This thread is privately moderated by Steveis, who may elect to delete unwanted replies.
Old Apr 11, 2014, 05:14 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
KK2.1 V1.17S1 Updated Firmware
If you are using the Pro firmware, please update to V1.17S2 as this has a fix for gimbal servo's jumping and also improves Outputs 7 & 8.
Thank you all for your donations. Total so far is just over 300.
Updated firmware and manual.
Both the Lite and Pro version have improved self level code to increase the angle accuracy so that your multicopter knows which way is up.
Pro version updates are:
a) Much improved self level code that more accurately calculates which way is up. This improves switching to self level after aggressive flying and will improve the Camera Gimbal operation as the accuracy of the angles is now much better. The receiver interrupts no longer screw with the Self Level calculation.
b) Fixed a bug where the Switch SS & PI flag wasn't cleared after a Factory Reset.
c) Added all 25 serial buffer bytes to debug. Only the first 16 used for a DSM satellite. All 25 are used for SBus. Note, only the first 16 bytes are used in the KK2.1.X control code. SBus channels above 16 bytes cannot be used to control the multicopter. When on the Safe screen, the servos will be centred. When in the menu, no signal is sent to the servos.
d) Servo Always On now user selectable in Misc Options 3 (Servos On Arm). If set to yes, servos will move (rather than centre) when armed and the throttle is at zero. Tricopter users will probably want to leave this as "No" so the yaw servo doesn't move when arming/disarming.
Donations for Merlin MS Centre
Ive spent many hundreds of hours updating this firmware. If you would like to show your appreciation, I would be delighted if you made a donation to my favourite charity, even if its only 1 or $1. Please leave a message with your donation. The message needs to be left on the Paypal page under Special Instructions before clicking "Pay now".
www.merlinmscentre.org.uk
Enjoy
Steveis is offline Find More Posts by Steveis
Old Apr 11, 2014, 05:41 PM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
Thanks, just donated but the paypal complete page brings you back to a blank page, couldnt leave message.
yosemitez is offline Find More Posts by yosemitez
Old Apr 11, 2014, 05:44 PM
Steveis is offline
AVR Dude
Joined Jul 2011
Thank you for your donation, it is very much appreciated. The message needs to be left on the Paypal page under Special Instructions before clicking "Pay now".
Thank you again yosemitez.
Old Apr 11, 2014, 08:39 PM
RotoRon is offline
Find More Posts by RotoRon
RotoRon's Avatar
United States, UT, Price
Joined Jan 2014
Same here.
Made a small donation for a good cause.
Edited to add:
I noticed that the default SL P gain is 70 in this version and 60 in V1.16S1. I'm guessing this has to do with the SL code change?
RotoRon is offline Find More Posts by RotoRon
Old Apr 12, 2014, 12:51 AM
Made in Austria is online now
Find More Posts by Made in Austria
Made in Austria's Avatar
United States, NV, Las Vegas
Joined Dec 2013
Just donated a few bucks.
@RotoRon, I just updated my board with the new FW. The update didn't change my gain settings.
Made in Austria is online now Find More Posts by Made in Austria
Old Apr 12, 2014, 01:03 AM
Steveis is offline
AVR Dude
Joined Jul 2011
Many thanks for your donations
Old Apr 12, 2014, 06:15 AM
io53 is offline
Find More Posts by io53
Joined Mar 2014
Kk installed on new vibration mount & new firmware flashed.. Charger stops working. Doh.
Thanks for the update! Sound like a good one, cannot wait for a new charger to arrive so I can try it out . Will look into the charity when I'm at the computer.
io53 is offline Find More Posts by io53
Old Apr 12, 2014, 10:17 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
donate
I jist pitched in some monies
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Apr 12, 2014, 10:20 AM
Asheville,NC
Joined Jun 2002
Files
Being new at this and just rc'd new KK2.1.5 board , dwnl'd the "lite" files
Not sure what to do with them next , they were UNzipped to documents folder when I plug in KK board with USB device , will it look for those files auto ?
still learning , Time to print manual and read are in order
thanks ............te
Old Apr 12, 2014, 10:25 AM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
I have a little problem after flashing from 16 pro back to 12s beginner.
sometimes it wont arm after disarming to make an adjustment, and I have to re-power the FC.
Any ideas?
Terry
marter1229 is offline Find More Posts by marter1229
Old Apr 12, 2014, 01:30 PM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
And now also available by the repository of kkflashtool.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old Apr 12, 2014, 04:55 PM
bwww is offline
Find More Posts by bwww
Gone Multicoptering
bwww's Avatar
Joined Oct 2012
Can I upgrade from the previous Lite without losing any settings?
bwww is offline Find More Posts by bwww
Old Apr 12, 2014, 05:18 PM
Steveis is offline
AVR Dude
Joined Jul 2011
No, you need to jot them down and set them again.
Old Apr 12, 2014, 09:36 PM
The Quasar is offline
Find More Posts by The Quasar
Firmware Fiend
The Quasar's Avatar
United States, CA, San Diego
Joined Nov 2013
Hi Tom, you need to download and install the KK Flash Tool by LazyZero, which can be found here. You need some sort of AVR programmer, like a USBasp, to connect to the ISP headers on your KK2.1.5. Then you have to select the right programmer, board, and firmware version from the drop-down menus in the KKFT GUI. Make sure that nothing else other than the 6-pin connector of the USBasp is connected to your KK. Hit the green running man button, and wait until the program is done flashing the firmware onto your board. After you've successfully flashed the new firmware, go through the initial setup procedure of selecting your motor layout, sensor, and ESC calibrations.
I know that it's a lot of info, so I highly suggest you read the necessary user's manuals and browse the forums for all the info before you start trying to flash your board so that you don't inadvertently brick it. Good luck.
The Quasar is offline Find More Posts by The Quasar
Old Apr 13, 2014, 08:26 AM
SuperFPVflyer is offline
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
After the donation I was taken to this link http://www.merlinproject.org.uk/than...=&item_number= (404)
SuperFPVflyer is offline Find More Posts by SuperFPVflyer
