Old Mar 26, 2004, 01:57 AM
Batty is offline
Find More Posts by Batty
Born to Ride
Irvine, CA (USA)
Joined Jan 2003
Lipo Battery voltage too low
I have a 3s3p TP 2100 Lipo pack and by mistake I left it connected to my speed controller in the plane for 4 days. Although, the switch on ESC was off, it still drained my battery and now my Triton charger is unable to charge this pack. It keeps on saying the battery voltage is too low. I checked the voltage on each cell and sure enough, its showing 2V.
My question is that is there any way I can bring back the pack to life?
Thanks in advance.
Batty
Batty is offline Find More Posts by Batty
Old Mar 26, 2004, 02:36 AM
Joe Ford is offline
Find More Posts by Joe Ford
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
Have you tried a lower charge rate? Say .5A?
Joe Ford is offline Find More Posts by Joe Ford
Old Mar 26, 2004, 03:26 AM
mjdoz is offline
Find More Posts by mjdoz
Australia, QLD, Bongaree
Joined Nov 2003
Barry,
If the cells have dropped below 3V at rest then you are required to charge at 1/10C to bring them back upto 3V per cell. Once at 3V you can then charge the pack normally.
If you have limited resources then you may have to be creative on how you do that. These are NOT suggestions just thoughts and any may end in disaster.
if the cells read 2V then the pack voltage is 6V this is the same as a 2S pack at discharge
Most NI? charges can be set to very low charge rates
Of course as soon as the pack reads 9V it can then be charged under supervision in the normal way. The only creative thing is to get it to 9V.
Anything that you try is risky so take the normal precautions when doing risky things and watch very carefully for any signs of danger.
Michael
mjdoz is offline Find More Posts by mjdoz
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Can we get this issue put in a big red sticky on the forum???
We've had at least 3 of these in the past week, that I've read.
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Mar 26, 2004, 09:27 AM
Charlie Wang is offline
Find More Posts by Charlie Wang
Joined Dec 2002
Batty,
Set the Triton to 7.4V/1Amp, you can charge the pack to 8.2 - 8.4V, then try again with 11.1V/1Amp setting.
Repeat the process if the charger stop charging.
Regards,
Charlie
Charlie Wang is offline Find More Posts by Charlie Wang
Old Mar 28, 2004, 12:57 AM
Batty is offline
Born to Ride
Irvine, CA (USA)
Joined Jan 2003
Thanks guys, I'll try it tomorrow.
Old Mar 31, 2004, 07:59 PM
Pmagall is offline
Find More Posts by Pmagall
Fun is what matters!
Pmagall's Avatar
Porto, Portugal
Joined Apr 2003
So Batty,
what happened?
I'm curious because, that also happened to me, the same way, and they here brand new etec cells.
2s2p 1200, and my schulze charger refuse to charge them (warning wrong cell count), and the voltage were 1.5v.
So Iím afraid, their really dead.
Paul
Pmagall is offline Find More Posts by Pmagall
Old Mar 31, 2004, 08:22 PM
Batty is offline
Born to Ride
Irvine, CA (USA)
Joined Jan 2003
Okay,
Good news. I tried it on one 3s cell. I charged it at 7.4V/1A and after a few minutes, my Triton complained that battery voltage is too low. I kept on resetting and repeating this process and each time, tiny amount of current would be pushed in. After 4 tries, the voltage reached > 7 volts or so. I then used the 10.8V setting of my Triton and charged it to 10V. After that it was charging like normal.
During the whole time, the battery did not even get warm, therefore I'm sure that no damage occured. Now I've to bring back the other two packs.
Good Luck and Thanks Charlie for suggesting this trick.
Batty
Old Mar 16, 2008, 02:11 AM
ramfayad is offline
Find More Posts by ramfayad
Guys,
The same thing happened to me with Electryfy 1250mAh 11.1V
Helllllppppppppppppp
ramfayad is offline Find More Posts by ramfayad
Old Mar 16, 2008, 02:44 AM View Post
abe_feliciano
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Mar 16, 2008, 03:31 AM
ramfayad is offline
Guys,
The same thing happened to me with Electiryfy 1250mAh 11.1V
Helllllppppppppppppppppppppppppppppppppppppppppppp pppppppppp
Old Sep 11, 2010, 05:30 PM
vorlynx is offline
Find More Posts by vorlynx
Joined Sep 2010
Hey,
I'm not sure if this was the safest thing to do, but here's what I did.
I, too, had discharged my LiPo battery pack such that it was reading about 1.5 volts per cell. My Triton EQ refused to charge it. If I set it to charge to 7.4 volts, it would complain that the cell voltage was too low. If I set it to 3.7 volts, it would "charge" for 2 seconds, and be done. So here is what I did:
1. Disconnected the balancing lead
2. Set the charger to charge a NiCD battery at 0.1 amps
3. Let it charge for 5 minutes.
After that, I manually stopped the charging, reset the Triton EQ, and charged the LiPo battery as normal. Everything seemed to work fine.
vorlynx is offline Find More Posts by vorlynx
Old Sep 11, 2010, 06:19 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
There is a Sticky
http://www.rcgroups.com/forums/showthread.php?t=1074181
Old Jan 25, 2015, 07:55 PM
Ridebackroads is offline
Find More Posts by Ridebackroads
Joined Jan 2015
Thank you for that tip!
Originally Posted by vorlynx View Post
Hey,
I too had a couple of 3S batteries that was beyond charge. I was told to recycle it as they were trashed! These were my first experience with LiPo batteries so I refused to believe that. After taking your advice, sorta, I removed the balancing plug and switched to NiMh. Charged battery at a low rate (0.5) amp for about 20 min. I went from 1.5 v per cell to 3.7 v per cell. Then I reconnected the balancing plug and re selected LiPo Balance. The charger is now happy. I took my time and I'm happy to have saved my two batteries. Once again thank you for your tip. From a newbie to the hobby.
Ridebackroads is offline Find More Posts by Ridebackroads
Old Jan 25, 2015, 10:54 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Time will tell.
hoppy is offline Find More Posts by hoppy
Discussion Triton [error] Battery voltage too low??? Danny Troy Batteries and Chargers 24 May 10, 2006 08:11 PM
Voltage too low in Lipo.....What to do ?? Cal Batteries and Chargers 10 May 26, 2005 04:33 PM
Help! pixie-7P cutoff voltage too low for li-poly's robert harik Power Systems 10 Feb 13, 2004 12:55 PM
Triton, Etec. ?? battery voltage too low? Astro30 Batteries and Chargers 1 Aug 10, 2003 08:07 PM
RX battery voltage too low? HELP! SKYLORD Electric Plane Talk 2 Aug 17, 2002 03:41 AM
