Old May 06, 2014, 02:14 PM
Sirbo is offline
Find More Posts by Sirbo
Joined Apr 2014
Help!
New to FPV - Is this video quality normal?
Hi guys,
I'm trying to get into quadcopter FPV but I'm having a few signal quality and range issues with a 'starter' setup I've bought. At the moment both are powered by 300mAh 2S batteries.
This is my TX setup with my GoPro connected via an ImmersionRC connector (I think). I had to move a few of the wires around to match what instructions suggest. Wires are video + ground.
This is my RX setup. I've got it connected to my TV at the moment but the idea is once I'm happy with my TX I'll buy some goggles or monitor.
Here's a video showing my issues.
Poor FPV signal (0 min 30 sec)
  1. So what I'd like to know is have I done anything fundamentally wrong in terms of my setup.
  2. If I haven't then what can I do to improve the video quality and range?
I'm a complete FPV n00b so I'm sure I'm doing something wrong.
I bought the transmitter and receiver as a set but I think these are the details I could find online.
Flysight 5.8G TX5802
Flysight RC306
Sirbo is offline Find More Posts by Sirbo
Last edited by Sirbo; May 06, 2014 at 03:23 PM. Reason: Added links to the product pages.
Old May 06, 2014, 03:00 PM
fryfrog is offline
Find More Posts by fryfrog
United States, CA, Mountain View
Joined Sep 2010
I'm only just getting started with FPV myself, so take my observations at low value.
Your picture clearly says both vTX and vRX are on channel 7, but the signal looks like it is close but not quite there. One of my bench tests had a camera and transmitter combination that would start to get too hot after 10-15 minutes and it would actually hop up by .5 or .75 of a channel. It'd go away on channel X, but be almost useful on channel X+1. Weird.
Could it also be as simple as a high powered vTX that is just too close to the vRX? Have you tried moving the two of them further apart?
I assume you don't have any spare parts, but I'd just start replacing one thing at a time and see if it made any difference. Probably starting with the cheapest, easiest things. Maybe try using the stock rubber duck antennas that both items surely came with, since it'd be free?
Did you maybe run the vTX w/o an antenna hooked up? That can be super bad for it, depending on the type. A good thing to avoid.
fryfrog is offline Find More Posts by fryfrog
Old May 06, 2014, 03:01 PM
TheSwedishRatboy is offline
Find More Posts by TheSwedishRatboy
I WANT food...I NEED to fly
TheSwedishRatboy's Avatar
Sweden, Skåne County, Malmö
Joined Dec 2013
Hi and welcome to a very exciting hobby!
I'm not an expert on this particular gear, but a couple of things come to mind.
1. 2s? Most gear run on 5,5 or 12v. If it runs of 12v you should use 3s. I've had similar results when a video tx was powered with to low voltage. (It's always good to include a link to the particular products you bought)
2. Have you tried switching the video and ground wires?
3. Are you sure you are on the same channel? Have you tried other channels?
Hope one of these things can help. Good luck!
TheSwedishRatboy is offline Find More Posts by TheSwedishRatboy
Last edited by TheSwedishRatboy; May 06, 2014 at 03:05 PM. Reason: Frog beat me to it
Old May 06, 2014, 03:22 PM
Sirbo is offline
Joined Apr 2014
Thanks for the replies so far.
Just tried that and it seems to be the same. Could it be that I'm trying it all out inside?
I made sure not to do that after watching on of the FliteTest videos on FPV.
I had actually thought that it could be a voltage issue but both say they work on 2S or 3S and I only have 2S with jst connectors so if that could be the issue then I'll happily buy some 3S batteries to test.
I've tried all sorts of different wire combinations and everything get worse than it is now. I have tried other channels and it's all either the same or worse.
I bought the transmitter and receiver as a set but I think these are the details online.
Flysight RC306
Old May 06, 2014, 04:46 PM
CapBlack is offline
Find More Posts by CapBlack
Joined Jul 2012
The black cable from the gopro are not in the right position che the manual of the transmitter you need to move to the first position on the another side.
