Old Mar 27, 2004, 12:31 AM
groundfx is offline
Find More Posts by groundfx
Delta, BC, Canada
Joined Oct 2003
What paint should I use to finish field box?
The manual that came with the field box kit recommends polyester resin or epoxy paint however, I'd prefer a less toxic finish.
Would a water borne acrylic polyurethane (E.g. Minwax or Varathane) work? Would it be at least partially fuel proof?
groundfx is offline Find More Posts by groundfx
Old Mar 27, 2004, 02:50 AM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
I would use acrilic paint. Something with a glossy finish.
Dax is offline Find More Posts by Dax
Old Mar 27, 2004, 04:29 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
Polyurathane (floor varnish) is one of the most fuel proof and durable finishes there is.
Ollie is offline Find More Posts by Ollie
Old Mar 27, 2004, 06:05 AM
Steve Guinn is offline
Find More Posts by Steve Guinn
Steve Guinn's Avatar
Country Rds.
Joined Sep 2003
Minwax Helmsman Spar Urethane
Fuel and UV resistant...bootiful too
Steve Guinn is offline Find More Posts by Steve Guinn
Old Mar 27, 2004, 03:24 PM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
I dunked a sample that had been treated with a water-base polyurethane into some raw glow-fuel. After a couple hours the acrylic finish was soft and easily peeled off. Don't recall the brand.
Best to use the smelly polyurethane.
Jim R
JRuggiero is offline Find More Posts by JRuggiero
what kinda spray paint should I use on foam? troymills Foamies (Kits) 4 Jul 15, 2004 06:30 PM
what prop should I use wallasan10 Parkflyers 6 Jan 21, 2002 08:58 AM
what airfoil should I use?? Pitt76 Foamies (Kits) 0 Oct 31, 2001 09:42 PM
What prop should I use on a Jeti Brushless 15/4 powered Zagi? Ryan Nau Foamies (Kits) 0 Jul 03, 2001 06:11 PM
What fiberglass should I use on a vacume bagged blue foam wing? ChrisFeole Power Systems 6 May 23, 2001 09:11 PM
