HKPilot Mega 2.5.2 Master Set
Hobbyking's master set includes everything to create a fully autonomous aircraft or FPV flyer
A complete APM-based kit at a reasonable price
The HKPilot Mega is an affordable autopilot system modeled after the 3DRobotics APM open-source project. The HKPilot has all the same features of the APM 2.5 at a fraction of the cost. Additionally, with the introduction of the 3DRobotics PixHawk, the price of an APM-based board has dropped considerably. But don't let the "old technology" myth sway you, there are plenty of APM 2.5 boards still being produced and used effectively; their processing power and reliability is excellent.
The HKPilot Mega master set comes with a power sensor and BEC module, a Minim OSD for FPV operations, a Ublox LEA-6h GPS, either 433MHz or 900Mhz telemetry radios, and cases for the controller, GPS, and radios.
What's included in the master set?
  • HKPilot Mega 2.5.2
  • Power sensor and BEC Module ( XT-60 connectors)
  • Minim OSD v1.1
  • Ubox super precision LEA-6h GPS
  • Telemetry radios (433MHz)
  • Cases for the flight controller, Telemetry radios, GPS with pedestal mount
  • Complete matched cable set
Click here for product website
Old Mar 19, 2014, 05:31 PM
The Valkman is offline
Find More Posts by The Valkman
The Valkman's Avatar
Joined Nov 2011
I wonder if you can install and external compass like the 2.5.
Edit: it looks like you can. After zooming in on the pic it has the same tracks you need to cut with a knife in order
to use external compass.
The Valkman is offline Find More Posts by The Valkman
Old Mar 20, 2014, 11:16 AM
ballemann is offline
Find More Posts by ballemann
ballemann's Avatar
Norway
Joined Jun 2007
Cut tracks?! Thought you could enable/disable an external compass through mission planner?!
ballemann is offline Find More Posts by ballemann
Old Mar 22, 2014, 05:14 PM
Amfamora is offline
Find More Posts by Amfamora
Multicopter Crash Tester
Amfamora's Avatar
Australia, QLD, Brisbane
Joined Apr 2012
APM 2.6 has tracks cut by default 2.5 doesnt.
Amfamora is offline Find More Posts by Amfamora
Old Mar 22, 2014, 07:17 PM
alan.powell is offline
Find More Posts by alan.powell
Joined May 2011
Saves about $30 over individual major items. Plus cables, APM case and GPS pedestal which do not appear to be available separately.
Good value in my book.
Also take a look at the Mini version of the HK APM2.52 if you just need the flight controller.
alan.powell is offline Find More Posts by alan.powell
Old Mar 22, 2014, 07:28 PM
v2rocketeer is offline
Find More Posts by v2rocketeer
v2rocketeer's Avatar
Australia, NSW, Ingleburn
Joined Mar 2013
It is always the case where I buy something and then a better deal comes along hahaha.
This looks like a good deal and comes with the 10hz GPS too.
v2rocketeer is offline Find More Posts by v2rocketeer
Old Mar 22, 2014, 09:51 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Agreed. For all the items, including the cases, this is a deal.
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Apr 01, 2014, 12:02 PM
Mase_00_7 is offline
Find More Posts by Mase_00_7
Joined Oct 2013
I've just bought this and am impatiently waiting for delivery to the UK!
Am I right in saying that the onboard compass will not be disabled simply by plugging in the LEA-6H, and that I will DEFINATELY need to cut the tracks to the onboard compass??
Cheers, Paul.
Mase_00_7 is offline Find More Posts by Mase_00_7
Old Apr 02, 2014, 01:09 PM
paolo176342 is offline
Find More Posts by paolo176342
United Kingdom, Scotland
Joined Jul 2011
The Lea-6H doesn't have a compass on it though so you'll actually NEED the onboard one...
paolo176342 is offline Find More Posts by paolo176342
Old Apr 05, 2014, 02:07 PM
Joined Nov 2011
No you don't. I have built a few now and will not use the onboard compass.
Having the external one is much more accurate.
Old Apr 05, 2014, 05:37 PM
WheresWald0 is offline
Find More Posts by WheresWald0
WheresWald0's Avatar
United States, NC, Stallings
Joined Aug 2013
Please correct me if I am wrong, but I thought that the inaccuracy of the internal compass was usually due to interference and many times could be remediated by careful placement of the electronic components? Is that simply not true?
WheresWald0 is offline Find More Posts by WheresWald0
Old Apr 06, 2014, 12:10 AM
trickedout is offline
Find More Posts by trickedout
United States, NV, Pahrump
Joined Feb 2013
Paolo was referring to the fact that the included GPS does not include an external compass so for this kit the internal compass must be used.
trickedout is offline Find More Posts by trickedout
Old Apr 07, 2014, 02:44 PM
Joined Nov 2011
You do not have to use the on board compass this is why there is an option in the Mission Planner to use an external one. The external one is only a few bucks and is a lot more accurate if you keep it away from batteries, wires etc.
WheresWald0 that is true but when your stuck for space and if the control unit has to be center it can be difficult. It is much easier to make a post out of plastic and have it up out of the way from everything.
The compass on the black post is one I just done for a customer. A cap screws on over it.
Old Apr 09, 2014, 05:37 AM
Joined Jul 2011
I'll try again - the GPS module does not have an inbuilt compass
The internal compass will have to be used unless you connect an external compass - you'll have to buy this separately…
Example GY-273-HMC5883L-3-Axis-Digital-Compass-Module
Old Apr 11, 2014, 10:56 AM
Beat-tu is offline
Find More Posts by Beat-tu
Allen, Texas (Baja Oklahoma)
Joined Jul 2010
Valkman, Can you recommend how to mount an external compass like you show in conjunction with the provided Ublox LEA-6h GPS? Can I mount it somehow on the provided GPS pedestal mount or GPS case?
Tom
Beat-tu is offline Find More Posts by Beat-tu
Discussion HKPilot Mega 2.5.2 with OSD Kavil194 FPV Equipment 0 Mar 19, 2014 07:17 AM
Found Hkpilot Mega 2.5 Alumalite FPV Equipment (FS/W) 2 Mar 15, 2014 06:24 PM
Found Hkpilot Mega 2.5 Alumalite Aircraft - Electric - Multirotor (FS/W) 12 Mar 15, 2014 06:21 PM
Help! HKPilot Mega V2.5 Flight Controller not responding jafinn Multirotor Electronics 1 Feb 07, 2014 05:10 PM
Alert HKPilot Mega V2.5 Flight Controller problem zeuasplace1983 Multirotor Electronics 0 Oct 19, 2013 02:13 PM
