Old Mar 27, 2004, 03:02 AM
The Flying Pig is offline
Find More Posts by The Flying Pig
The Flying Pig's Avatar
Oxford, UK
Joined Nov 2003
Is my prop on the right way?
For a pusher (X-ite / EleBee) is my prop on the right way?
How can you tell?
The Flying Pig is offline Find More Posts by The Flying Pig
Old Mar 27, 2004, 03:24 AM
Oxford, UK
Joined Nov 2003
Sorry, should be on the 'power systems' forum - can this be moved?
Old Mar 27, 2004, 03:43 AM
Wheazel is offline
Find More Posts by Wheazel
Tech freak
Sundsvall Midlanda, Sweden
Joined Aug 2002
Looks like the prop is in the wrong direction to me.
The sharp and thin longside of the blade is the trailing edge.
By looking at the prop its also possible to see how it should spin to be efficient.
wheaz
Wheazel is offline Find More Posts by Wheazel
Old Mar 27, 2004, 04:12 AM
Oxford, UK
Joined Nov 2003
Yep, I think you're right - thanks.
Old Mar 27, 2004, 04:31 AM
james_28 is offline
Find More Posts by james_28
wizard of OZ
james_28's Avatar
N.S.W Australia
Joined Feb 2003
it is as i can see the numbers on the prop
james_28 is offline Find More Posts by james_28
Old Mar 27, 2004, 07:03 AM
Hiflyer is offline
Find More Posts by Hiflyer
TN
Joined May 2000
The prop in the photo IS on backwards.
Props were originally called airscrews and it helps to think of them that way. When they are spinning in the correct direction (clockwise when standing behind the aircraft and looking forward) would the prop be screwing thru the air and pulling/pushing the aircraft forward?
To make things a bit more confusing, props will still produce some thrust even when mounted backwards (and still spun in the correct direction). This used to be done on purpose by some freeflighters when testing/trimming their gas jobs, as it reduced the power a lot for the first flights.
In any case, flip that one over and go have some fun.
Mike Hines
Hiflyer is offline Find More Posts by Hiflyer
Old Mar 27, 2004, 11:09 AM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
my understanding is that the writing on the props should always be facing forwards (ie the direction of flight), whether it be tractor or pusher.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Mar 27, 2004, 11:46 AM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
You can't always go by the writing on the prop. Depends on the manufacturer. The props that came with my Zagi XT must be turned with the writing towards the back. They have MAXX written on them. I have others that look identical but the writing on them must face forward. These are both black 5X5 props. The one pictured needs to be turned around.
rwp is offline Find More Posts by rwp
Old Mar 27, 2004, 12:40 PM
Oxford, UK
Joined Nov 2003
Thanks for the replies - turned it around.
Nice to know how to tell which way round props go in general.
Used bigger props in the past for IC models.
Help! My prop is spinning the wrong way!! HaBo Power Systems 11 Apr 10, 2006 03:21 PM
Is my prop on correct? eriction Foamies (Kits) 4 Jul 15, 2002 03:08 PM
Should I put a prop on my Kyo T-33? the#1 Foamies (Kits) 8 Dec 24, 2001 04:32 AM
How to keep my prop on ? Red Baron 47 Power Systems 5 Jul 11, 2001 10:52 PM
