Must-see — Scratch-Built Metal Masterpiece
Byron Townsend’s 1941 Chevy Pickup Pro Street Truck.
A radio controlled work of art!
I have been a diehard RC enthusiast for over thirty years and I am still being constantly amazed by fellow hobbyist’s ingenuity and building ability to create completely unique one-off custom RC creations. With that said, there are rare times where I discover a vehicle that is a true standout and is nothing like I have ever seen before. This was definitely the case with Byron Townsend’s extraordinary, all-metal, scratch-built, 1941 Chevy Pickup Pro Street Truck.
ABOUT THE BUILDER
Byron Townsend lives in Australia and at 23 years old, is already quite gifted with metal fabrication and welding. He started modifying RC vehicles back in 2010 when he decided to tweak the suspension on his 1/5-scale rock crawler which quickly escalated into transforming the truck into a King of the Hammers-style Jeep constructed of aluminum. Once this truck was completed he moved on to another 1/5-scale that was a replica of a full-size Nissan Patrol GQ off-road truck and again he used all aluminum.
Before his next build, Byron purchased a TIG welder and taught himself how to weld stainless steel. The first project was TIG welding 3/16 stainless steel tubing to create a roll cage for a 1/10-scale drift car. Although he found it to very difficult, he also discovered how much he liked the polished look of the stainless steel mixed with the beautiful discoloration of the metal around the welds he made.
These projects instilled in him valuable lessons on fabricating with metal. Like being able to predict how the metal will react to the heat from the welder. They also led Byron to outfit his workshop with some cool tools like a lathe, TIG welder, a bench mounted sheet metal nibbler, drill presses and a variety of hand tools.
ABOUT THE BUILD — 1941 CHEVY PICKUP PRO STREET TRUCK
Byron’s constant source of inspiration has been the full-size automotive world where he would draw upon different genres of automotive engineering and from motorsports to ignite his creative juices. Segments such as Off-Road Racing, Drifting, Hot Rods and especially events like King of the Hammers. It was when he discovered Hot Rodding and Pro Street-style drag cars that triggered the concept to build the truck you see here, a scratch-built, all-metal 1/10-scale 1941 Chevy Pickup truck.
BYRON’S BUILD GOALS:
  • Design and build a Pro Street-style boxed chassis
  • Scratch build as much of the truck as possible
  • No time constraints for when the truck should be completed
  • Make the truck sit as low as possible
  • Fabricate the chassis to loop up and over a rear solid axle
  • Use an aluminum solid rear axle with coil over shocks and 4-link suspension setup
  • Machine wheels from solid billet aluminum with the rears larger than the front to achieve the Pro Street look
THE TRIPLE STACK MOTOR SYSTEM
Once Byron had the chassis and suspension figured out for this special truck, he began to brainstorm what the motor would be. He did not want a run-of-the-mill electric RC motor setup. It had to be unlike anything else out there and replicate a blown and injected big block V8 engine. His solution was downright ingenious.
After many sketches on paper the Triple Stack was born. Byron realized that he could build a motor plate in the shape of a V8 engine and then mount three HPI Firebolt 15T 540-size brushed motors to it. The ultra-cool part of this design was that he was able to incorporate a supercharger-style belt to run from the top motor while pinions are used on the lower two motors. The belt from the top motor spins a pulley that is attached directly to the spur gear and the pinions from the lower motors mesh with the spur gear which is mounted to an output shaft that runs out the back of the motor to drive the rear axle. Byron used Mod 1 steel cut gears with 19-tooth pinions and a 39-tooth spur gear. The pulleys that the belt rides on were all custom machined by Byron. The finished motor is very trick looking, especially with the faux blower mounted on top.
AXLES, WHEELS & TIRES
Following in the footsteps of a typical full-size Pro Street vehicle, Byron went with a 2WD drivetrain where just the rear wheels are driven by the electric motors. The all-metal axle was one of the items he did not fabricate and chose to simply pick up a billet aluminum SCX10 axle from Integy. It is attached to the chassis frame rails with a 4-link setup that is damped by aluminum-bodied, oil-filled shocks. Again, in keeping with the Pro Street theme, the front uses an I-Beam axle that was inspired by a 'Hot Rod' theme and used a perpendicular, inverted leaf spring for suspension.
The nice-looking, 5-hole wheels were machined from billet aluminum by Byron on his lathe. Just as you would find on a real Pro Street truck, Bryon gave the rear wheels a larger diameter and width. A standard rubber treaded tire is used for the front, but for the rear he gave the ’41 RC drift style wheels which he machined himself from Polypropylene plastic.
ELECTRONICS
The electronics are nicely hidden out of sight on the custom ’41 Chevy. The box mounted at the rear of the chassis, which resembles a full-size fuel cell, stows two 2S 2200mAh LiPo battery packs which are wired in parallel to provide more runtime. Wiring can be hard to keep hidden especially when electronic components are positioned far from each other on a chassis. For Byron, this was a piece of cake and a beauty of his all-metal design. Since the frame rails are boxed structures, he was able to run the wires from the battery packs through the frame rails and to the speed controls located in the cab of the truck. And yes it is speed controls in plural; three HPI SC-15 speed controls, one for each motor. A bench style seat became the perfect spot to mount the bank of speed controls along with the receiver. All three speed controls are run from one channel on the receiver via a Y-connector. To provide cooling to the electronics in the bench seat structure, Byron added a series of cooling holes. The steering is actuated by a Towardpro servo to direct the front tires. It is mounted on the driver’s side floor with a turnbuckle link that connects to the steering arm for the wheels.
