Old Mar 30, 2004, 10:15 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
Why don't we hear much about GWS LPS systems ?
Many fliers are using the GWS IPS A gearbox 5.86/1 ratio. Approx 1 oz. weight.
I was curious why more are not using the LPS C gearbox. LPS RXC-C
Almost the same gearing 6.2/1, but 0.3 ounces lighter (0.7 oz. weight).
Even better, this same gearbox is available with a 4.8V motor (LPS RLC-C), which when propped down will safely run on 7.2 V (2 lipoly) to get significantly more power at approx. 3.5 Amperes max.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Mar 30, 2004, 08:37 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Martyn, I'm with you. Just before I graduated from IPS to larger motors, I bought one of the LPS RXC-Cs. In my opinion, it is a much nicer unit than the IPS -- smaller and lighter. I think what happens is that most IPS users get started with a GWS kit that comes with an IPS, and they stick with what they're familiar with. The LPS requires a round mounting stick (dowel) instead of the rectangular stick for the IPS. So that may work against it for those who already have aircraft with rectangular mounting sticks.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Mar 30, 2004, 08:41 PM
JREEVES is offline
Find More Posts by JREEVES
Wayward Pilot
JREEVES's Avatar
USA, FL, New Port Richey
Joined Sep 2001
Martyn, in your experience (I have none), do you find a difference in durability between the IPS and LPS?
JREEVES is offline Find More Posts by JREEVES
Old Mar 31, 2004, 02:09 AM
Toronto Canada
Joined Dec 2002
The only weakness of the LPS units (if one could call it a weakness), is that the shaft is more prone not only to bend, but to break if you nose it into the ground in a hard crash. I have extra shafts on hand. I guess that this is the penalty one has to pay to achieve the lighter weight. A propsaver might prevent the problem.
Electrically I have had no problems with them and use them in all my little planes.
Old Mar 31, 2004, 02:24 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Availability is an issue too. I simply haven't seen these except on Nippon Daves site.
Old Mar 31, 2004, 02:30 AM
Toronto Canada
Joined Dec 2002
Good point !
When they first came out they were well stocked at my local hobby stores, but I suspect because of the lower demand they are not re-inventoried.
I got my latest ones from Zebra Hobby in Calgary Canada.
Old Mar 31, 2004, 06:37 AM
RocketRob is offline
Find More Posts by RocketRob
Size Matters!
RocketRob's Avatar
San Francisco Bay Area
Joined Dec 2002
Shhh!
These are "the best kept secret"
I've been using a 4:1 w/ 7.2v motor in my 3oz 75% scale Tiny X.
Recently i built up a hot wind 18mm x10mm tall stator cdrom motor.
1st one (16t) spun up a 9x7sf @ 3amps.
Second one 14t spins up at 4.3 amps -currently on the plane.
Trying to optimize for 6.6 amp (20c) for kokam 340 2s pack-the final version -12t - 6.1 amps.
This begs the question of durability?
The unit was designed for 20-21 watts-now seeing 40-45. Thus far all well!
Oh yeah. the complete unit-motor/adapter/gearbox/prop/and spinner weigh 32gms compared to the original unit at 27gms.
RocketRob is offline Find More Posts by RocketRob
Old Mar 31, 2004, 07:34 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
The IPS's are my favorite motors for the small stuff.
Aeromicro keeps a good supply.
http://www.aeromicro.com/
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Mar 31, 2004, 07:52 AM
Joined Feb 2000
I got mine from Balsa Products:
http://www.balsapr.com/catalog/motors/default.asp
Old Mar 31, 2004, 05:30 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
How do the GWS-SF props fit the 2mm LPS shaft? Is there a cheap adapter or sleeve?
MKH
MKH is offline Find More Posts by MKH
Old Mar 31, 2004, 06:55 PM
no stick is offline
Find More Posts by no stick
Ohio
Joined May 2003
Probably due to the same reason you don't see many of the GWS EPS 150 power systems. You wont see much demand until GWS CEO builds kits for the power systems.
Ed
no stick is offline Find More Posts by no stick
Old Mar 31, 2004, 07:22 PM
Toronto Canada
Joined Dec 2002
MKH:
The LPS systems come with 2 small aluminum sleeves to increase the shaft diameter for a variety of props.
Old Mar 31, 2004, 08:00 PM
MKH is offline
MKH
MKH
Ohio
Joined Mar 2000
Originally posted by Martyn McKinney
MKH:
Thanks! A buddy wants to duplicate my lightest Mini IFO, but doesn't want to pay for the expensive coreless setup. Oddly enough, the LPS with a 2x340 pack and GWS submicro gear will weigh the same as my coreless drive and 3x250 pack, and thrust will be within an ounce, so he should be happy.
MKH
Old Jul 21, 2006, 03:28 AM
Tim Kroeger is offline
Find More Posts by Tim Kroeger
Joined Jul 2004
Hi Guys,
This thread is probably dead, but I was wondering if the GWS IPS A (??) would power a 70% scale version of Tom Hunt's Miss Stik? Wing span is about 40" and I am targeting AUW of 10 oz.
Not after 3D performance, rather a nice scale like floating style...
BR
Tim
Tim Kroeger is offline Find More Posts by Tim Kroeger
Old Jul 21, 2006, 04:26 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Originally Posted by Tim Kroeger
Hi Guys,
BR
Tim
Just about. I am flying a 10oz Eindekker on IPS 'B', 3s etech 450 and 8x6 prop.
The 'A' motor goes perfectly with 7x6 prop on 3s LIPO..
You will not get spectacular performance, but it will fly all right.
Discussion Why don't you hear more about Swift wings Fearless Flight Flying Wings 8 Feb 26, 2007 08:00 PM
Discussion You don't hear much about the GWS Funny Park sgil2001 Parkflyers 15 Feb 09, 2006 09:22 PM
Why don't we get vapor trails? Jaffa Electric Plane Talk 30 Mar 11, 2003 11:55 AM
Why donīt we fry our receivers when connecting battery connector wrong? Erik Johansson Electric Plane Talk 3 Dec 12, 2001 05:52 PM
