This thread is privately moderated by Mud Duck Bill, who may elect to delete unwanted replies.
Old Mar 20, 2014, 02:27 PM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
Build Log
Autogyro blade shaping sanding block.
A quick and easy way to make a blade shaping / finish sanding block. I hope it turns out as nice for you as it did for me.
Well I guess we a limited to how much we can say in each picture.
So after Harding the balsa block it will raise the grain in the wood so just run it over the fine paper on the master to smooth it off. That's why you don't dismantle the jig till often the balsa is dry.
I guess you get the picture in the other post.
Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old May 26, 2014, 08:29 AM
Lazygit is offline
Find More Posts by Lazygit
Joined Oct 2009
What a super piece of work. I must make a jig and several blocks.
Lazygit is offline Find More Posts by Lazygit
Mini-HowTo Creating a Leading Edge Sanding Block russ_hillis The Builders Workshop 3 Aug 31, 2010 10:28 AM
Discussion foam sanding blocks/loose landing paper ,whats the way with blue foam? soarluck Composites Fabrication 9 May 14, 2009 09:24 PM
Sold Lots of building tools, covering iron, prop balancer, sanding blocks, etc. Steve H. Aircraft - General - Miscellaneous (FS/W) 12 Mar 24, 2008 08:54 PM
Sold Monokote Trim Seal Tool and Great Planes Contour Sanding Block rvillegachapa Aircraft - General - Miscellaneous (FS/W) 1 Feb 19, 2007 11:37 PM
What type of gule for foam blocks and sanding? Gary Warner Electric Ducted Fan Jet Talk 10 Sep 21, 2001 04:52 PM