Hope that help
CapBlack is offline Find More Posts by CapBlack
Old May 06, 2014, 05:19 PM
Sirbo is offline
Joined Apr 2014
Hope that help
Ok I will try that tomorrow. These are the instructions. I assumed NC meant ground.
Old May 06, 2014, 07:06 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
NC means "No Connection".
- is ground.
Daemon is online now Find More Posts by Daemon
Old May 06, 2014, 07:13 PM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
Negative (-) should be your ground position.
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old May 06, 2014, 08:19 PM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
I think that NC is where the left speaker channel is supposed to be. I'm surprised you actually got a signal.
Hajile is offline Find More Posts by Hajile
Old May 06, 2014, 10:50 PM
CapBlack is offline
Joined Jul 2012
this maybe help you
Description:
Old May 07, 2014, 10:22 AM
iwcai is offline
Find More Posts by iwcai
Joined Jan 2011
Looks like some multipathing going on. Try a patch antenna on receiver.
iwcai is offline Find More Posts by iwcai
Old May 07, 2014, 11:17 AM
Sirbo is offline
Joined Apr 2014
Firstly, thanks for all the replies.
Secondly, I've had some progress.
I had a proper read of the instructions and after checking both transmitter and receiver I noticed they were on different bands.
After changing the band so they matched the signal is definitely better and more 'locked on'. I can walk around my living room without losing signal. (something I couldn't do before). It's still a bit shaky though but I wonder if that's down to something like the 2S batteries I'm using. (low voltage?)
I've also adjusted my wires to match what was suggest above but that seems to have given the video a strange rainbow effect.
Rainbow video
FPV Issues - Progress (0 min 19 sec)
Any ideas?
Old May 07, 2014, 12:03 PM
Bodywerks is offline
Find More Posts by Bodywerks
Nick Radle
Bodywerks's Avatar
United States, AZ, Tucson
Joined May 2004
Try running just the signal wire into the tx, no ground connection. Since you're powering the camera separately you shouldn't need the ground.
Bodywerks is offline Find More Posts by Bodywerks
Old May 07, 2014, 12:23 PM
Sirbo is offline
Joined Apr 2014
Without the ground cable there's no display on my TV at all.
Could it be down to the GoPro itself? When I build my FPV quad I don't think I'll use the GoPro so it might be a complete red herring.
Old May 07, 2014, 01:03 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
From the behavior of the two video examples I suspect the vTx & vRx RF band settings still do not match. So **check again** and confirm that the vTx and vRx have identical band letters (A-F). If the band and channel settings all match then there is a chance you have a bad vTx and/or vRx.
With all the testing the battery packs may have discharged to an unacceptably low voltage. I suggest you confirm the voltage is correct using a voltmeter while the battery packs are powering the vTx and vRx.
On early versions of the Flysight vTx the "NC" pin was unexpectedly connected to GND (Power-). But that has been corrected and now it is a floating (unconnected) pin. What I mean is that on your particular transmitter a continuity tester or ohmmeter should show that NC, Power Output-, and Power Input- are all connected together. But regardless, to remain compatible with newer Flysight transmitters (in case you get a new one someday) you should use Power Output- when connecting the camera's ground.
That's expected. The camera's video signal requires a return path, so two wires are required.
- Thomas
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Discussion Best FPV Video Quality - For recording MikeMSD Multirotor Talk 5 Mar 17, 2016 11:49 AM
Discussion FPV - Improving Video Quality MikeMSD Multirotor Talk 36 Feb 16, 2014 10:14 PM
Discussion FPV Video Quality - Flickering Video MikeMSD Multirotor Talk 4 Feb 02, 2014 08:40 PM
For Sale Brand NEW RC Head Tracking High-quality ALL-IN-ONE wireless video goggle FPV kit syst John li FPV Equipment (FS/W) 1 Aug 04, 2012 02:02 PM
Discussion New To FPV, Is This Normal? wrex450 FPV Talk 2 Apr 20, 2009 10:30 AM
