Go Back   RC Groups > Aircraft - Electric - Airplanes > Indoor and Micro Models
Old Dec 23, 2001, 08:46 PM   #1
ifo 1524 motor
I need information on the 1524 motor pinion if it can be replaced
and where can I get the parts and tools to replace it.
Terry W
Terry W is offline Find More Posts by Terry W   Reply With Quote
Old Dec 24, 2001, 07:54 AM   #2
Bill Glover's Avatar
I think the motor is supplied (by the manufacturer) with the pinion, hope I'm wrong but I have a nasty suspicion that buying a new motor may be the quickest/easiest/cheapest option Maybe someone out there can supply an identical replacement, good luck!
BTW, how on earth did you wreck the pinion gear?? I use a 28cm (11") prop on my 1524 with 9 cells and it's survived some pretty major impacts completely unscathed so far.
Bill Glover is offline Find More Posts by Bill Glover   Reply With Quote
Old Dec 24, 2001, 09:33 AM   #3
Pat Daily's Avatar
Terry
I think Todd's Models carries replacement 1524s. I have chewed up several of the pinions in the 6:1 geared jobs using 7-8 props and have learned to use very light props. The 11.1 1524s that I use have either the ARC or the other carbon fiber prop and so far I have about 300 flights on it. I think you must use a light prop because the gears are so small and fragile.
Pat
Pat Daily is offline Find More Posts by Pat Daily   Reply With Quote
IFO Mini Motor Mount Steven D Indoor and Micro Models 11 Feb 04, 2004 02:11 PM
Question Mini-IFO, 1524 and Qualcomm 830's Clu Indoor and Micro Models 24 Feb 25, 2002 09:26 AM
A couple of Mini IFO / 1524 questions... Clu Indoor and Micro Models 8 Jan 14, 2002 09:13 AM
mini ifo 1524 motor pinion gear Terry W Electric Plane Talk 1 Dec 24, 2001 12:18 AM
Wanted IFO MK3 Motor JStory Aircraft - Electric - Airplanes (FS/W) 3 Oct 15, 2001 11:53 PM
Congratulations SimpleM!
