RC4WD Hilux/Mojave Accessories Plus Other Cool Items
Raise your truck to the next level with scale add-ons.
RC4WD releases new parts for the Hilux/Mojave along with other unique scale offerings!
It is quite hard to keep up with all of the products that are released from our friends over at RC4WD, but here are a few of the cool ones that were announced this month. Two are accessories specifically made to fit Tamiya-style Hilux and the RC4WD Mojave bodies and the other three will shed light on the situation and a realistic storage device for oils.
Full Tubed Exocage for Hilux & Mojave Body
The Full Tubed Exocage is a tig welded tube chassis that is attached to the outside of the body. It is precisely built and does not require any holes drilled for install. It is meant for Tamiya-style Hilux and the RC4WD Mojave bodies. RC4WD includes a custom cloth to aid in the installation along with hardware.
SPECIFICATIONS
TOTAL LENGTH17.9in (456mm)
WIDTH7.4 in. (190 mm)
HEIGHT5.51 in. (140mm)
WEIGHT25.5 oz. (724g)
ITEM NO.Z-C0045
PRICE$169.99
Front Inner Fender Set for Hilux & Mojave Body
When you are able to look between the top of the tire and fender and see the inside of the chassis, the illusion of realism is quickly killed. This Front Inner Fender Set fixes this issue.
KEY FEATURES
  • Lexan material
  • Includes protective film
  • Easy installation
  • Paint-able
  • Weight: 0.56 oz. (16g)
ITEM NO. Z-S1192
PRICE $11.99
1/10 Blue or Red Hydraulic Oil Tank
These are CNC-machined billet aluminum Hydraulic Oil Tanks that can be used for display or get this…for holding fluid. It has a 100ml capacity and uses a metal plug fitted with a rubber gasket to keep the oil inside. The tanks are available in a brilliant anodized Blue or Red color.
SPECIFICATIONS
HEIGHT3 in. (77mm)
OD1.85 in. (47mm)
WEIGHT3 oz. (85g)
ITEM NOS.VVV-S0113 (BLUE) / VVV-S0115 (RED)
PRICE$59.99 ea.
1/10 High Performance LED Light Bar
Add some serious bright lighting to virtually any scale RC vehicle with this 1/10 High Performance LED Light Bar from RC4WD. Check out its features below.
KEY FEATURES
  • Cast molded housing
  • Reversible "L" brackets to fit many applications
  • Adjustable "L" brackets for rotating light
  • 14 individual LED bulbs
  • Super bright lighting
  • Vented on side to dissipate heat
  • Works with up to 3-cell LiPo w/ use of a BEC to regulate voltage below 7.4 volts
  • Standard receiver plug
  • Connects to extra channel on receiver
  • 2mm mounting holes
SPECIFICATIONS
OVERALL LENGTH2.2 in. (56mm)
LIGHT BAR WIDTH1.57 in. (40mm)
OVERALL HEIGHT0.81 in. (20.8mm)
LIGHT BAR HEIGHT0.63 in. (16.2mm)
WEIGHT0.88 oz. (25g)
ITEM NO.Z-C0045
PRICE$169.99
Learn more—RC4WD!
There are no posts
Sold FOR SALE - Axial Deadbolt Body - Castle Motor and Scale Misc Items RC4WD *PICs* SoCalSteve72 Cars - Accessories (FS/W) 2 Mar 05, 2014 01:37 PM
Sold RC4WD Mojave Body For Trailfinder 2 with Extras ff954 Cars - Trucks and Parts (FS/W) 0 Feb 06, 2014 11:48 AM
Discussion RC4WD TF2 Mojave "the ultimate scale truck" Mr Glassman Rock Crawlers 3 Feb 20, 2012 06:29 AM
For Sale Eagle Tree items FS, all new, plus a couple of other items. Jeffrito FPV Equipment (FS/W) 6 May 02, 2011 05:48 PM
5 Jr 537 servos plus flightpack, switch, and other accessories for sale JStory Aircraft - Electric - Airplanes (FS/W) 1 Mar 30, 2002 03:21 PM
