Old Apr 17, 2004, 04:11 AM
SharksTooth is offline
Find More Posts by SharksTooth
Aerobatic Extremist
SharksTooth's Avatar
United States of America For Which We Stand!
Joined Jan 2004
Flyin' Naked?!?
Griz has just given new meaning to the term 'Flyin' Naked' ! LOL!!!
SharksTooth is offline Find More Posts by SharksTooth
Old Apr 17, 2004, 06:23 PM
grizzlyone is offline
Find More Posts by grizzlyone
Vancouver Island
Joined Nov 2003
Hey Sharky,
I am replete with joy. My humble sense of humour is appreciated
So...I'm flyin Yak 6 (39") with my Axi and thinking a change of pace might be in order...
Wouldn't want to stagnate...
So what's the second best flate plate foamy out there? The Bulldog?
I've got RZMHV2, D Box (or C Box?), 3S1500's, CCPh10, 4 084's, Electron6. and lot's of materials...
Care to pick one for me or send me a drawing?
Cheers,
Grizzled and Greying (not so gracefully)
grizzlyone is offline Find More Posts by grizzlyone
Old Apr 17, 2004, 08:56 PM
Aerobatic Extremist
Joined Jan 2004
Originally Posted by grizzlyone
Hey Sharky,
Cheers,
Well, the 40" Extra is pretty darned good! That plane would harrier, elevator, and wall sooooo easily.
If you're not in a hurry, I'm gonna get back on the 45" Extra, and am gonna talk with GW about a 50" or 60". He said something in the thread I did on the 40" plane about a 50". the 45" and 50" or a 60" is gonna take alot of motor. I would say at least the 2025-5300, and a Lehner setup would probably be better...eosecially on the bigger two. With the Razor setup you mentioned a 40" would be as big as I would go personally. I like alot of power though. I also build a little stronger, and not quiet as light becasue I put the things through he-- . hehe
Old Apr 17, 2004, 09:38 PM
Vancouver Island
Joined Nov 2003
Sharky/GW,
Have you got the latest Extra drawings?
I've got some 36"er's that GW sent me back in Feb but they may have been modified since then? mjglover at shaw dot ca
Thanks in advance.
Griz
Old Apr 18, 2004, 07:41 PM
Capn_Marlin is offline
Find More Posts by Capn_Marlin
Capn_Marlin's Avatar
Johns Island, SC, USA
Joined Jan 2004
Got some new video the other evening. Was the first time I've gotten to fly in three weeks because its been so windy. Mostly harrier practice. Enjoy!
Its called "Prop Saver Maiden"
http://rcgroups.com/gallery/showgall...p?ppuser=27087
Capn_Marlin is offline Find More Posts by Capn_Marlin
Old Apr 18, 2004, 08:56 PM
GALENM is offline
Find More Posts by GALENM
Wooster OH
Joined Oct 2003
Pull pull linkages are new to me. Anybody got pictures or sites that have ideas.
GALENM is offline Find More Posts by GALENM
Old Apr 18, 2004, 09:10 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Originally Posted by dsBeliever
galenm,
To get that same 25 ozs of thrust with an AXI you'd have to use the 2212-20. But then you'd be pulling 16.3 amps or about 1.5 ozs/amp
The 2212-26 is being used at a claimed thrust of 30oz with a 11-3.8 I know some folks have been using 11-4.7 on them and the power is unreal! With every thing out in the open on a profile 3D foamie the cooling factor is a plus.
The 26 should be ran with the tanics or irates. The etechs will choke. This is from the Flex 3D EPP kit and its motor recomendation.
POWER
Specifications:
Wing Span: 31-1/2"
Length: 33"
Wing Area: 291.625 in.
Flying Weight: 12 to 14 oz.
Wing Loading: 5.93 to 6.91 oz./ft.
Stall Speed: 11 mph (approximate)
Radio: 4-6 Channel, Computer Recommended
Servos: (4) Cirrus CS-4.4
Motor: AXI 2212/34 with radial mount, 26 oz. thrust @ 11 amps WOT
Prop: APC 12 x 3.8 SF
Batteries: 1100-1300mah 3S1P (8 to 10C) Lithium Polymer
Speed Cont.: Castle Creations Phoenix 10 or 25
1) Alternate Motor Setup:
AXI 2212/26 @ 30 oz. static thrust @ 15.5 amps with an APC 11x3.8 SF prop and a Castle Creations Phoenix 25 ESC
2) Alternate Motor Setup:
PJS 3D 550E @ 21 oz. static thrust @ 9.5 amps with an APC 12 x 3.8 SF prop and a Castle Creations Phoenix 10 ESC
power is offline Find More Posts by power
Old Apr 23, 2004, 08:44 PM
GALENM is offline
Wooster OH
Joined Oct 2003
How do you do a neat job of gluing the xbrace to the fuse. I would think that sliding it in place would scrape off all the glue. Or can you get glue into the joint from the sides after assembly. Will a bead of hot glue hold?
