HobbyKing — Quanum Vandal (ARR)
1/10-scale brushless electric 4WD off-road buggy almost-ready-to-run
Just add a radio and battery and you are ready for the track!
Quanum first released the Vandal 1/10-scale 4WD electric buggy in kit form and due to customer demand it is now available as an ARR (almost-ready-to-run). As an ARR, this means that the Vandal comes out of the box fully assembled with the brushless motor, speed control and steering servo already installed for you. Even the body is painted and trimmed and includes a decal sheet so that you can decorate the body shell how you like. All that is left to do is install your own 2-channel radio system and 2S LiPo or 6-cell NiMH battery pack.
The construction of the chassis provides a lightweight yet sturdy setup to handle off-road running. A TrackStar 3650 12.5T 3000Kv brushless motor is harnessed to a 4WD shaft-driven drivetrain equipped with reliable front and rear metal gear differentials. Soft compound tires were enlisted to get the power from the brushless motor to the ground with plenty of traction. An adjustable slipper clutch is spec’d to protect to drivetrain. The suspension is fully adjustable and uses threaded-body, oil-filled shocks to keep the ride smooth and controlled.
Equipped with adjustable suspension.
QUANUM VANDAL 4WD ELECTRIC BUGGY (ARR)
Length16.34 in. (415mm)
Width10.04 in. (255mm)
Height5.59 in. (142mm)
Wheelbase10.83/11.02 in. (275/280mm)
Gear Ratio11.2:1
Hex Hub Size12mm
Battery Tray Dimensions5.59x1.81x0.94in. (142x46x24mm)
Motor3650 12.5T 3000kV TrackStar
ESC45A Trackstar Brushless ESC with HXT 4mm Connector
Item no.9382000168-0
Price$104.86
KEY FEATURES
  • Almost-Ready-To-Run, just install your own radio system and battery
  • Adjustable camber, caster and shock mounting positions
  • Low center of gravity chassis design
  • Shaft-driven 4WD system
  • Adjustable slipper clutch
  • Metal gear front & rear differential
  • Oil-filled shocks
  • Soft compound tires for increased traction
  • Pre-painted and trimmed body shell w/decal sheet included
  • Pre-installed motor, speed control and steering servo
NEEDED TO COMPLETE
  • 2-channel radio system
  • 2S 3000 to 4000mAh LiPo battery pack
Learn more—HOBBYKING!
Old Mar 19, 2014, 10:35 AM
Paul Onorato is offline
Find More Posts by Paul Onorato
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
Video from HobbyKing on Quanum Vandal
HobbyKing Daily - 1/10 4WD Quanum Vandal (2 min 46 sec)
Paul Onorato is offline Find More Posts by Paul Onorato
New Product Quanum RTR Bomb System 1/6 scale Plug-n-Drop from HobbyKing Skyking213 Flight Accessories 94 Mar 07, 2016 04:10 AM
Discussion new hobbyking car - 1/10 Quanum Skull Crusher 2WD Brushless Monster Truck (ARR) derpron Off-road Cars 44 Feb 11, 2016 11:22 AM
Discussion quanum vandal buggy kit is it worth the price mr. modder Off-road Cars 36 Jan 18, 2016 11:37 AM
Discussion 1/10th Scale FTX Carnage/Vantage/Banzai and Hobbyking clone Quanum Vandal jerrysimon Off-road Cars 23 Oct 06, 2015 05:08 AM
Discussion hobbyking quanum fc woobirdy Multirotor Talk 3 Oct 14, 2013 06:00 AM
