Old Dec 21, 2001, 01:59 PM
mism42 is offline
Find More Posts by mism42
Joined Nov 2001
Best way to test battery charge?
How can I tell if a battery is fully charged? I have a multimeter to check voltage. Is this the most accurate way? (or is it even accurate at all?) If it matters I am charging small cells 3.6v 300mah with a small solar panal. Normally I just use a peak charger for charging which is why I have no clue. The panal is 6v 100mah output in ideal conditions (4v ish in less light)
mism42 is offline Find More Posts by mism42
Old Dec 21, 2001, 08:47 PM
Quacker is offline
Find More Posts by Quacker
ClearView Rocks!
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Voltage itself is not a good indicator. One way to do it is to observe the voltage as the battery charges. If the voltage goes flat or starts downward (assuming the solar cell output is constant) the battery is charged. You may also check for battery warming. The battery starts heating up when the charge is finnished.
Regards,
Q
Quacker is offline Find More Posts by Quacker
Old Dec 21, 2001, 11:37 PM
mism42 is offline
Joined Nov 2001
Hmm is theres some kind of meter that could do the job?
Old Dec 22, 2001, 01:29 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Unless you have a constant current from your solar panel, there is virtually no way to tell when it is full. If you can make sure to have a constant current supply from the panel, all you need to do is watch the battery voltage. When it stops rising it's essentially full. A little after this you would see the votlage drop at this point the pack is overcharging and the charge should be terminated. With the 100mA charge rate the 300mAh cell may not show a peak. You should stop charging when the voltage stops rising. The voltage of the panel itself is irrelavent in this case as long as it is always over 4.8-5V.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Dec 22, 2001, 05:16 PM
mism42 is offline
Joined Nov 2001
Hmm, is there anyway to tell how much electricity will be required to fill a battery (or at least a close estimate) It almost seems to me that a 300mah battery charged at 100ma should be done in 3 hours? But, this is based on my logic which really doesn't mean much
Old Dec 22, 2001, 05:24 PM
MK is offline
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
In theory that is correct but two important facts have to be considered besides "just the math".
1. The battery most likely will not be totally "empty".
2. Charging (of any kind) is not 100% efficient. Some energy is lost as heat.
Given the two unknowns above, it's hard to tell unless you follow what others have suggested above.
MK is offline Find More Posts by MK
The best way to test the current on brushless SuperHornet Pusher Prop Jet Models 2 Jun 12, 2005 06:41 AM
Rave Best way to discharge battery? thumsrus Beginner Training Area (Aircraft-Electric) 5 May 12, 2005 06:04 PM
What is the best way to test a plane when alone. TeamTEOR Electric Plane Talk 9 Aug 08, 2004 09:05 AM
best way to discharge a battery? skylark_man Batteries and Chargers 5 Aug 28, 2003 02:00 PM
Best way to discharge battery? seanpr123 Beginner Training Area (Aircraft-Electric) 5 Dec 29, 2002 07:21 AM
