iCharger 406 Duo Highlight
1400W 40A 6S Dual Port Charger
Lots of power in a small package
Those of you familiar with the iCharger series of chargers know how well they perform. I've been using the 4010 Duo now for over a year to charge my larger 4S and 6S 8000mAh to 10000mAh Lipo packs. It can output up to 40 amps which means that I can parallel charge two of those 6S 10A batteries on each channel at a 1C charge rate. I love it! It's been super reliable and balances batteries better than any other charger I've used. Now we have the 406 Duo. It essentially the same as the 4010, but in a much smaller package. If you want to read a full review of all the features of the 4010 check out Chris Mulcahy's review. Dale at BuddyRC hooked me up with a 406 Duo at the Toledo Trade show. Lets dive in and take a look at what's different from the 4010 and talk a little more about the features that I like.
The 406 has roughly the same outline and look as the 4010, albeit in a smaller size. The dimensions on the 4010 are 207x140x75mm and weighs 3lbs 5oz while the 406 comes in at 170x118x55mm and weighs 2lbs 1oz. The color on the 406 is a dark grey and orange and it looks pretty good. The button layout is exactly the same as the 4010, but a couple of ports have changed. On the back of the 4010 is a USB port and a Micro SD slot. On the 406 you still get the USB and SD slot, but you also have a 5V 1A USB port which could be used to connect a phone charger or other USB powered devices. On the right side of both units, you still have two servo output ports. On the front the only change on the 406 is the balance ports are now 7 pin ports instead of 11. That means you likely won't need an adaptor to connect your parallel charge board to the 406.
Using the 406 is exactly the same as the 4010 Duo. The screen is just slightly smaller and still rotates up at various angles to make reading the screen easier. The programming can take some getting used to, but once you have it figured out, its a joy to use. The main dial is responsive and makes it easy to change settings. I love having the ability to setup different battery profiles to charge with. It's only a few clicks to start charging once that is setup. The charger also provides great information like icons to let you know which cells are being balanced and the ability to see the internal resistance of each cell.
Overall, I am super happy with the 406 Duo. It really does have every feature I need and It charges just about every battery type out there with power to spare. I'm planning on buying a new SUV soon and I plan to make a charge station in the back. The 406's smaller size would be perfect for this application and would allow me to charge anything I want from my vehicle (using fireproof containers of course).
Thanks to Dale and BuddyRC for providing the 406 Charger for this article. You can find them at BuddyRC.com
Old Apr 16, 2014, 03:44 PM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
I like the size of the charger for a dual output, very small.
The price on the other hand puts it out of my budget. Hopefully they continue to make more models that are lower spec and lower price for those that don't need that kind of power.
mt_100 is online now Find More Posts by mt_100
Old Apr 17, 2014, 07:59 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Yeah i own 308Duo and loves it. Hope that junsi make other cheaper Duo series like 206Duo or 306Duo as i need another one that is cheaper.
rizky_p is offline Find More Posts by rizky_p
Old Apr 17, 2014, 08:48 AM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
Yup a 206 duo would fill in some balnks in the mid range department.
The Tug is online now Find More Posts by The Tug
Old Apr 17, 2014, 09:13 AM
I have no friends
Joined Dec 1996
A model that could do 6S packs at up to 30a and 400w - 500w per port at a price tag of $149 would be awesome.
Old Apr 18, 2014, 08:35 AM
Mauronic is offline
Find More Posts by Mauronic
cool, how high does it go?
Mauronic's Avatar
Joined Jun 2012
The 80s called and they want their colecovision back
I really like the functionality but until they fix the f ugly 80s video game industrial design I can't bear to buy it.
Mauronic is offline Find More Posts by Mauronic
Old Apr 21, 2014, 02:27 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
It's actually quite nice and functional in reality.
Julez is offline Find More Posts by Julez
Old Apr 22, 2014, 01:00 AM
GTbay is offline
Find More Posts by GTbay
Joined May 2013
I have their 3010. Though not so good in looking, but very good function. I want to change to 4010
GTbay is offline Find More Posts by GTbay
Old Apr 22, 2014, 06:53 AM
rizky_p is offline
rizky_p's Avatar
Joined Apr 2007
I dont mind the design, look better in real life than in the photo though.
Old Apr 22, 2014, 11:10 AM
LNLP is offline
Find More Posts by LNLP
LNLP
Oak Harbor, Washington 98277
Joined Jan 2005
Power Supply For 406 Duo Charger
How large a DC Power Supply is needed to secure the full output of the
406 Duo?
Who stocks such DC power plant?
appreciate your help, LNLP
LNLP is offline Find More Posts by LNLP
Old Apr 22, 2014, 05:43 PM
ronin4740 is offline
Find More Posts by ronin4740
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
Am curious what advantages the iCharger 406 has over the 1000W Revolectric Powerlab 6 which is ~$120.00 less?
ronin4740 is offline Find More Posts by ronin4740
Old Apr 22, 2014, 05:44 PM
rizky_p is offline
rizky_p's Avatar
Joined Apr 2007
You can buy used server power supply for cheap depending on where you lives. I bought a second hand Eaton APR24-3G power supply pulled from celullar tower. It cost $34 really cheap for 24v (mine set to 27v) 50A watts power supply.
Description: Name: uploadfromtaptalk1398206484524.jpg
Description: Name: uploadfromtaptalk1398206523713.jpg
Description:
Old Apr 22, 2014, 05:45 PM
rizky_p is offline
rizky_p's Avatar
Joined Apr 2007
Well 406Duo has 2 channels for start.
Old Apr 22, 2014, 06:36 PM
Livipers is offline
Find More Posts by Livipers
Livipers's Avatar
United States, NY, Massapequa Park
Joined Oct 2008
And after using a 2 channel charger, you'll never want to wait for a 1-channel charger ever again LOL
Livipers is offline Find More Posts by Livipers
Old Apr 22, 2014, 06:54 PM
Left Coast DJ is offline
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
Where do you plug-in the ColecoVision cartridges?
Left Coast DJ is offline Find More Posts by Left Coast DJ
Discussion iCharger 406 duo plpflyboy Batteries and Chargers 12 Jun 02, 2014 02:14 PM
Sold iCharger 4010 Duo - Like new indoorheli Aircraft - Electric - Batteries & Chargers (FS/W) 5 Feb 18, 2014 10:33 AM
Discussion Are There Other Chargers That Have Comprehensive Data Screens Like iCharger Duos? itsme2 Batteries and Chargers 3 Jan 23, 2014 01:12 PM
Wanted looking for iCharger 308 or 4010 duo lw777pilot Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 11, 2014 10:22 PM
Found Hyperion EOS 0720i Super Duo or ICHARGER 308DUO purcilas Aircraft - Electric - Batteries & Chargers (FS/W) 1 Oct 16, 2013 12:42 PM
