Old Dec 26, 2001, 02:14 AM
rtideas is offline
Find More Posts by rtideas
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
Saw the new Ripmax f-16 at the LHS - any good?
My local hobby shop had the Ripmax F-16. Is it a good plane? What type of batteries? Can it use 600AE Zagi batteries? Is it a tough plane?
I'm quite tempted. I have to pick up some balsa for skis and I might just have to make a post-xmas purchase.
rt
rtideas is offline Find More Posts by rtideas
Old Dec 26, 2001, 11:19 AM
rtideas is offline
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
Has anyone seen this beastie or own one?
rt
Old Dec 26, 2001, 03:48 PM
mtayl is offline
Find More Posts by mtayl
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Looks interesting on the web page http://www.ripmax.com/ProductFrames/A-K10802.html
The page claims that the EDF gives you 400g of thrust and is included in the kit. How much did they want for the entire kit?
mtayl is offline Find More Posts by mtayl
Old Dec 26, 2001, 04:25 PM
John E is offline
Find More Posts by John E
Bristol, England
Joined Aug 2000
No, Ripmax don't appear to have the Kyosho F16 any more (but if anyone knows where there might be one - I could be interested)
It's this one:
http://www.ripmax.com/ProductFrames/A-ARTF6002.html
I looked in the box at the LHS and thought it was way too flimsy for me, though a friend who is an indoor specialist has got one and it should be nearly ready by now, I'll try to give him a call.
Regards, John
John E is offline Find More Posts by John E
Old Dec 26, 2001, 04:26 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
mytal, that link is to the Kyosho F-16 that Ripmax imports into the UK. I think the F-16 that he really means is this other, small foam F-16 with 2 small pusher motors on the trailing edge of the wing.
Look at:
http://www.ripmax.com/FS_AircraftEPScaleSport.html
I don't think rtideas saw a Ripmax labled Kyosho F-16 in the US, but he might well have seen the other little foam F-16, which I think is a Ripmax exclusive.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 26, 2001, 04:51 PM
rtideas is offline
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
Nope, the smaller 280 speed foamie. My buddy had the Kyosho.
I was wondering about the little jet (pusher.)
rt
Old Dec 28, 2001, 08:05 AM
Trecker is offline
Find More Posts by Trecker
Ruhrgebiet NRW-Germany
Joined Sep 2001
@rtideas ,
Iīve flown the little foam F-16 a while ago .Instead of the two pusher Props , RIPMAX delivers it with a single speed300 Pusher .I used 7/600AE Battery wich fitīs good intoo the plane and the weight is OK.Itīs easy to handlaunch and quite fast for a little plane like this . She really looks nice in the sky and is easy to fly , but at full throttle she always wants to turn left, īcause of the torque the single pusher creates.All at all itīs a nice very good looking plane.
Trecker is offline Find More Posts by Trecker
Old Dec 28, 2001, 08:38 AM
rtideas is offline
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
Trecker,
Thanks. Would a gearbox be worth it? Or maybe I don't want to cut the top speed down.
Is there any way to counteract the torque?
Thanks again,
rt
Old Dec 28, 2001, 11:03 AM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Perhaps a small bit of right thrust to counter the torque would help.
Mikey-flies is offline Find More Posts by Mikey-flies
Old Dec 28, 2001, 01:33 PM
Trecker is offline
Joined Sep 2001
Forget the Gear īcause that means a bigger prop and more Torque . The Idea to work with right thrust is worse thinking about , but the problem is the motormounting .Originaly it is planned to glue the motor into a ring of wood .If you do so , you can build in a little counterthrust . But I wanted to test different motors , so I installed a tube with a slot atthe end where the motor is fixed in by a strap.Works fine , but I forgot to build in an angle to give it some counterthrust ...Perhaps i will do this the next time .As soon as the wind calms down , I want to test the F-16 with a C6/7 Estes Rocket Engine .This fits well into the tube ...
Old Dec 28, 2001, 02:21 PM
mtayl is offline
mtayl's Avatar
Boulder, CO USA
Joined Sep 2001
Cool idea. Don't forget about the ejection charge.
Old Dec 29, 2001, 10:09 AM
Trecker is offline
Joined Sep 2001
Thanks for the hint ! Otherwise I will see a Foamie snowing down in white and grey bits ....a brand new experience ***
New Product new f-16 at hobby people .net Mike_eee Foamy EDFs 3718 Apr 19, 2010 03:38 PM
FS- Lots of New stuff! Ripmax F-16 NIB, EPS300D, HS-81's, and ICS-300 esc- all new Etonic Aircraft - Electric - Airplanes (FS/W) 11 Sep 10, 2004 11:07 AM
NEW Built Never Flown Ripmax F-16 saint152 Aircraft - Electric - Airplanes (FS/W) 6 Nov 26, 2002 08:43 PM
Does anyone have any experience w/ the Ripmax F-16? phoneguy Foamies (Kits) 0 Apr 12, 2002 11:32 PM
New Ripmax F-16 sfrazee Foamies (Kits) 17 Oct 15, 2001 08:50 PM
