Old Mar 23, 2004, 08:03 PM
stoneware is offline
Find More Posts by stoneware
Joined Mar 2004
Idea
~1/9th scale Piper Cherokee aileron trainer
I just completed the a prototype for a piper cherokee at about 1/10 scale.
Specs:
wingspan = 1 meter
root = 24 mm
chord = 170 mm
constat for entire span
Fuselage:
750 mm
weighs in at 409 grams ready to fly (no battery) or about 14.5 ounces.
Drive:
AXI 2208 34 and 10 by 6 propellor
Radio:
4 channel with speed control
and is very fast, at least for me. I built it because I wanted an alieron trainer as an intermediate step to flying a afr spitfire that I keep crashing.
sorry the pics are so small I lost my camera's charger.
[IMG][/IMG]
tnx
stoneware is offline Find More Posts by stoneware
Old Mar 23, 2004, 08:13 PM
Joined Mar 2004
More shots
Sorry about the limited size of photos.
Old Mar 23, 2004, 08:24 PM
Joined Mar 2004
More shots
Old Mar 23, 2004, 11:53 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
From what I can make out, looks like a great looking plane. Let us know how she flies.
cadconversions is offline Find More Posts by cadconversions
Old Mar 24, 2004, 12:01 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Looks like a nice model!
Here's a little inspiration for you to get her flying!
A shot on final.
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Mar 24, 2004, 12:02 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Moments before the "urk" of the tires on the tarmac!
Old Mar 25, 2004, 02:31 AM
machine is offline
Find More Posts by machine
i say, Yippee
Vancouver Intl, Canada
Joined Aug 2003
hi stone
I've been looking into buying a piper cherokee, but have yet to find one anywere. I have a piper cub, and the lower wing cherokee would be right in line with my hanger.
I'd like to see the plane fly (perhaps a video) and read a review on the build up. Any plans in the future???
machine is offline Find More Posts by machine
Old Mar 25, 2004, 04:05 AM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Very nice Stone! My first aileron r/c aircraft was a Flitecraft Piper
Arrow III. It flew GREAT! It was a gasser with a .25 motor, but
loads of fun. Tons of power.
Your's looks really cool. I hope you have a great time with it.
Hawker is offline Find More Posts by Hawker
Old Mar 25, 2004, 11:31 AM
Joined Mar 2004
Just trying to find someone with a camera. Had a small flight the other day. Seems the glide in ground effects is better then I anticipated. ie. prop meets chain link fence. Minimal damage to plane. This depron stuff is much tougher then the stuff they use on the gws planes. I think if i'd hit the fence with one of those I may have strained it.
Old Mar 25, 2004, 11:42 AM
Joined Mar 2004
line drawings
Nother note.
I am going to build another from what I have learned thus far. It should weigh less and look a bit better cause there will be much less glue involved and I'll probably use epoxy instead of my prototyping hot glue gun.
If some one has line drawings that include a front view I'd appreciate it. This is what I have been working from.
Old Mar 25, 2004, 01:53 PM
P-51 flyby is offline
Find More Posts by P-51 flyby
P-51 flyby's Avatar
United States, NC, Rocky Mt
Joined Oct 2003
Thats sweet man. There are a ton of those at my local airport! course not 1/10th yet
P-51 flyby is offline Find More Posts by P-51 flyby
Old Mar 25, 2004, 06:53 PM
Joined Mar 2004
3 view drawing
Here's a little something I whipped up on my new "cadview" program. Nice freebie!
Hope this works, It's a bit of a learning curve here.
Old Mar 27, 2004, 10:16 PM
Joined Mar 2004
Results of test flights
The wind was variable but fairly gusty due to thermal activitiy but not enough to deter my test pilot from doing a nice demonstration with his 3DX and my multiplex Pico Cub had no problems penetrating either.
Loaded up the cherokee with 8 1100ma nimh batteries and... contact.
We launched from a slightly soggy baseball diamond and the plane ate up an entire baseline to get off the ground, granted the wind was a bit cross. Just before the grass some up elevator was applied and the little guy rose gently but steadily to about 50 feet and about 300 ft downrange where the pilot initiated a left trun and kept climbing to about 70 feet.
Not bad and it's scarry how much it looks like the real thing in flight. This first flight consitsted of about 5 circuits around the flying field with lots of throttle. Plane landed safely but not much roll out because of the wet field but nothing broken. Success!
I got to fly next and the take off was the same but I realized there wasn't much battery left so I just landed instead of making a low turn. Flight two a success too.
The last flight of the day we experienced a total power out on our base leg turn and she just rolled over and went straight in.
Damage as shown in the photo is only to the front. The wings are still solidly attached to what's left of the fuselage.
Observations:
Too much throttle was needed to fly.
The plane, once trimmed out flew very scale and can't be considered aereobatic...yet.
It's still too heavy.
More elevator needed. Full up was needed to liftoff and climb.
More aleron needed, truns were nice and smooth but the roll rate seems a little slow, well at least for m;y test pilot.
Rudder is sufficient for good ground handeling and seems to be ok in flight.
The landing gear are bullet proof!
Doesn't climb as well as I would like.
What's next:
I am not going to bother rebuilding the crashed fuselage, I am going to build a new one according to my latest kit plans. Its a little sleeker and should weigh considerabley less. This should help in the area of thrust and lift. Thrust due to smaller frontal area and lift due to increased wing area.
The new elevator will eat into the horizontal stab so I get more control surface without giving up any on the scale profile.
The new horizontal will have a greater incidence angle to see if that's why there isn't enough lift and seemingly little elevator.
The nose gear will be upgraded in terms of wire guage and lenght. I want to run at least a 10" prop on the axi.
When do you consider your prototype complete.
Lastly, as the photo shows we lost our test pilot, I guess he figgured the risks too great. On the other hand we got a new one with lots of experience. I'm just worried about his health, he seems a little yellow.
Hopefully videos will accompany the next installment.
ciao
Inappropriate picture removed by moderator
Old Mar 29, 2004, 10:26 AM
Joined Mar 2004
censorship
Boy are you guys strict. And I suspect a little humor deficient.
Anyway here's the offending photo "self censored". Kind of kills the joke completely.
Old Mar 29, 2004, 10:52 AM
P-51 flyby's Avatar
Joined Oct 2003
I thought it was great. But of course some tree hugger has to report something they don't like
Large Delfin In 1/9th Scale CaptDH Submarines 54 May 14, 2005 11:17 PM
Einar Johnsson SAAB VIGGEN 1/8th and 1/9th scale Sluf7 Electric Ducted Fan Jet Talk 1 Jul 12, 2004 06:38 AM
1/3 Scale Piper Vagabond Cowl probuilder Aircraft - Fuel - Airplanes (FS/W) 0 Apr 27, 2004 08:48 PM
Cool 1/4 Scale Piper J-3 Cub "sig"#rc-48 bonhed Aircraft - Fuel - Airplanes (FS/W) 1 Feb 01, 2004 03:10 PM
Sig 1/5 scale Piper Cub Michael in Toronto Scale Kit/Scratch Built 5 Oct 04, 2002 12:30 PM
