Old Mar 28, 2004, 07:17 PM
Kado is offline
Find More Posts by Kado
PRO BRO #1691
Kado's Avatar
Cedar Park, Tx
Joined Mar 2004
Yippee!
Yet another Brushless SS question
Okay gang, this is my first post so please be gentle.
I've been flying my slow stick for well over a year now and while I'm also flying a GWS P-51 I feel I'm ready to a bit of hovering.
I've been reading these forums for months now and have done a bit research. I think I've got all the proper components.
Here is what I have:
Nippy Black 1208/180
Jeti 18-3 ESC
GWS 9.6v/730mAH
My delimma is that when I goto throttle up I can only get up to 1/4 to 1/2 on my stick before my motor shuts down. I'm baffled as to why it is doing this. All I can think of is my ESC shuts down as it approaches my shutdown current.
If that is the case what can I do, if anything to prevent this?
I appreciate any and all responses.
Kado
Kado is offline Find More Posts by Kado
Old Mar 28, 2004, 08:33 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You are correct - those lousy batteries of yours have no hope of keeping up with the demands of a Nippy 1208/180 and you are hitting the LVC. Those AAA cells are good for only 3-4A before they suffer dramatic voltage drop under load - your best bet would be to go to 8-cell 2/3AA KAN 650's - not much heavier than the 730 AAA's but able to deliver 10A without trouble.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 28, 2004, 09:35 PM
sarge is offline
Find More Posts by sarge
sarge's Avatar
Fayetteville, NC
Joined Dec 2002
Would a 3s 1500 Tanic (10C) at 15amps and 11v for less weight and twice the run time also work? Unless LiPo is out of the question.
sarge is offline Find More Posts by sarge
Old Mar 28, 2004, 10:46 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Sarge,
Max amps on that motor is 12A. So with that pack you would have to use a 7 X 5 APC SF or a 8 X 4 APC E prop or you are over the 12A and even the 8 X 4 would be actually pulling about 13A!
Your max thrust would be with the 8 X 4 at about 14oz. Kado what prop are you using now with the 8 cells? Yopu're not going to get much more than 14oz of thrust from that motor no matter what you do!
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Mar 29, 2004, 12:07 AM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
A SS wont hover real well anyhow... A good 3d ship would be a better recipient for that motor combo, and you'll also have an easier time learning
Phreakish is offline Find More Posts by Phreakish
Old Mar 29, 2004, 12:39 PM
Kado is offline
PRO BRO #1691
Kado's Avatar
Cedar Park, Tx
Joined Mar 2004
Phreakish, I'm aware that the SS doesn't hover real well. I would just like to try it before I go out and buy another airframe that may get destroyed due to my lack of skills.
Now then is there a NI-MH battery that I can use that would give me the required power for this brushless setup?
I would like to stick w/ NI-MH because that's what I currently have and don't have any extra cash lying around for Lipo's.
Kado
Old Mar 29, 2004, 01:48 PM
kitfoxdrvr is offline
Find More Posts by kitfoxdrvr
Authorized Self-Portrait?
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
Go with the KAN 650s, they are among the best hi-discharge Nimh out there for the price. I had the same problem with a Mini AC and Phil helped me out as well, recommending KAN 1050s; worked like a charm!
kitfoxdrvr is offline Find More Posts by kitfoxdrvr
Old Mar 31, 2004, 11:00 AM
Kado is offline
PRO BRO #1691
Kado's Avatar
Cedar Park, Tx
Joined Mar 2004
Just curious, where can I get those Kan 650's?
My LHS doesn't have any.
THANKS!!
Kado.
Old Mar 31, 2004, 11:07 AM
boomerace's Avatar
Joined Sep 2001
THANKS!!
Kado.
Get the 650's from www.cheapbatterypacks.com as they are the same cells.
boomer
Yet Another C.G Question Heather Modeling Science 3 Aug 19, 2002 09:59 PM
Yet Another Zero Build Question Runyond Parkflyers 1 Jul 21, 2002 02:19 PM
Yet another GWS Zero question - rolls left on launch Peter Khor Parkflyers 5 Jul 14, 2002 11:09 PM
Yet another GWS Zero question!!! Hopperfly22 Parkflyers 3 May 22, 2002 08:10 AM
Yet another GWS Zero question... tnsfrk Foamies (Kits) 6 Apr 25, 2002 03:29 PM
