Old Mar 29, 2004, 03:11 AM
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
Yippee!
Work in progress - big panorama!
OK, I'm gonna just start overlapping all the photos I get from this similar view and see what I end up with... here is what i have so far:
CJS
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Mar 29, 2004, 05:36 AM
Ironsides is offline
Find More Posts by Ironsides
Ironsides's Avatar
Toronto, Canada
Joined Jan 2003
CJS:
There are some gorgeous colors in your pano.
David
Ironsides is offline Find More Posts by Ironsides
Old Mar 29, 2004, 03:37 PM
Joined May 2002
Yes...
The clouds were particularly nice... it is pretty hard sometimes getting the clouds and the ground exposed properly... most of the time the clouds are washed out to get correct exposure of the ground or vice-versa... but this came out OK
by the way, this is a 180 degree panorama looking from the north (left) to the south (right)
CJS
Old Mar 29, 2004, 07:25 PM
Kyle G. is offline
Find More Posts by Kyle G.
Kyle G.'s Avatar
Wheeling, Illinois
Joined Dec 2003
very nice. i like the clouds too, the lighting also seems to be just right and makes the panorama very nice looking. got a full size? what program are u using to stitch them together?
Kyle G. is offline Find More Posts by Kyle G.
Old Mar 29, 2004, 10:08 PM
Joined May 2002
Kyle G.,
I have a full size... but not sure where I could post it! My file size on that is somewhere around 51meg!
I'm using Adobe Photoshop 7 to work with them... there is no "stitching" function that I'm aware of, I've just been rotating the photos and adjusting brightness/contrast where needed... on these I didn't do anything except overlap them - a quickie job really. I think there ae many other programs that will stitch photos together...
CJS
Old Mar 29, 2004, 10:15 PM
Kyle G. is offline
Kyle G.'s Avatar
Wheeling, Illinois
Joined Dec 2003
50 meg!! i see about 7 pics together there what is the original size of the pictures? that is really cool. are all the objects in the pics the same size throughout the panorama or did u have to make some smaller or bigger so they fit with each other. (when i say bigger or smaller i mean like stretching and skewings so to speak)?
Old Mar 29, 2004, 10:32 PM
Joined May 2002
Kyle G,
My photos are 2272 x 1704 mp each.
The way I did this one was first to set up my camera so that however long I hold down on the "trigger switch" in my case channel 5, the landing gear switch - it will just continue to shoot photos.
Then I just turn in a slow circle while holding the switch down, in this case it was an "outside" circle, meaning that the camera was pointed out the left wing and I turned right, this gave me more clouds and less ground because of the bank of the plane during the turn. If I wanted it the other way around I'd just turn the opposite direction for a more downward angle.
Actually I should have done an "inside" circle immediatly following these shots, I could have stiched on a second row of photos!
Other things I do is to set my camera up manually for focus to infinity and then I turn off the photo "post view" so it does not waste energy on powering up the view screen.
This allows me to take over 150 shots at a time easily - of course most are a waste and have to be weeded out!
CJS
Old Apr 02, 2004, 01:20 PM
cjalphonso is offline
Find More Posts by cjalphonso
Columbia, SC
Joined Jan 2004
I use a program called photovista that will stitch those pics together seamlessly, works very well.
cjalphonso is offline Find More Posts by cjalphonso
Bluecore F-14, work in Progress,,,,,,,,,,, Flying Weasle Foamies (Kits) 78 Nov 12, 2004 12:57 PM
Kits, Plans & Work-in-Progress Pusher Jets Gordon Electric Ducted Fan Jet Talk 49 Dec 02, 2003 01:07 PM
My new GWS Spitfire - work in progress mattski GWS (Grand Wing Servo) 2 Sep 07, 2003 05:50 PM
RBC Beaufighter (work in progress!, long progress) Stuart Warne Scale Kit/Scratch Built 10 Apr 13, 2003 09:33 AM
Work in Progress Sail 'n Soar Parkflyers 2 Sep 21, 2002 12:13 PM
