Old Apr 03, 2004, 06:49 PM
RapidRaptor is offline
Find More Posts by RapidRaptor
RapidRaptor's Avatar
Wilsonville, OR
Joined Jul 2002
New Scorpio Build and Maiden Flight
Today brought the maiden flight for my new Scorpio. What a blast. Goes straight up accelerating until it's a speck in 10 sec and I could detect no flex in the wing even pulling fairly hard in some high G turns. This baby is a keeper!
Here are the specs:
Hacker B50 6S
Hacker 105 OPTO ESC
RFM 16x16 narrow
10x GP3300
360 mAH Rx batt
With a fresh charge but cool batt pack pulled 89 amps. Will check it again with batteries in the 50-60C range.
RapidRaptor is offline Find More Posts by RapidRaptor
Old Apr 03, 2004, 06:50 PM
Wilsonville, OR
Joined Jul 2002
Bottom view
Here's the bottom
Old Apr 03, 2004, 06:52 PM
Wilsonville, OR
Joined Jul 2002
Motor
Motor
Old Apr 03, 2004, 06:53 PM
Wilsonville, OR
Joined Jul 2002
Helmut Meyer Spinner
Nice "Carbon" look from a plastic spinner
Wilsonville, OR
Joined Jul 2002
Spinner matches fuselage perfectly
Old Apr 03, 2004, 06:54 PM
Wilsonville, OR
Joined Jul 2002
Wing harness
Here's the Multiplex plug for the wing. Thanks Dieter for the tip regarding wiring the 4 servos
Old Apr 03, 2004, 06:55 PM
Wilsonville, OR
Joined Jul 2002
Aileron linkage
Old Apr 03, 2004, 06:56 PM
Wilsonville, OR
Joined Jul 2002
Battery pack
Old Apr 03, 2004, 06:57 PM
Wilsonville, OR
Joined Jul 2002
Elevator control horn and routed area of vertical fin to accomodate full deflection
Old Apr 03, 2004, 06:59 PM
Wilsonville, OR
Joined Jul 2002
Inside fuselage. The ESC is mounted with velcro for easy in and out of battery pack. The Rx battery and Rx are mounted behind the wing saddle.
Old Apr 04, 2004, 10:58 PM
tic is offline
tic
Find More Posts by tic
tic
thunderscreech
tic's Avatar
United States, MI, Gaylord
Joined Dec 2000
I had to do a little routing of the vertical stab on mine as well but not near as much and I made it round and smooth.. sure wish I had a digital camera... I am proud of the way it turned out.... Dive your scorpio straight down from 1000 feet and do a pylon turn... you WILL see the wing flex!....
tic is offline Find More Posts by tic
Old Apr 05, 2004, 12:49 AM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Yup.
It's a nice plane though. I assembled one for a friend (notice I didn't say "built") and got to fly it as a benefit. Not quite as fast as an Avionik, but good enough for me.
-David
davidfee is offline Find More Posts by davidfee
Old Apr 05, 2004, 08:48 AM
96S14 is offline
Find More Posts by 96S14
96S14's Avatar
Calgary, Alberta, Canada
Joined Oct 2002
Re: New Scorpio Build and Maiden Flight
You'll be blown away when the cells are hot. My Plett pulled 91A with that prop at room temp, and 125A at 60 DegC. That's a good deal more watts (probably about 350W extra or so...not insignificant!!!)
Let us know how it goes. Looks like the Hacker 6S is almost as hot as the Plettenberg F5F drive. As for efficincy, I don't know who gets the nod (hopefully the Plett as it's almost twice as much dough )
Ryan
96S14 is offline Find More Posts by 96S14
Old Apr 08, 2004, 02:28 PM
GoodTill is offline
Find More Posts by GoodTill
"HE CRASHES"
GoodTill's Avatar
Hasbrouck Hts, New Jersey , United States
Joined Oct 2000
Aileron linkage
I personally would like to see an all metal clevis on the ailerons and a Z bend at the servo. You want the to be as slop free as possible. Any slop will translate into flutter at the speed the plane can achieve.
GoodTill is offline Find More Posts by GoodTill
Old Apr 08, 2004, 07:25 PM
mauiguy99 is offline
Find More Posts by mauiguy99
mauiguy99's Avatar
Kahului, Hawaii, United States
Joined Jul 2003
Where did you get your batteries? or did you buy ready made packs?
mauiguy99 is offline Find More Posts by mauiguy99
Discussion Scorpio FW190 Maiden Flight Report! mrebman Electric Warbirds 4 Sep 06, 2006 08:32 PM
GWS Tiger Moth build and Maiden flight. ib456 Beginner Training Area (Aircraft-Electric) 25 Oct 17, 2005 02:19 PM
Tiger Moth 400 Build and Maiden Flight review AirWarriorBelgy Parkflyers 180 Aug 16, 2004 02:23 PM
new to me zagi...maiden flight help asjeep Beginner Training Area (Aircraft-Electric) 5 Feb 10, 2004 04:13 PM
New Zagi almost done! Ready for maiden flight! Crete1 Foamies (Kits) 1 Sep 05, 2001 10:35 AM
