The Vixen F3J
The Vixen was designed by Daryl Perkins as a no compromise F3J model.
The Vixen is a cooperation between Daryl Perkins, Jiri Baudis, and SoaringUSA.
Soaring USA is the North American distributor of the Vixen. The kit by Baudis is complete with wing bags, ballast set, and wiring harness components.
Specs
  • CG - 110-112mm from LE.
  • Cruise - line up the aileron at the tip
  • Thermal - 3 degrees
  • Reflex/Speed - -1 to -2 degrees. -2 degrees for Zoom
  • Launch - +15 degrees (ish)
Mike Smith won the World Soaring Masters Flying VIXEN. Here is what Mike said about the comp...
I thoroughly enjoyed flying the Vixen in all that Muncie had to offer. I ran 40% of the available ballast in the crazy conditions where wind and lift were happening, and 20% for the active and moderately windy weather where sink had to be flown through quickly
5 time world champion Daryl Perkins;
"The Vixen was designed by Daryl Perkins as a no compromise F3J model. Everything about the Vixen was well thought out for the task. It was designed to be easy to build light, and to keep the weight out of the extremities - note the V-Tail and two piece wing. There is no joiner box structure or joiner weight at half span which reduces weight out at the tips. The section choices are designed to have a wide speed range, pull hard on tow, and slow down well for a slow controlled approach. Many of you will question the six servo wing - it must be flown to be believed! The control surfaces are quite short, enabling the use of very small and light servos and less prone to twist or flutter. The largest benefits here are in the landing circle and the ability to slow down, controllably, and work the clock for that last 10th of a second. F3J contests are won on tow, and in the LZ. The Vixen is optimized for both."
Check the Vixen out at Soaring USA.
There are no posts
Video "SEA VIXEN" flying under influence jofro Foamy EDFs 3 May 22, 2014 07:12 PM
Build Log 1.8M W/S Depron de Havilland Sea Vixen Scratchbuild Electriflier Scale Kit/Scratch Built 38 Nov 24, 2013 04:38 PM
Sold Durafly D.H.110 Sea Vixen Bobwheet Aircraft - Electric - Jets (FS/W) 0 Oct 27, 2013 08:47 PM
Sold Durafly DH110 Sea Vixen 69 mm Ducted Fan Jet MickeyD Aircraft - Electric - Jets (FS/W) 4 Sep 26, 2013 02:26 PM
