked one up while I was at Toledo show.
The plane is quite small and is intended to be powered by a direct drive IPS motor and 3x2 or 3x3 prop. Compared to my E-spresso, this plane has a shorter wingspan (17.5”), a wider chord, and a shorter fuselage length. I like flying my E-spresso; however, after seeing the beta Micro-Stik fly, its looks and performance appeared to be different enough to justify owning both. While my E-spresso is like a mini-pylon racer and feels best when flown fairly fast, the Micro-Stik seems to be able to fly more slowly and is easier to hand-launch and belly-land on grass fields. Of course, I’ll have a better idea of how it performs when I get mine done and in the air. So let's get started!
Don Leitz is offline Find More Posts by Don Leitz
Old Apr 04, 2004, 09:07 PM
Joined Jan 2000
Wing Construction
The kit consist of a few sheets of balsa and ply, all nicely laser cut, a few pieces of hardware, and a six page instruction book. The directions are short, but more than adequate. No full-size plans are included or needed.
Construction starts with the wing. The plane uses a unique method of attaching the ribs to the main spar. The ribs are split in half, front and rear. The rear ribs have tabs that fits into slots in the spar and extend out through the front. The front ribs have a cut out that matches the tab, and are placed in front of the spar in line with the rear ribs.
Old Apr 04, 2004, 09:11 PM
Joined Jan 2000
The rest of the wing is pretty standard. The trailing edge and wing tips interlock to the ribs and spar. I didn't use any thin CA until I got to this point in the construction.
Old Apr 04, 2004, 09:16 PM
Joined Jan 2000
The leading edge is cut to length and added. A balsa plate is added between the two inner most ribs to act as a servo mount. Total time to build and sand the wing: 50 minutes. The kit includes a couple of easy hinges for the ailerons, but I plan on using tape hinges, so I beveled the aileron leading edges accordingly. Note how small this wing is.
Old Apr 04, 2004, 09:19 PM
Joined Jan 2000
Tail
The horizontal and vertical stabs are next. A rudder is optional, but I'm not adding it. Total time for both stabs and elevator: 10 minutes.
Old Apr 04, 2004, 09:24 PM
Joined Jan 2000
One hour after starting, and I'm ready to start the fuse! Construction is straight forward, with two formers, laser-cut slab slides, top and bottom all interlocking together. Very easy to get a straight fuse this way. Note the small magnet at the rear of the wing opening. It will be used to retain the rear of the wing.
Old Apr 04, 2004, 09:30 PM
Joined Jan 2000
The kit comes with two firewalls. One is laser-cut to mount a GWS motor using a heatsink as part of the mount. The other is left solid and can be modified for mounting other motors. I think that using one of the new small outrunners in this plane would be a blast, but I plan on using the GWS motor and therefore chose the first one. Note the cut-outs that make the firewall look like the Red Baron's face complete with moustache - a nice touch!
Old Apr 04, 2004, 09:33 PM
Joined Jan 2000
Here's my progress after two hours' worth of work. Ready for a final sanding and then covering.
Old Apr 04, 2004, 09:43 PM
Joined Jan 2000
I used red and a little white Solite to cover the plane. Covering is definitely not my forte, but I have to admit that after a covering a couple of other planes with Solite, it's really no more difficult to use than any other covering. It just takes getting used to. Total covering time: 2.5 hours (told you it wasn't my forte ). I hinged the ailerons and elevator with SR hinge tape and installed one of the supplied ply control horns on the elevator. However, I will use Dubro micro-horns instead of the ply horns for the ailerons, as they are easier to install and I have have had good luck with them in the past.
Here's the plane so far, after about 5 hours of work:
Old Apr 04, 2004, 11:41 PM
Gizzmo0411's Avatar
United States, TX, San Angelo
Joined Mar 2004
So this is a 3 channel then?
One channel for the ailerons, one for the elevator, and one for speed?
Gizzmo0411 is offline Find More Posts by Gizzmo0411
Old Apr 05, 2004, 07:30 AM
Joined Jan 2000
Yes. Aileron, elevator and throttle control using very small (PS-20, HES 4.9, etc.) servos. Rudder is optional, but not required, and probably not too effective on this plane. The plane does all aileron/elevator aerobatics.
The target weight is 3-3.5 ounces, so every little bit of weight left off helps.
Don
Old Apr 05, 2004, 09:34 AM
Jiwer's Avatar
Odessa, TX
Joined Feb 2004
Wow, I really like this little plane and would love to hear your flight reports when you get it airborn.
Jiwer is offline Find More Posts by Jiwer
Old Apr 05, 2004, 10:30 AM
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Hey, that's cool! I can't seem to find it on Radical's site. What's the wing area?
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Apr 05, 2004, 12:02 PM
Joined Jan 2000
Martin,
Try this link and go to page 2. It's about half way down the page. Wing area is 88 sq. in.
Don
Old Apr 06, 2004, 07:43 AM
Huber Heights, Ohio, 45424, USA
Joined Mar 2000
Don, looks very nice. At least, you choose the right resolution to make your covering skills look first rate. ;-)
You cover much faster than I do really. I do love the So-Lite and Nelson.
Thanks for sharing our kit here on the Zone. We're very encouraged as it sold very well at Toledo considering its realy not "known" yet. I also look forward to your flight report.
Happy Flying!
Dave
radicalrc.com is offline Find More Posts by radicalrc.com
Radical RC Micro Stick Building and Flying alligood Parkflyers 864 Mar 09, 2012 02:20 PM
Discussion Anyone Flying Radical Rc's Micro Bipe? bajajrider Indoor and Micro Models 10 Jun 04, 2009 02:00 AM
FS all NIP Radical RC Micro-STIK, with IPS, and 2 amp speed controller $35 shipped phoneguy Aircraft - Electric - Airplanes (FS/W) 5 Feb 25, 2005 05:11 AM
Building and Flying a GWMP Sport E-Stik kelvin Sport Planes 272 Dec 08, 2003 07:01 PM