1941 CHEVY PICKUP BODY
The stepside 1941 Chevy Pickup body is awesome-looking and is the feature that lets onlookers know immediately that this is a special RC truck. Byron hand hammered the entire body from .9 mild steel sheet metal and joined it all together with his TIG welder. He really nailed the look of the full-size ’41 Chevy, especially the front end with its recognizable giant front grille, fender mounted headlights and even the side intake vents for the engine compartment.
WRAP UP
After four months of work the truck was completed. Byron told me that he feels he successfully met his goals and is very happy with the final results. When he set out to build this Pro Street-style truck, he wanted something that was really unique and to be something that would showcase his skills and passion for metalcraft. The TIG welder, the use of metal and Byron’s skill definitely gives his ’41 Chevy Pickup a very unique and timeless quality. It is no wonder that Byron calls his builds “Rolling Works of Art”.
Old May 21, 2014, 01:45 PM
Jim T. Graham is online now
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
Awesome.
Jim T. Graham is online now Find More Posts by Jim T. Graham
Administrator
Old May 21, 2014, 01:52 PM
tntpoof is offline
Find More Posts by tntpoof
Joined Aug 2012
Great.. try using a tig welder ..
tntpoof is offline Find More Posts by tntpoof
Reply With Quote  (Disabled)
Old May 21, 2014, 02:07 PM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Nice job, and well presented.
SoloProFan is offline Find More Posts by SoloProFan
Old May 21, 2014, 06:17 PM
Flying glass is online now
Find More Posts by Flying glass
obey gravity, it's the law
USA, IL, Rockford
Joined Nov 2005
Wow, that is awesome. Incredible skill and style and so young and self taught. Can't wait to see what he does next
Flying glass is online now Find More Posts by Flying glass
Old May 21, 2014, 07:39 PM
fastmax is online now
Find More Posts by fastmax
FPV FTW
fastmax's Avatar
United States, MI, Goodrich
Joined Nov 2007
Absolutely amazing! That has got to be the coolest RC truck I have ever seen.
fastmax is online now Find More Posts by fastmax
Old May 21, 2014, 09:57 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
That is pretty damn cool Paul, thanks for sharing the article!
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old May 21, 2014, 10:09 PM
sippy is offline
Find More Posts by sippy
Joined May 2011
+1 and whats that sitting on the trailer being towed by the '41?
sippy is offline Find More Posts by sippy
Old May 22, 2014, 12:48 AM
Arabology is offline
Find More Posts by Arabology
Lebanon, Beirut
Joined Apr 2014
amazing
Arabology is offline Find More Posts by Arabology
Old May 22, 2014, 09:05 AM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Good call with the pinup poster above the shop bench.
PiperCub49 is offline Find More Posts by PiperCub49
Old May 22, 2014, 04:09 PM
Paul Onorato is offline
Find More Posts by Paul Onorato
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
I am glad you guys really like Byron's build. I knew as soon as I saw it that I had to share it with you guys.
The truck sitting on the trailer is another scratch-built project truck he built before the '41 Chevy. He calls it The Fully Welded RC Drift Ute. I attached some pics of that truck in this post.
And 'Ute' is Australian for 'Utility Truck'.
Had to fix that, so she is now gone, sorry.
Paul Onorato is offline Find More Posts by Paul Onorato
Old May 22, 2014, 09:16 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Dang...that is awesome!
electricrc68 is offline Find More Posts by electricrc68
Old May 23, 2014, 03:54 AM
pecanpatch is online now
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Very talented Kid..... He will move on to full scale stuff and be very successful....
Nice resume'
pecanpatch is online now Find More Posts by pecanpatch
Latest blog entry: 6th Annual South Eastern FPV...
Old May 25, 2014, 02:36 AM
rawy is offline
Find More Posts by rawy
e-powered foam
rawy's Avatar
swiss watch makers area
Joined Dec 2002
Amazing Job !
thanks for sharing
rawy
rawy is offline Find More Posts by rawy
Old May 25, 2014, 03:00 PM
Matthew Shane is offline
Find More Posts by Matthew Shane
Matt .
Matthew Shane's Avatar
New Zealand, Manawatu-Wanganui, Whanganui
Joined Mar 2009
WOW - Now thats cool .
Matthew Shane is offline Find More Posts by Matthew Shane
Cool Must see, indoor glider tow, ending is hilarious! RcAirplaneNoob Scratchbuilt Indoor and Micro Models 9 Nov 18, 2013 02:21 AM
Discussion Must-see video: SpaceX Grasshopper rocket makes a half-mile hop f86esabre FPV Talk 3 Oct 14, 2013 02:15 PM
For Sale Futaba Transmitters For Sale!! JUST $5!! Must SEE!! olivazane1 Aircraft - General - Radio Equipment (FS/W) 0 Sep 19, 2013 10:15 PM
Sold Harley Riders MUST SEE MIKEYOUR Non R/C Items (FS/W) 0 Sep 19, 2013 02:03 PM
Cool All Scratch Builder Must See This r/c junkie Slope 3 Sep 01, 2009 05:22 AM
