Old Mar 25, 2014, 12:42 PM
Moorkey is offline
Find More Posts by Moorkey
R/C Potts...
Grantham
Joined Jun 2008
Bilge pump power?
Realistically, can a pair of bilge pumps be used to propel a 1:350 Typhoon along at a decent pace (ballast system, not dynamic)... and if so, what bilge pumps to use?
Moorkey is offline Find More Posts by Moorkey
Old Mar 25, 2014, 04:44 PM
Cliff Hanger is offline
Find More Posts by Cliff Hanger
California Desert... 7 miles from nearest town
Joined Jan 2010
1:350 scale Typhoon submarine
This would be a model measuring about
Length = 19.68 inches
Beam = 2.59"
Height (hull only) = .47"
This is a very small subject.
I have never tried building less than 1:44 scale.
I don't know where to even look for items small enough to make this work.
I will watch your progress because this is off interest.
Cliff Hanger is offline Find More Posts by Cliff Hanger
Old Mar 25, 2014, 09:37 PM
redboat219 is offline
Find More Posts by redboat219
Philippines
Joined Jan 2005
Think your Typhoon look like the Starship Enterprise.
A pair of bilge pumps would propel it at warp speed.
redboat219 is offline Find More Posts by redboat219
Old Mar 26, 2014, 10:51 AM
Moorkey is offline
R/C Potts...
Grantham
Joined Jun 2008
Excellent, redboat! Power to excess (only for emergencies, mind :-D).
Cliffhanger, the Hull is 20.5" long, and about 2.5" wide.
Looking for that 'unique' project, as it seems TK SSBNs have been done to death!
Old Mar 26, 2014, 11:15 AM
Ronin055 is offline
Find More Posts by Ronin055
Ah, so its THIS again. . .
Ronin055's Avatar
United States, NV, Sparks
Joined Jan 2013
What are you trying to build? The Red October?
Ronin055 is offline Find More Posts by Ronin055
Old Mar 26, 2014, 11:59 AM
Moorkey is offline
R/C Potts...
Grantham
Joined Jun 2008
http://i892.photobucket.com/albums/a.../Photo0075.jpg That's the idea!
Old Mar 26, 2014, 12:43 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Have you built a sub before?
Sub culture is offline Find More Posts by Sub culture
Old Mar 26, 2014, 12:56 PM
Moorkey is offline
R/C Potts...
Grantham
Joined Jun 2008
Nope. Just surface boats.
Old Mar 26, 2014, 01:02 PM
Man from Atlantis
London
Joined Nov 2003
Okay, I would strongly advise you start with somethign simpler and larger. Howes are flogging the Moebius/Revell Skipjack 1:72 scale for 25 quid at the moment, which is a complete bargain. Get one, and convert that. there are kits available if you are lacking in workshop facilities. Norbert Bruggen does a kit for 120 euro, so you can be in the water for about 150 if you have a radio.
Old Mar 26, 2014, 01:55 PM
Moorkey is offline
R/C Potts...
Grantham
Joined Jun 2008
Thanks for the advice SubCulture. I already have a radio (Focus 6), hull (dusty Alanger Typhoon from a friend's layapart store), and servos. Looking at finishing up with bilge pumps as: a) it's slightly unique in the slew of Typhoons I have seen out there, b) the pumps offer me space (as far as my block design goes so far) to be a static diver, and c) just like with my boat projects, I enjoy tackling difficult projects head-on. Will keep an eye on the Skipjack / NB kit if this one goes south.
Old Mar 26, 2014, 06:26 PM
Man from Atlantis
London
Joined Nov 2003
Okay. Bear in mind that very few modellers build at this small scale, those who do accept that pretty much everything will have to built from scratch, as there is virtually nothing available off-the-shelf for these small models.
The Skipjack has been converted by many modellers, there are at least two commercial conversion kits available, and plenty of good practical advice.
Old Mar 26, 2014, 06:51 PM
Joined Jan 2010
At this size you will be able to find small motor(s) to drive propellers. The motor/pump will be the hardest part to find that will fit in the hull.
If you go the way of a syringe, you will have to build the gear box to push and pull the plunger.
The simplest system would be a water pump in to a closed ballast tank in to a bladder letting the water reduce the air volume in the hull. The bladder works because it has not fixed shape and will conform to the internal shape.
Remember there can be no sharp edges against the bladder.
I does not turn out well if there is.
Small pumps are out there. I just did a google search for "micro water pump". Then click images and go from there.
Here's one
$8.00
Old Mar 26, 2014, 11:56 PM
Man from Atlantis
London
Joined Nov 2003
I've tried those, they're not what I'd describe as micro, also they're not very dependable, the gears are too soft and burn out easily.
Old Mar 27, 2014, 01:14 AM
Joined Jan 2010
Good to know. about those pumps. Thanks.
I have no experience with them.
Old Mar 27, 2014, 10:31 AM
Man from Atlantis
London
Joined Nov 2003
Decent waterpumps are becoming hard to find. Production of many trusted versions moved from European countries to China, and the quality control went straight to hell.
Tiny water pumps are out there, but are extremely specialized and thus the price of these will give you kittens.
There are various options for a baby ballast system, but my advice is to avoid fitting one to start with, and build the boat as a dynamic diver. Leave room for one to be fitted at a later stage.
If you can leap all the hurdles of getting this thing reliably watertight and functioning well as a dynamic diver, adding a ballast system shouldn't pose any major difficulties.
Cool Bilge pump switch with 0-60sec delay off roger84 Scale Boats 6 Oct 30, 2008 02:48 PM
Video bilge pump switch with 0-60sec delay off roger84 Dock Talk 0 Oct 30, 2008 01:56 PM
Question Looking for a bilge pump and anchor winch ken_nj Scale Boats 6 Oct 08, 2008 12:37 AM
Wanted want to buy bilge pump Jon NFL Boats (FS/W) 0 Feb 12, 2006 06:47 PM
