Old Mar 23, 2004, 01:14 AM
Raglan is offline
Find More Posts by Raglan
New Zealand
Joined Jan 2004
whats' the best wire for foam cutting ?
Does anyone have experience in hot wire foam cutting ? I'm about to set up a small plant and would like to know whether I should use stainless steel or nichrome wire. Also if there are alternatives to using a variac (voltage transformer/regulator).
I intend to use regular polystyrene foam, but some say I should use high density polystyrene foam.
Any help would be appreciated.
Paul Broome.
Raglan is offline Find More Posts by Raglan
Old Mar 23, 2004, 02:40 AM
SoCalGliderFlyr is offline
Find More Posts by SoCalGliderFlyr
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
Guitar stings. Ran out of nichrome once. Worked just as good. Have to watch the temp/voltage/amps though.
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
Old Mar 23, 2004, 02:30 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Inconel.
But I use stainless steel fishing leader. It works great, it's cheap and easy to get in a variety of thicknesses. I like the .020 dia.
TFLG
TFLG is offline Find More Posts by TFLG
Old Mar 23, 2004, 02:52 PM
Think Thermals!!!!
Joined Mar 2004
That's what I have used! Fishing line leaders.
Now how about a good regulated power supply?
Did you know that Moreno Valley used to be two subberbs? Moreno and Sunnymead. Cousins lived in Sunnymead. Everyone called it Scummymead.
Old Mar 24, 2004, 12:07 AM
Pismo is offline
Find More Posts by Pismo
Jim in San Diego
Pismo's Avatar
United States, CA, San Diego
Joined Nov 2002
I second the Inconel vote. Can't really say about the others since I haven't used them.
Inconel seems to handle the constant heating and cooling really well and is very strong - helps you crank it tight. I use 0.014 on smaller bows and 0.020 the larger ones.
I use a variac so can't really say if there's a good alternative. I know I've read many threads that have great info on the different options though. Maybe you can do a search and find some or, one of the users can post a link.
Good luck & happy cutting.
Pismo is offline Find More Posts by Pismo
Old Mar 30, 2004, 01:39 PM
chemsurfer is offline
Find More Posts by chemsurfer
Rip th... Bring the Beer!
chemsurfer's Avatar
La Mesa, CA, US
Joined Jan 2001
I don't know what the best is , but I gotta give guitar strings a solid thumbs up.
Brad
chemsurfer is offline Find More Posts by chemsurfer
Old Apr 06, 2004, 02:56 PM
Les Horvath is offline
Find More Posts by Les Horvath
East Stroudsburg Pocono, Pennsylvania, United States
Joined May 2003
Re: whats' the best wire for foam cutting ?
Paul Broome.
Cooper coated nicrome wire.
Les
Les Horvath is offline Find More Posts by Les Horvath
Old Apr 06, 2004, 03:18 PM
Think Thermals!!!!
Joined Mar 2004
What does the copper coating do?
Old Apr 06, 2004, 03:45 PM
Joined May 2003
wire
Beter condactiviti.
Old Apr 06, 2004, 04:02 PM
Think Thermals!!!!
Joined Mar 2004
Thought it might be a chemical thing with the foam.
As to conductivity; you want resistance as this is what heats up the wire. Wire consistency in diameter and composition is important so as not to get hot spots.
Old Apr 06, 2004, 04:09 PM
Joined May 2003
wier
Give me a call at 570-828-7396
les
Old Apr 06, 2004, 07:15 PM
SkyKing RC is offline
Find More Posts by SkyKing RC
Minneapolis
Joined Feb 2004
RENE 40 FOAM CUTTING WIRE
I have good results with stainless aircraft safety wire. Guitar strings and fishing leader material is also stainless wire. Inconel (sp) seems to be another favorite but the best I have ever used is Rene 40. It's the wire used by many commercial foam cutters. It's expensive but well worth the cost. It does not stretch. Does not break easily. Handles 100's of heat/cool cycles and is very tough.
I have a spool of .012 that I use on my bows and as many of you know I'm cutting 100's of cores for the kits I am producing.
If any of you would like to try it I can supply it for $.50 per foot with a 20 foot minimum. Shipping is an additional $3.00.
Ed
SkyKing RC is offline Find More Posts by SkyKing RC
Old Mar 22, 2008, 11:35 PM
icerinkdad is offline
Find More Posts by icerinkdad
Omaha
Joined Oct 2005
I have been using .012 or .015 seven strand control line flying wire for about 10 years. It is easily available from Brodak or Sig in the USA. I am not sure where you would get it in other parts of the world.
Bob
icerinkdad is offline Find More Posts by icerinkdad
Old Mar 23, 2008, 05:36 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Nichrome is crap its high resistance thats why they use it in kettles for a hot wire you want the lowest resistance wire you can get so the heat passes easier through the wire, resistance means it takes greater amps to heat the wire to the same level and keep it there ,and as others have suggested Stainless wire works a treat for that very reason .I use .022" lock wire from 737/700 ailerons but the fishing trace would be just the same . Also a victim of the foam fumes over many years.
SteveW
steve wenban is online now Find More Posts by steve wenban
Old Mar 23, 2008, 12:26 PM
T.D. is offline
Find More Posts by T.D.
T.D.'s Avatar
Vancouver, Canada
"Nichrome is crap" Then how has Les been able to cut thousands of near perfect cores using it?
When I started cutting cores in the 70's I tried Nichrome and could not get it to work for me, used SS fishing leader and ended up sticking with Inconel but Les has obviously found a way of using Nichrome that works, perhaps there are several types.
I like Inconel.
T.D.
T.D. is offline Find More Posts by T.D.
Best Wire for Hot Wire Foam Cutter andyg Foamies (Kits) 20 May 02, 2014 03:05 AM
Whats the best glue for foam??? Cas123 Foamies (Kits) 34 Nov 25, 2004 08:44 PM
Best Voltage / Amperage /AC/DC for Foam Cutting mdennis Composites Fabrication 4 Jun 17, 2004 04:51 PM
wire for foam cutting daveswall Foamies (Kits) 0 May 29, 2004 06:52 AM
