Old Apr 02, 2004, 08:47 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
AC prop adapters for 3.0 mm and 3.2 mm shafts
There seem to be lots of posts asking for info on prop adapters so, as a service, I thought I'd share with you the latest offering from Nippon Dave at www.aircraft-world.com which reached me by parcel post for $2.50 postage in exactly a week.
These little guys weigh less than 1g: the 3.0mm size is ideal for GWS IPS and EPS 300's, and for Microtex and Little Screamer motors: the 3.2mm size suits AXI 22xx/xx series. APC SF props fit perfectly on the conical "boss", GWS RS series are okay, but not as stable as the APC's, and GWS HD's don't really fit too well.
Here are three photos for your perusal (Microtex 20/5/18 is the 'model').
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 02, 2004, 08:50 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Prop adapter on Microtex - Duh! forgot the link in the initial post. These are called "AC Prop Saver 3D Wobbly AC-ADAPWOBB-30" - $3.60.
http://www.aircraft-world.com/prod_d...ac-propacc.htm
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Last one - with APC SF 8x6 prop fitted
Old Apr 02, 2004, 09:01 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I was looking at these trying to figure out how this was a prop adapter. The I saw the rubber band, and realized it was a prop SAVER..
..a
Old Apr 02, 2004, 09:09 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Sorry Andy - I'm usually the pedant here! But if one is using an APC SF prop, which would not normally fit directly on to a 3mm shaft, we are talking about a prop adapter as well as a prop saver, aren't we!
Cheers, Phil
Old Apr 02, 2004, 09:11 PM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
IPS are 2mm shafts so these wouldn't fit right?
Perfect for the microtex though thanks Dr. K.
LTChip is offline Find More Posts by LTChip
Old Apr 02, 2004, 09:13 PM
LTChip is offline
LTChip's Avatar
Helena, MT
Joined Feb 2003
Funny - I just noticed that your motor isn't red like mine.
Old Apr 02, 2004, 09:33 PM
ScienceGuy is offline
Find More Posts by ScienceGuy
United States, NY, Marion
Joined Sep 2001
The IPS shafts are 3mm so the 3.0s will fit. I just received 14 of these to go with some of the Microtex motors that should reach me any day. The 20/5/**s have a 3mm shaft while the 20/8/**s have a 3.2mm shaft.
By the way, my digital scale finds them to weigh 1.7 grams each with the screws included.
Hugh
ScienceGuy is offline Find More Posts by ScienceGuy
Old Apr 02, 2004, 09:53 PM
LTChip is offline
LTChip's Avatar
Helena, MT
Joined Feb 2003
cool
Old Apr 02, 2004, 10:53 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Dang, Hugh, your digital scale is better than mine. Mine only weighs in 2g intervals and whether I put the saver on by itself, or with the Microtex, it didn't register any change in weight! - I assumed the saver itself must be ~1g.
I'm glad I also got the 3.2mm version for the 20/8/18, which will be winging its way in my direction very soon - he says, hopefully, plaintively,............
Call me SOON to say you have your hands on them! And, Hugh, I'll take a second 20/8/18 (and one each of the prop savers:3.0 and 3.2) if you have spares.
Cheers, Phil
Old Apr 03, 2004, 01:02 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
I've got one of the 3.2mm versions on my Typhoon Micro 6. Found I needed to ream out both the GWS SF and the APC SF props I use but that isn't a problem. Nice, light and cheap too.
Dave
wildpalms is offline Find More Posts by wildpalms
Help! 3mm shaft prop designed for 3.17-3.2mm Biopraetorian Power Systems 5 Jan 31, 2006 10:08 AM
Wobbly Prop Adapters For 3-blade Props rcplanebuster Power Systems 0 Feb 24, 2005 12:16 PM
Prop Size for SmoothE with 350C & 2-cell LiPO ssTerry Parkflyers 14 Apr 14, 2004 02:59 PM
Bob Selman Designs Prop Adapters for GWS 4mm Bore Props Gordon Johnson Scratchbuilt Indoor and Micro Models 17 Mar 31, 2004 11:08 AM
Gunther prop adapter for 3.2mm shaft? bmiller Power Systems 1 Jul 26, 2002 11:49 PM
