Old May 05, 2014, 07:56 PM
bayareaheli is offline
Find More Posts by bayareaheli
quit crying start flying
bayareaheli's Avatar
United States, CA
Joined Mar 2013
New Product
The Nemesis 240mm Mini folding FPV Quad (G10 and Carbon Fiber) Thread
Nemesis Build Log by ezikiel12: http://www.rcgroups.com/forums/showthread.php?t=2200882
Thanks bro
Introducing the New Mini Nemesis a 240mm mtm diagonal mini quad. This frame was designed and engineered from the ground up to be highly versatile while retaining the heart and design language of the original BAH series. Created in the USA with customer feedback in mind!
QUAD status: First batch of frames have been delivered.
Nemesis Assembly Assembly Manual Rev_1.2 Posted
Photos courtesy of Justin aka ezikiel12
Thanks Again Justin!
Available in both G-10 and 3k twill weave Carbon Fiber
Get it here:
-(Buzz Hobbies) http://www.buzzhobbies.com.au/index....te=common/home
-(R-Squared market) Available for Pre order https://squareup.com/market/rsquared-innovations
-(R-Squared Site) Nemesis is now available for pre order http://www.rsquared-innovations.com/frames
-(USA Seller) Quadrysteria http://www.quadrysteria.com/nemesis-240-mini.html
-(Asia/Europe) Drone Matters http://www.dronematters.com/
-(USA Seller) GetFPV http://www.getfpv.com/nemesis-240-mi...bon-fiber.html
-(USA Seller) GetFPV http://www.getfpv.com/nemesis-240-mi...opter-g10.html
-(USA Seller) Multirotor Superstore http://www.multirotorsuperstore.com/...-fpv-quad.html
-(USA Seller) Amain Hobbies http://www.amain.com/product_info.ph...opter-Airframe
-(USA Seller) TMARC1 Hobby https://tmkarc1hobby.com/pre-order-n...v-quad-3k.html
-(USA Seller) TMARC1 Hobby https://tmkarc1hobby.com/pre-order-n...r-and-g10.html
Pricing (final):
G-10: $121
Full Carbon Fiber 3k twill weave: $144
Weight
G10 (149g)
CF (128g)
Standard Frame features:
-Vibration free separated Clean and Dirty sections for smooth video recording
-Instantly fully inward fold-able quad for easy pack and go and crash protection
-Lightweight frame design but still able to take hard hits
-Unique custom folding and extending arm mechanism allows both 5" and 6" props
-4 predefined flight configurations for wings, X compact, H compact, X extended, Superman
-Alignment/locking holes for H in 5", X in 5", X in 6"
-Unique ability to dirty or clean mount your flight controller (supports 45mm and below FCs)
-2 Stage Bobbin travel limiter
-Built in Mobius/GoPro1-3+ mounts integrated into frame and accessories
-Dedicated Board Camera and rear bulkhead plates
-Accessory Shelf with 3 mounting positions, (you can use up to 3 at once)
-Extension plate for mounting Mobius, GoPro, InfinityCam One, CCD flight cam out front, bolts in 2 locations
-Multiple SMA jack mounts including a unique rear bulkhead mount
-Extended lower front spoiler on dirty section for frontal crash impact absorption
-Intelligent Electronics management: tons of options for mounting electronics including Buzzers, Strobes, leds, voltage readers, OSD, access Mobius buttons when mounted inside frame, etc
-Clean wiring, all ESCs mount inside center frame as well as flight controller, fits Bt408 mini PDB perfectly inside
-Battery can be top mounted or mounted inside the clean section
-Integrated mounting points (2 locations) for Landing Gear/Standoffs
-Optional upgrades TBA later
The standard frame kit includes:
-1 Top Clean Plate (1mm)
-1 Bottom Clean Plate (1mm)
-1 Top Dirty Plate (1.5mm)
-1 Bottom Dirty Plate (1.5mm)
-4 Adjustable extending Arms (3mm)
-1 CCD Camera Plate (1mm)
-1 Rear Bulkhead Plate (1mm)
-1 Stacking Accessory Shelf/Plate (1mm)
-1 Camera front Extension Plate (1.5mm)
-All hardware required to assemble frame
4 x M4x14mm (arms)
4 x M4 Nylock Nuts (arms)
4 x M2X10mm (Dirty Section)
4 x M2 Standard or Nylock Nuts (dirty section)
4 x High Quality Vibration Dampers
8 x M3 Standard Nuts (bobbins)
16 x M3x6 or M3x8 button head (clean section)
8 x M3x35mm standoffs (clean section)
4 x M2x3mm spacers (dirty section)
Recommended Equipment:
Motors: Sunnysk x2204 2300kv (3s), Tiger MN 1806 2300kv (3s-4s) , Cobra 2204 2300kv (3s), Cobra 2204 1960kv (4s)
ESC: Blue Series 12A (Simonk 05-13 FW), Turnigy plush 10A on BLheli
Prop: 2 blade 5030 Gemfan, 2 Blade 5 x 4 HQ Composite, 2 Blade 6030 HQ Composite
Flight Controller: Flip 1.5/Ez, Naze32 Acro, OP CC3D, KK2 (can also fit but large for a mini)
Camera: PZ0420 ccd, any bracket camera as well
PDB: bt408 Mini PDB (6g) w/ integrated video filtering
New spare parts will be cut here in the usa since i had to find a new suplier
Thanks for your support
Bay
bayareaheli is offline Find More Posts by bayareaheli
