Old Mar 25, 2004, 09:31 PM
rtideas is offline
Find More Posts by rtideas
rtideas's Avatar
wyoming, mi usa
Joined Dec 2000
How about a port for a high intensity LED to flash when a picture is taken.
rtideas is offline Find More Posts by rtideas
Old Mar 25, 2004, 09:47 PM
eBird is offline
Find More Posts by eBird
Look! Up in the sky!
eBird's Avatar
Grand Junction, Colorado
Joined Jul 2002
I like the LED idea. My Optio is so quiet, I know I'll never hear it when it takes a pic.
If not the LED, how about an output for a really loud peizoelectric buzzer of some kind? Those things are tiny and can emit a loud fraction-of-a-second chirp you could hear from quite a ways.
It's really nice to get confirmation a shot was taken.
eBird is offline Find More Posts by eBird
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Ok, the switch already IS programmable...and already has high-intenstity lamp to show a picture was taken!
All that is coming to you for $20 shipped, adding an audible lost model alarm will be a $10 or so upgrade. The base model already includes a bright red LED that flashes when signal is lost, but we all know that we need to hear it? I will begin accepting pre-orders very soon, coding is nearing completion unless I have to add more features
Darnstrider:
You have some good ideas in your posts. I only sample the input once per cycle, and I have never had any problems. I wonder why you had problems?
You have some good ideas. I am looking into the mode switcher, but the USB tear-down seems a bit excessive for the average hobbiest to perform. I think just installing a new connector would be easier and safer to attempt so as not to ruin the camera.
Thanks guys!
-Matt
zagisrule! is offline Find More Posts by zagisrule!
Old Mar 25, 2004, 09:54 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Looks like I just missed your post Steve,
Like I said, I have 2 LED's on there now, one for status and one for lost model / camera shutter. The LMA model already has a beep function when you snap a picture, change modes, or reset the programming, but that is only on the upgraded model. I want to keep the base model as small/light/inexpensive as possible for those that like to "keep it simple" I figure $30 for the LMA model is still quite reasonable and there would still be quite some people to buy it, despite it's slightly thicker size and higher price.
Do you guys think my prices are fair? Final size of the base model is about .35" X .45" and would weigh very little.
-Matt
*edited for bad spelling*
Old Mar 25, 2004, 10:34 PM
TugBoat is offline
Find More Posts by TugBoat
NSW, Australia
Joined Jun 2003
Matt,
Just take this as professional advice - or ignore as you see fit
Non-technical readers should skip this post!
I think that in the interests of 'good design' you should be filtering the input state - and requiring a number of 'good' consecutive input pulses before turning the shutter on and similarly before turning it off.
It is relatively easy to get a stray 'bad' servo pulse. These are filtered in a servo by a number of mechanisms - including that there is a limit to how far a servo can travel in ~20msec.
The issue here is the performance of the device under less than ideal conditions. In ideal conditions the simple vs. the 'filtered' device will work the same - however in marginal conditions there will be a big difference.
Another reason I would suggest this facility is required is that if you are using a software loop to read the input pulse width then the stability of the value you read will not be good (the start and end of the input pulse is asychronous w.r.t your code and you can't measure either the start or end point accurately). This means that if the input signal is close to your switching point there is a good chance that you will get an oscillating signal out of your switch. (ie. some input signal reads will be > the switch point and some will be < the switch point). (Edit: this is typically why you would expect hysterisis on an input control like this.)
I would also suggest that if you have never seen a problem it is probably because the camera's switch debouce circuitry is hiding the problem from you. Ie. if you see a 'bad' pulse and blip the camera switch for 20mS the camera is probably ignoring you.
Tim
TugBoat is offline Find More Posts by TugBoat
Old Mar 25, 2004, 10:52 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Taken as proffessional advice. Ignoring such advice would only be foolish. I don't see any reason not to filter at this stage of design. I am going to work this out. I have noticed on my scope that input signals for the same stick position are not the same. They can vary easily by + or - .01 or .02 mS in good conditions with transmitter "held steady". I will re-work the code to provide a multiple-stage process of verifying the desired shutter activation, checking 3-5 pulses to make sure they are close (within + or - .05mS of desired switching position). Do you think 3-5 samplings/verifications is enough or do I need to do more than that? I would think that 3-5 would be the compromise of accuracy vs. response time.
I greatly appreciate the time you have taken to help me out with this Tim. The question is, who gets the switch? Both of you? That is only fair
PM me with addresses, Tug Boat and Darnstrider.
Old Mar 26, 2004, 12:51 AM
danstrider is offline
Find More Posts by danstrider
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Whoa there Tim, it took me two reads to begin to understand your post! I do think I understand now. In my case, some "stray bad servo" pulses you refer to came from inductive spikes from three of my servos, I belive. Someone else explained the phenomon to me, but it boiled down to servo commands that moved the servo motor were sending feedback down the servo lines and into the basic stamp I was using. The spikes were of great enough magnitude (trigger low) that the camera triggered every time I moved any stick to control the airplane. Laugh if you want, but it helped take pictures... the new basic stamp program samples for three consecutive "trigger" commands, essentially making it statistically unlikely (I am told) that inductive spikes will cause a trigger. I have not tried this new program, but I can no longer replicate the problem. And, now my camera trigger is optically isolated from the servos anyhow, making the whole issue pretty much a moot point.
