This thread is privately moderated by Tahoe Ed, who may elect to delete unwanted replies.
Old May 23, 2014, 05:58 PM
Tahoe Ed is offline
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
FAQ
H3-3D Gimbal Reset
Here is the procedure to reset the gimbal when it bricks on upgrade.
http://www.rcgroups.com/forums/showp...6&postcount=11
Tahoe Ed is offline Find More Posts by Tahoe Ed
Site Sponsor
Old Jul 09, 2014, 12:45 PM
brused is offline
Find More Posts by brused
Canada, ON, London
Joined May 2012
High voltage problem with my 550 flame wheel DJI N-M
Hi I read how you helped the other person get his Flame Wheel going and I have a problem if you will care to read.
My F/W sat all winter and it was a cold one, It worked last year but all of a sudden my heart breaks. Naza-M Burnt my Good spectrum dx8 receiver, Then burnt 2 more.
My basic electronics are very limited. So now I have found another receiver for my Dx8 r/AR100e only this time I borrowed a volt meter from my friend, and found out that 10.6 volts are going to at least 2 wire connectors and probably them all
my receiver is rated for3.5v up to 9.6v so that I presume is the reason I burnt 3 receivers. I find I have 3.6v on the 2 outer wires and 10.9v on the 2 inner ? wires.
So I am stumped. I thought of getting a Bec from castle that regulates voltage and amperage for this type of problem, but I am stabbing in the dark. I don't under stand motor speed controls or much else. So much would an old man like me to have some rhetoric from you. Never flown for about 3 seasons, for that matter not at all. Someone built it for me Rick at Clubheli. Now he won't talk to me, I don't blame him really, I am a dope with RC's but a wizard with AC's. 40 years in HVAC
and I feel a bit sorry for myself for wasting so much of my money.
Thanks in Advance if you can
brused, Bent, Busted
I thought of getting a bec from castle that regulates voltage and amperage for this
brused is offline Find More Posts by brused
Old Jul 09, 2014, 06:08 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Brused,
You don't say which version of the Naza you have. However, it appears that either your VU or your PMU may be defective. I would replace it before frying another Rx.
Site Sponsor
Old Jul 14, 2014, 08:36 AM
brused is offline
Canada, ON, London
Joined May 2012
I am using version 2.20 and assitant software 4.0 i believe
Old Jul 14, 2014, 12:54 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
I meant Naza V1 or V2.
Site Sponsor
Old Jul 14, 2014, 07:47 PM
brused is offline
Canada, ON, London
Joined May 2012
I'm using version naza 1, hardware but cant find version 1 software i am using version 2 soft and because I'm not very savy on this stuff can u please explain what a VU or your PMU in detail, if you would,
what they are.
Thanks alot
Old Jul 14, 2014, 07:52 PM
brused is offline
Canada, ON, London
Joined May 2012
what they are.
Thanks alot
Old Jul 14, 2014, 09:02 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
With Naza V1 the power and led units were combined into the VU. When the V2 came along they separated them into the PMU for power and an additional can bus port and the LED. You can get additional information on each unit in the manuals.
http://www.dji.com/support
Site Sponsor
Old Jul 14, 2014, 10:07 PM
brused is offline
Canada, ON, London
Joined May 2012
Help me, I am not to fast or tired, Everything at this link is there, I don't see what i need to read or use for my naza=m, v1 software. Nor do i understand what software will educate me. Maby nothing will. Not sure But thanks.
Old Oct 13, 2014, 07:02 PM
azanchet is offline
Find More Posts by azanchet
Joined Oct 2013
Hi Ed,
I bought a He-3D last week and came with a Yaw issue.
I saw that this problem is common in H3-3D gimbal.
I updated it to the latest firmware (v1.8), but nothing worked.
If did I reset it, will be fix?
Thank you,
Alexandre
azanchet is offline Find More Posts by azanchet
Old Oct 13, 2014, 09:25 PM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Originally Posted by azanchet View Post
Hi Ed,
Thank you,
Alexandre
I would let us know what your set up is. DJI makes a lot of controllers that work with the H3-3D.
Site Sponsor
Old Oct 14, 2014, 05:55 AM
azanchet is offline
Joined Oct 2013
Hi,
my set is:
Gimbal H3-3D Standard from Foxtech, bought last week:
http://www.foxtechfpv.com/zenmuse-h3...rd-p-1516.html
Naza V2 + Mini iosd with last firm updated on Tarot T650 frame.
My last flight:
GIMBAL ZENMUSE H3 3D With Yaw Problem (3 min 17 sec)
Regards,
Alexandre
Old Oct 14, 2014, 10:51 AM
Tahoe Ed is offline
DJI Support
Tahoe Ed's Avatar
Joined Feb 2010
Please do the advanced IMU calibration on a flat nonmetallic surface. Then when you are at the field complete a compass calibration. Power down the craft and when you power up make sure it is on a level surface and do not though it until it has completed its full startup sequence. See if that helps.
Site Sponsor
Old Nov 20, 2014, 12:25 PM
bellyache is offline
Find More Posts by bellyache
Wolcott, Colorado
Joined Apr 2005
H3 3D reset
I would think that this would work for the Non Phantom (standard) H3 3D gimbal.
bellyache is offline Find More Posts by bellyache
Discussion DJI Zenmuse H3-2D Gimbal vs Arris 2000 Gimbal Cookie28 Multirotor Talk 1 Aug 28, 2013 03:54 AM
Sold **OPTIONS UPDATED** AG500 H3 Gimbal and Hoverfly Gimbal Control Wingbreaker Aircraft - Electric - Multirotor (FS/W) 0 Aug 22, 2013 04:50 PM
Sold TPPACKS Crab, AG500 H3 Gimbal, Naza GPS, Hoverfly Gimbal Controller Wingbreaker Aircraft - Electric - Multirotor (FS/W) 2 Aug 17, 2013 11:12 AM
Sold TPPACKS Crab, AG500 H3 Gimbal, Naza GPS, Hoverfly Gimbal Controller Wingbreaker Aircraft - Electric - Multirotor (FS/W) 0 Aug 10, 2013 11:36 AM
Sold TPPACKS Crab, AG500 H3 Gimbal, Naza GPS, Hoverfly Gimbal Controller Wingbreaker Aircraft - Electric - Multirotor (FS/W) 2 Aug 07, 2013 02:48 PM