United States, CA
Joined Mar 2013
Some photos I managed to snap in a hurry tonight all I had was stiff 6" HQ 6x3 props so I threw them on there to show it in folded and fully extended configurations! More to come soon. --Drclawscat
Old May 05, 2014, 07:57 PM
United States, CA
Joined Mar 2013
Early Flight Videos of Prototypes
Open box video from snotlober on youtube
Nemesis Mini Quad: The Unboxing (6 min 6 sec)
Joe s chasing drift cars with the Nemesis
H.O. Motorsports drift event (11 min 3 sec)
Nemesis flight by Starvnmrvn playing with 2 blackouts Awdspider and Fotocasion
broken parts (4 min 14 sec)
flight by Joe559
Nemesis (4 min 39 sec)
Park Fly - Nemesis 240 Mini (9 min 9 sec)
Nemesis Crazy Wind Flight Nailed A Metal Pole :D (7 min 45 sec)
Coyote Point Nemesis 240 Mini Testing (3 min 41 sec)
Nemesis 240mm Mini Maiden 2nd Person View Fpv (4 min 55 sec)
United States, CA
Joined Mar 2013
another reservation
Old May 05, 2014, 07:58 PM
United States, CA
Joined Mar 2013
reserved for customer photos videos
United States, CA
Joined Mar 2013
reserved for additional content
Old May 05, 2014, 08:23 PM
Brainstorm is online now
Find More Posts by Brainstorm
Fly a LiPo a day...
Brainstorm's Avatar
United States
Joined Jun 2012
Reserved for much rejoicing about the 240mm BAH Stingray.
And for bugging the two Robs about the larger 350mm Stingray...
Seriously: Kickass, Bay and drclawscat! The fact that it can fit 6" props is what sets the BAH Stingray apart from all the other mini-H designs. If you don't appreciate why 6" props are a big step up from puny little 5" props, have a look at Soma's SunnySky X2204 2300kv Thrust Test Data. Not to mention the Tiger 2206 motors, which are even less able to live up to their full potential with 5" props.
Brainstorm is online now Find More Posts by Brainstorm
Old May 05, 2014, 08:31 PM
United States, CA
Joined Mar 2013
lmao bug the other rob more jk
soon soon soon the 350 we thought we could get them both out quick but was some sleepless nights just to get this one done
Old May 05, 2014, 08:43 PM
ezikiel12 is offline
Find More Posts by ezikiel12
ezikiel12's Avatar
United States, CO, Denver
Joined Mar 2013
ezikiel12 is offline Find More Posts by ezikiel12
Old May 05, 2014, 08:52 PM
Fly a LiPo a day...
Brainstorm's Avatar
United States
Joined Jun 2012
No worries at all, Bay! Especially not with the health woes you've just been through. Personally, I am still months away from building either a 240 or a 350. And if the 240 Stingray is any indication, the 350 (Giant Devil Ray? ) will be well worth the wait!
Old May 05, 2014, 08:53 PM
drclawscat is offline
Find More Posts by drclawscat
I like Spinning things
United States, CA, SF
Joined Jun 2013
Bug the other Rob with questions on the 350! Lol, but seriously, I just started the CAD measurements last night hehe
drclawscat is offline Find More Posts by drclawscat
Old May 05, 2014, 08:56 PM
the.ronin is offline
Find More Posts by the.ronin
masterless samurai
the.ronin's Avatar
United States, CA, Long Beach
Joined Feb 2013
In!
the.ronin is offline Find More Posts by the.ronin
Old May 05, 2014, 08:59 PM
masterless samurai
the.ronin's Avatar
Joined Feb 2013
Is that an m3 hole on the arms I can use for extended landing gears so I can belly mount the lipo?
Old May 05, 2014, 09:08 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
BayAreaHeli,
that list you gave for a mini is impressive!
Some questions:
1. Will it fit a 3s-2200mah Lipo for longer flight times?
2. or will the upgraded in 6" props with 3s-1500mah increase runtimes?
(pending we use the same 2000-2200kv motors everyone uses)
4-5min regular runtime must be improved.
Hope this mini Quad does well, it seems like you listened to the mini users
and you've accomplished here:-)
LexusFPV is offline Find More Posts by LexusFPV
Old May 05, 2014, 09:10 PM
Fly a LiPo a day...
Brainstorm's Avatar
United States
Joined Jun 2012
Even better, Rob! I was just teasing and do not plan any more bugging. Although I am sure others are chomping at the bit to size up to the 350.
I look forward to real-life pictures and video of the first BAH Stringray as well as many, many customer builds thereafter.
New Product BAH Mini H Foldable Quad - Made In USA bayareaheli Mini Multirotors 5581 Aug 16, 2016 08:12 PM
Discussion Mini-H 240mm all carbon fiber quad available Return2Flight Mini Multirotors 0 Apr 15, 2014 01:55 PM
For Sale BAH Mini H Quad - Carbon Fiber Frame (version 1) starvinmrvn Aircraft - Electric - Multirotor (FS/W) 2 Mar 04, 2014 03:49 PM
New Product BAH Mini H Fpv Quad bayareaheli Multirotor Talk 0 Oct 19, 2013 04:45 AM