Dan
danstrider is offline Find More Posts by danstrider
Old Mar 26, 2004, 02:51 AM
TugBoat is offline
NSW, Australia
Joined Jun 2003
Matt,
Thanks for the offer of a switch, but from personal experience you are going to need all the switches you have - consider mine as 'a spare for when you need it'. Also I can actually make any switch I need myself!
Without going on too much - the clue to what is happening is what you say: 'They vary +/- 0.02ms'. Actually if you look at the receiver output with an analyser I think you will find it is remarkably stable - the signal doesn't vary much - the 'error' is in the sampling in the PIC. Your software loop measures in 0.01msec steps. As a result it can 'loose' (or gain) 0.01msec on the beginning and end of the sample - hence +/- 0.2msec. (This is a bit subtle - try drawing some diagrams...)
You are also correct there is a trade off between response time and error rejection - welcome to the real work of engineering
I have been using 5 (about 0.1sec) and never really noticed the delay. Based on my experiments I think you are correct about 3-5 is probably about right.
Tim
Old Mar 26, 2004, 10:10 AM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Tim,
Why did I think you would say that? Thanks for your help!
I was not using a PIC, that was the rx signal out, straight to my ocilloscope, a Tek TDS3032. Usually the signal was stable, but on occasion, I would get one that is up to .02 mS off of what it *should have* been. Your explation makes sense though for PIC-based readers.
I am going to use 5 samples of the input to "Verify" that the user really does want the shutter triggered.
Thanks again TugBoat.
-Matt
Old Mar 31, 2004, 09:08 PM
mike50 is offline
Find More Posts by mike50
mike50's Avatar
Rochester, MN
Joined Jul 2003
I would also suggest that once you decide to trigger the shutter, you should hold it triggered for some reasonable amount of time (I think the MR RC-CAM switch holds the shutter triggered for 250 ms or so) regardless of subsequent input pulses. It is hard to know what a camera might think of someone pressing and releasing the shutter button in 20ms.
mike50 is offline Find More Posts by mike50
Old Apr 01, 2004, 12:50 AM
Rogerdoger is offline
Find More Posts by Rogerdoger
Rogerdoger's Avatar
United States, CA, Clovis
Joined Apr 2002
Good Ideas
Reading this thread has been a trip.
I have to get some coffee!!
Roger
Rogerdoger is offline Find More Posts by Rogerdoger
Old Apr 01, 2004, 10:52 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
mike50,
I already pause 500 mS, thanks anyhow for the suggestion.
Roger,
Yes, you do need that coffee!
Everyone who will eventually want a switch....
Features are now as follows:
-Shutter and mode button control on one channel (Danstrider's idea? A few people touched on it (ZRX Doug, Vince in Texas) but danstrider hit it on the head?)
-User programable shutter and mode trigger points
-Lost Model Alarm and beeps as suggested by Dax
-Zoom controls (the hardware and software is there in my switch....but it is up to you guys to determine the best way to actually get in into the camera) as suggested by Extremeone
-Two super-bright LED's as originally planned for indicators
-Multiple filtering stages as suggested by Tug Boat and Danstrider
-Auto-mode, takes a picture every 3 seconds regardless of radio input, still allows mode change commands
-Wake-up feature keeps camera's from falling "asleep"
-Both open-collector and open-emitter circuits for both trigger and mode controls allow these switches to be used on any camera commonly used for AP
-Sized at .48" X .57" with all these features!
Price will be $20 each for a "Base model" that includes all the above features except the buzzer for the LMA and confirmation beep feature. Price will be $30 for the "Advanced model" with all above features.
I will be taking orders in a week to two weeks, I still need to order the production run of PCB's for these and then I can start shipping soon after that.
Thanks everyone for their interest and input!
-Matt
Old Apr 02, 2004, 02:25 AM
Dax is offline
Dax
Find More Posts by Dax
Dax
There is no spoon
Dax's Avatar
Vancouver BC Canada
Joined Aug 2002
Your the man. I might need to purchase more of these things after my flying buddies check mine out. I am in the process of building a web page to show off arial photos to realitors.
Once again, cudos to you man.
Dax is offline Find More Posts by Dax
Old Apr 05, 2004, 08:10 PM
Who needs a pilot??
danstrider's Avatar
Alexandria, VA
Joined Jul 2002
Hey Matt, how goeth the switch building? Was just cruising the forums and thought I'd ask... haven't had any more idea inspirations but it's been a busy week :-)
Dan
Old Apr 05, 2004, 10:21 PM
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
I have ordered the final PCB's and parts, and am gearing up for a long night of soldering the things together later this week. It will be a week or so before I have my website up and taking orders.
I will be accepting payment by PayPal, Check, or MO.
Anyone interested in buying a unit can contact me via:
switchmaster@hotmail.com
-Matt
ideas for a good airfoil for 24" Pitts? TheDudeVT Sport Planes 6 Oct 17, 2003 02:05 PM
Looking for good flying park plane..any ideas? fletch Parkflyers 13 Jan 01, 2003 03:52 PM
HELP!!im looking for a GOOD sport electric sailplane any and all ideas welcome Dennis Everett Electric Sailplanes 9 Dec 11, 2002 07:05 PM
Post your ideas for The E Zone here jbourke Site Chat 68 May 17, 2002 09:54 AM
Ideas for good battery charger The Other Dave Beginner Training Area (Aircraft-Electric) 2 Nov 29, 2001 12:43 PM
