Old Apr 03, 2004, 10:39 PM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
Sig Riser 100 electric conversion
There was an article in Sailplane & Electric on converting a Sig Riser 100 to electric. In the article the author stated that the kit was very good. Can anyone confirm this?
John Gallagher is offline Find More Posts by John Gallagher
Old Apr 04, 2004, 06:00 PM
Ed Franz is offline
Find More Posts by Ed Franz
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Could you tell me what month and year that article was from?
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Apr 04, 2004, 10:59 PM
Lindenwold, NJ, USA
Joined Dec 2000
February, 2001
Old Apr 05, 2004, 01:28 PM
SoarNeck is offline
Find More Posts by SoarNeck
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
I've built two over the years, and I'd say that it was very good. The thicker parts have to be cut out of printed stock, but there are only about 8-10 if I remember properly.
The model builds up very nicely, and makes a great training sailplane, but it is probably a bit overdesigned for someone who knows what they're doing on the flying side of things.
Does that help?
SoarNeck is offline Find More Posts by SoarNeck
Old Apr 05, 2004, 01:38 PM
paulcarnes is offline
Find More Posts by paulcarnes
Alamogordo, NM
Joined Aug 2003
Re: Sig Riser 100 electric conversion
Mine is almost ready to cover and was a very comfortable build. I did use my disk sander on the nose block and a scroll saw on the wing tips but otherwise it was all done on my 2'x4' bench in the weekend house (where the carpets are)
paulcarnes is offline Find More Posts by paulcarnes
Old Apr 05, 2004, 09:03 PM
Lindenwold, NJ, USA
Joined Dec 2000
Does that help?
Do you mean it's designed stronger than it needs to be for someone who is not a newbie?
I'm not looking for a training glider and do intend to convert it to electric and would probably try to lighten it in any way I can. The most obvious place to start would be replacing the heavy tail pieces (mentioned in the article). Since I will not be winching it, I can use lighter covering in the wing tips and tail.
I've heard some negative comments about Sig kits including the 2m Sig Riser and just wondered about the quality of this kit.
thanks to all
John
Old Apr 06, 2004, 01:31 PM
SoarNeck is offline
RCGroups Author
SoarNeck's Avatar
Calgary, Alberta
Joined Nov 2001
Yes, it would be overdesigned for someone who isn't new (ply fuse, heavier tailfeathers and wingtips etc). That said, when I was considering adding a RES model to my fleet a couple of years ago, I seriously considered building a third Riser 100! I went with a Paragon since I could get the kit more inexpensively (and for the extra span).
Nothing wrong with the quality of the Riser - I'm primarily a scratch-builder, so I'm picky about what kits that I'm willing to build when I'm feeling lazy
Old Apr 06, 2004, 08:36 PM
Alamogordo, NM
Joined Aug 2003
February, 2001
So what motor/battery/prop setup did they use?
Old Apr 07, 2004, 09:54 AM
Lindenwold, NJ, USA
Joined Dec 2000
Magnetic Mahem, master airscrew 3.5:1, MA 15x12 folder
Old Apr 07, 2004, 11:17 PM
Alamogordo, NM
Joined Aug 2003
I'm looking forward to flying the Riser 100. Here's a shot of My Riser 2m returning from an hour + flight.
Sig Riser 100 chris dodge Electric Sailplanes 11 Feb 04, 2015 04:56 AM
Sig Riser 100 Rob Nelson Thermal 13 May 28, 2005 11:55 PM
F/S: Sig Riser 100 Jim Carlton Aircraft - Sailplanes (FS/W) 2 Dec 24, 2002 12:32 AM
WTB NIB SIG Riser 100 J Bergsmith Aircraft - Electric - Airplanes (FS/W) 3 Apr 02, 2002 12:39 AM
Sig Riser 100 NIB soar-iowa Aircraft - Electric - Airplanes (FS/W) 0 Feb 12, 2002 09:09 AM
