Old Apr 01, 2004, 03:59 PM
Brycew is offline
Find More Posts by Brycew
Central Point, OR
Joined Sep 2003
Question
Phoenix 25 esc question
Quick question...
When I cut the throttle in my formosa (himax 2015 4100, 9x7 apc prop, gws "C" gearbox), the motor makes these very short...glitches.
After I cut the power, the prop sort of spins freely. As I nose down and pick up gliding speed, it is almost as if the motor begings to cut in and out in VERY short bursts. It is like the brake may be trying to stop the prop, however, the wind flow is enough to make it try to spin.
Has anyone else noticed this happening?? I am not really familiar with the brake setup, and the esc is set to recommended setting.
Thanks!
Brycew is offline Find More Posts by Brycew
Old Apr 01, 2004, 04:47 PM
MailOrderGuy is offline
Find More Posts by MailOrderGuy
Sir Buildsalot
MailOrderGuy's Avatar
Stockbridge, GA
Joined Nov 2002
I would disable the brake, using the brake with those GWS plastic GB's is not recommended.
The himaxx motors are designed to free spin without current.
The esc is detecting this (free spin) and thinks it needs to apply brake, hence the "motor begings to cut in and out in VERY short bursts"
MailOrderGuy is offline Find More Posts by MailOrderGuy
Old Apr 01, 2004, 06:33 PM
Brycew is offline
Central Point, OR
Joined Sep 2003
MailOrderGuy,
Thanks for the input. I thought that it probably had something to do with the brake setup. I will disable the brake and give it a try!!
Bryce
Old Apr 01, 2004, 10:29 PM
mjdoz is offline
Find More Posts by mjdoz
Australia, QLD, Bongaree
Joined Nov 2003
On the older software versions the CC BL ESC will sense the position of the motor by momentarily switching on the brake while it is windmilling. This has been discussed on the CC board and I beleive that CC were going to remove it from future software releases. Not sure if that has already happened or is still to happen.
Michael
mjdoz is offline Find More Posts by mjdoz
Old Apr 02, 2004, 11:39 PM
manito is offline
Find More Posts by manito
Comer GA
Joined Apr 2004
I'm having a similar problem in my Pelikan Mig-35 with a CC25 and an Aveox 27/13/4 turning an APC 6x4. It's powered by a Kan 1800mah 8-cell. Normally, it will go like mad right from the start and as long as you don't throttle back too far, no problem. But when I throttle back and, heaven forbid, cut the throttle- the motor begins to stutter and won't do anything but stutter when I throttle up.
I've got the brake off. I've tried lowering the cutoff voltage....same stutter, no go. Disconnscting and reconnecting the battery doesn't help.
The motor does seem to be getting pretty hot, though the esc and batt are not....
Any ideas?
manito
manito is offline Find More Posts by manito
Phoenix 25 ESC question BlueDevil Power Systems 1 Sep 09, 2005 12:51 PM
FS: Mega 16/15/4 & CC Phoenix 25 ESC rtucker Aircraft - Electric - Airplanes (FS/W) 4 Sep 02, 2003 01:43 PM
FS - Mega 16/15/5 w/ Castle Phoenix 25 ESC Will Chapman Aircraft - Electric - Airplanes (FS/W) 4 Aug 18, 2003 12:32 AM
phoenix 25 esc programming? Ryan Nau Power Systems 1 Jun 25, 2003 04:28 PM
FMA Rx, smallest 1.5" Azar ant. and a Castle Creations Phoenix 25 ESC. mars Parkflyers 10 Feb 10, 2003 08:02 PM
