Old Mar 30, 2004, 04:16 PM
darthdrk is offline
Find More Posts by darthdrk
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
All new Bell 206 Jet Ranger fuse for Corona/LMH
I finally got this fuselage done. This is the newer LMH 206 Jet Ranger fuselage. Improvements: installation is easier, do not have to remove anything off the original stock setup. Fuselage seperates behind the rear passenger door, Make changing batteries in stock location easier and also to make electronic adjustments. More scalism better lines. With the older fuselage Corona owners would have had to make a minor rear crutch modification with the 206 Jet Ranger. The newer fuselage, there is no modifications required. My next project the Agusta 109/119 Koala is nearing completion.
darthdrk is offline Find More Posts by darthdrk
Old Mar 30, 2004, 04:31 PM
twguns is offline
Find More Posts by twguns
Indianapolis, IN USA
Joined Sep 2001
Looks good!!!
"Scalism"?????????
bigTim
twguns is offline Find More Posts by twguns
Old Mar 30, 2004, 06:16 PM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
more detail
Im adding more detail to mine. Added some detail to the air intake to particle seperator, added wire strike protection system, and added an antenna on the upper cowling. Also made cut outs for the exhaust stacks.
Old Mar 30, 2004, 11:16 PM
Xorb is offline
Find More Posts by Xorb
Edmonton, AB
Joined Nov 2003
two parts?
Darth,
Are these two halves (like the stock canopy) with a seam along the length of the fuse?
Darin
Xorb is offline Find More Posts by Xorb
Old Mar 31, 2004, 07:20 AM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
The main fuselage is actually four pieces. Two fwd halves and two rear halves. The halves are joined together by a seperate seam strip that is glued down the center on the inside of the the halves. Its a pretty simple construction. I might install some clear plastic for the side windows then again its warming up leaving the windows open helps with cooling the electronics.
Old Mar 31, 2004, 12:29 PM
Ian Dale is offline
Find More Posts by Ian Dale
Stockport, UK
Joined Sep 2001
This looks really good. Do you ship to the UK?
Ian
Ian Dale is offline Find More Posts by Ian Dale
Old Mar 31, 2004, 01:24 PM
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
I ship world wide
Old May 02, 2004, 10:03 PM
aeropuppy is offline
Find More Posts by aeropuppy
aeropuppy's Avatar
Joined Nov 2002
Converted mine this weekend
Just finished mine...now I just need to add some color
aeropuppy is offline Find More Posts by aeropuppy
Old May 03, 2004, 04:59 AM
nitro57 is offline
Find More Posts by nitro57
Chicago, IL
Joined Mar 2004
HI Darthdrk,
Would you be making any fuselage for Quick EP10? I'm looking for one that fits or that needs a little modifying to fit. Wonder if any of your LMH fuselage will fit. They look pretty sweet.
thanks,
n57 (Seng)
nitro57 is offline Find More Posts by nitro57
Old May 04, 2004, 03:59 PM
y_g is offline
y_g
Find More Posts by y_g
y_g
y_g's Avatar
Tel Aviv
Joined Mar 2004
Finished my conversion as well...
She's a real beauty. I followed the NYPD scheme out of the link you sent me.
y_g is offline Find More Posts by y_g
Old May 04, 2004, 05:11 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
More nice work Darth.
Moving over to the Scale forum.
Looks like Scale will be mostly EP though. We just don't get alot of IC action here.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Discussion T-rex Bell 206 Jet Ranger overhaul darthdrk Mini Helis 105 Apr 30, 2009 06:23 PM
Discussion Darth BCP/Cp2 (Micro) Heli Bell 206 Jet Ranger darthdrk Micro Helis 28 Dec 17, 2006 08:47 PM
Mini-Review THE BELL 206 JET RANGER V2 on T-Rex BY DARTH. GREAT JOB ! matthew james Mini Helis 16 Jul 13, 2006 01:21 AM
Sold Jet Ranger body for Corona 120 GrantL Aircraft - Electric - Helis (FS/W) 0 Jun 27, 2005 06:26 PM
FS: Jet Ranger fuse for ECO 8 w/decals, $80 Ben Diss Aircraft - Electric - Airplanes (FS/W) 0 Sep 10, 2001 07:02 PM