Do you cut the whole wing from one piece and slide in place, once again a glue problem.
Is the CF wing brace one piece? Certainly the strongest way.
Old Apr 24, 2004, 01:17 AM
dsBeliever is offline
Find More Posts by dsBeliever
I fly, therefore...
dsBeliever's Avatar
Santa Blah Blah
Joined Dec 2002
galenm,
Put it all together with no glue, then use thin foam safe CA to tack in some places, then use baking soda and thin CA to finish the job. I usually let that set up overnight then put on another bead then a depron triangle as well. Sharky did a build thread here. This post describes his gluing procedures. I've been using the BSI CA and it really is good stuff!
dsBeliever is offline Find More Posts by dsBeliever
Old Apr 24, 2004, 08:55 PM
MickeyMoo is offline
Find More Posts by MickeyMoo
MickeyMoo's Avatar
Ohio
Joined Oct 2003
Here's a pic of may second Yak.
specs
Himax 2015-4100
CC p-25
etecs 3s1200
gws D gb and 12x6 prop
FFF covered to and bottom with color packing tape
3 HS-55 servos
The plan was scaled up to 106% giving the plane a 38" ws
It weights about 16 oz! I didn't think it would weight that much but it is covered top and bottom with packing tape and the fuse is tripple ply on bottom from nose to TE of wing. This and the packing tape make for a strong and heavy plane. Test flew it today. Kinda windy but flew well and climbs nicely. I'll get some video in the near future.
MickeyMoo is offline Find More Posts by MickeyMoo
Old Apr 24, 2004, 09:06 PM
MickeyMoo's Avatar
Ohio
Joined Oct 2003
Here's a pic of the first one again. I gave it to my brother Now we both have one Just have to resist combat when flying together That's what the IFO's are for.
BTW it's setup just like the second.
Oh and thanks for the Plans GW These planes are a blast.
Old Apr 29, 2004, 06:08 AM
CraigT is offline
Find More Posts by CraigT
Clearwater FL
Joined Sep 2003
28" yak flys again
CraigT is offline Find More Posts by CraigT
Old May 02, 2004, 09:29 AM
dkurtz is offline
Find More Posts by dkurtz
Joined May 2004
Axi Powered Genie
I ordered and just received my Genie fron NSP. Sal suggested the Axi package (with radial mount) since I plan to fly outside where a little additional wing loading is a benefit. Now that I realize that the motor will be turning backwards, I'm wondering if I have to do something special to adjust the timing or just let the defaults in my TMM 25 handle it.
dkurtz is offline Find More Posts by dkurtz
Old May 02, 2004, 10:02 AM
skysthelimit is offline
Find More Posts by skysthelimit
3D Flyer
skysthelimit's Avatar
pensacola
Joined Nov 2003
I have a 36" gw extra i am building and was wondering how do people get45-60 degrees of throw. I am running a mega 16/7/10 with a homemade li-poly from a guy off ebay 6 cell 3s 2p runs about 30 min. also I willl have to post some pics of my landing gear. Did anyone have any trouble getting there middle peice in. Thanks
skysthelimit is offline Find More Posts by skysthelimit
Old May 02, 2004, 11:47 AM
I fly, therefore...
dsBeliever's Avatar
Santa Blah Blah
Joined Dec 2002
Well, I thought I'd better post a couple of pictures since this thing is taking sooooo long to finish up. (Caution: Don't take up another hobby like airbrushing in the middle of a build!) This will be the first airplane that will maiden with as much hanger rash as an oldie! Just need to cut and hinge the ailerons and install the stuff that makes it go. Bummer is, I think my controller just crapped out.
Discussion which plane?? AJ extra 330 or 3dhobbyshops 47" yak? RC-newbie 3D Flying 19 Feb 25, 2007 05:32 PM
Download Challenger 3D, Yak 54 and Extra 330 Hamilton in Switzerland Aeromedia Scratchbuilt Indoor and Micro Models 0 Dec 15, 2006 12:18 PM
GW Extra 330 and Yak Foam Fly GW 3D Flying 595 Mar 26, 2004 11:11 AM
A small video of my gw extra coultam 3D Flying 5 Mar 21, 2004 12:04 PM
GW Extra 300L....... Motor? No0bSteR 3D Flying 2 Feb 08, 2004 10:16 PM
