Old Mar 29, 2004, 02:36 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Unicorn Wing Building Process - Part 2!
Here's the second part of the thread, that ended here;
http://www.rcgroups.com/forums/showt...45#post2000345
tim hooper
tim hooper is offline Find More Posts by tim hooper
Old Mar 29, 2004, 03:30 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Hey guys, we're getting notorious! This is the second Unicorn related thread that went into second edition!
Up&Away is offline Find More Posts by Up&Away
Old Mar 30, 2004, 01:50 AM
The Flying Pig is offline
Find More Posts by The Flying Pig
The Flying Pig's Avatar
Oxford, UK
Joined Nov 2003
Great models deserve notoriety.
The Flying Pig is offline Find More Posts by The Flying Pig
Old Mar 30, 2004, 04:50 PM
segdohbird is offline
Find More Posts by segdohbird
segdohbird's Avatar
San Jacinto, California
Joined Jan 2004
hey sargentw,
I have a graupner 5.5x 4.3 that I've been thinking of using with the Mega 16/15/4 Do you think I will have any problems with that setup. I haven't figured out how to use the motocal yet. Presently running a MAS 6X4 and motor is just barley warm after about 30 min of flight................SB
segdohbird is offline Find More Posts by segdohbird
Old Mar 30, 2004, 08:45 PM
sargentw is offline
Find More Posts by sargentw
"SARGE"
sargentw's Avatar
Fairfax Station, (Northern) Virginia
Joined Jun 2003
You are better off with the larger prop. It sounds like it's working for you. I've heard the graupner cam props work better than the APC props. I seem to be finding that out too as I keep testing both types of props. The graupners are alot more expensive, at least i have not broken any (yet).
Even though I don't need them right now I made a set of Unicorn Winglets with Oracover and poster board (Thor). Also a fellow flyer sent me some clear 2mm coroplast and I'm making a set of winglets out of that with the bright yellow glued only on the outside. I need that bright color on the outside so I can see the darn thing.
I will post pictures soon.
How is your flying getting along?
Regards,
Tad
sargentw is offline Find More Posts by sargentw
Old Mar 30, 2004, 09:03 PM
segdohbird's Avatar
Joined Jan 2004
Sargentw,
I'm not sure exactly what you meant about the prop size.....I guess I'll just do some comparison testing on my own. Just didn't want to heat up the power plant (mega) by spinning too fast with the smaller 5.5 X 4.3 Graupner....I too have some 2mm coroplast on the way so I will be building some standby winglets. I think I am going to go to lmore magnets to hold them on, the 2 pair on each side work OK until you start doing barrel rolls then they want to come off. Might need to add more, say 3 pr. per side. FLYING is greatly improving. I try to get out every day after work and I get in about an hour before it gets dark....but that will change this Sunday when we go to daylight savings time. Thanks for the info......clear prop........sb
Old Mar 30, 2004, 09:17 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
You should be safe with smaller props. The smaller props will not draw more power. Your best performance with your mega 4 wind will be with a larger prop (6x4). You will see this when you check em out. BTW: the Graupner 5.5x4.3 is not that much smaller and may work well for you. It's a good quality prop.
Right daylight savings time!
Old Mar 30, 2004, 11:34 PM
segdohbird's Avatar
Joined Jan 2004
Thanks for the info Sargentw,
I do really like the Graupner props....I have a 6x3 cam folding that really works great....but I busted my first one (forgot to throttle down before crashing, ripped one of the blades off) When I get a little more confident that I won't rip the hell out of it I'll put it (new one) back on.....I really like the Grupner Cams but they are price-y..........sb
P.S. Does anyone know of a place where we can get the Graupner, other than Hobby (shipment gouger) Lobby.. I've searched the web and haven't had any luck locating a supplier...
Old Mar 31, 2004, 09:11 AM
777 is offline
777
Find More Posts by 777
777
Bought at a price.
Winfield, Kansas, United States
Joined Jul 2002
www.nesail.com
777 is offline Find More Posts by 777
Old Mar 31, 2004, 09:26 AM
segdohbird's Avatar
Joined Jan 2004
Thanks 777,
Windfield Ks. I lived there once.....just before our family moved to cali. But that was 50 yrs. ago. My sister was born there. I'm sure it's a little bigger than when I was there..........sb
P.S. There's something wrong with the nesail site. Server running really slow. Sometime can't even get into it. Will try again later.
Old Mar 31, 2004, 09:57 AM
777 is offline
777
777
Bought at a price.
Joined Jul 2002
No kidding!?! Wow, it really is a small world!!
Winfield is still pretty small & insignificant, but I like it that way. About 12,000 population, but I believe that includes the rural areas as well.
Here I never have to search for a place to fly, there's lots of wide open space. Never crowded out by other flyers, in fact, I've never seen another RC flyer here ever! It's almost lonely.
I'm looking for Graupners too, for when I finally slip the 16/15/4 in the 'Corn. I'm considering the 5.5x5.5. What do you plan on using? Do you have any experience with any of them?
Take care,
Brad
Old Mar 31, 2004, 10:04 AM
soundman is offline
Find More Posts by soundman
soundman's Avatar
Norfolk, UK
Joined Jul 2002
I use the 5.5x5.5 CAM with 10 cells - it's a nice combination of speed & vertical.....I did measure the current draw a while back - I think it was 18 amps static.
soundman is offline Find More Posts by soundman
Old Mar 31, 2004, 11:18 AM
777 is offline
777
777
Bought at a price.
Joined Jul 2002
Thanks, soundman.
That's helpful. Have you tried any other combinations?
Old Mar 31, 2004, 12:06 PM
soundman is offline
soundman's Avatar
Norfolk, UK
Joined Jul 2002
I've tried 8 cell on that prop - still nice but needs the 10 cells really.
I also tried a gunther carbon 5x5 on 8 cells (before I had the 10 cell packs) to be honest it was a bit dissapointing - speed & vertical were better than stock, but nothing to write home about.
The 5.5x5.5 is the one for me.....it has almost too much speed for me (but I'm getting used to it) vertical is great & the run times aren't bad either.....I think it's in a happy area where speed, vertical & runtime are good - you could of course improve on any one of these but the others would suffer.
I may try a 6x4 or so one day....but I can't really see any reason why I need to.
Old Mar 31, 2004, 12:28 PM
Oxford, UK
Joined Nov 2003
While we're on props:
What folding props are people using?
I'm using a Mega 16/15/4 and am thinking of using a folding prop for better streamline flying and less drag on landing.
Believe me I've searched the various 'Corn threads and I know this one has been discussed, but there are thousands of reples and searching is like the needle in a haystack....
Idea GWS PT-17 Stearman Building tips (Part 2) guapoman2000 Parkflyers 110 Jun 01, 2015 07:00 AM
Stevens Aero Stella: Building Thread (part 2) doc-e 3D Flying 543 Dec 22, 2004 06:58 PM
Banchee E-3D - Building and Flying, Part 2 Harley Sport Planes 499 Dec 10, 2004 12:46 PM
Rave Unicorn Wing Building Process sargentw Foamies (Kits) 504 Mar 29, 2004 02:36 PM
