Old Mar 22, 2004, 05:50 PM
TheLost is offline
Find More Posts by TheLost
My Bulldog is my copilot ..
TheLost's Avatar
Joined Feb 2004
Yet Another GWS 109..
Took the bits out of my old 109 and moved them into a new home.
It was my first attempt at 'glassing'.. I can do better next time... but over all im happy with how it turned out.
TheLost is offline Find More Posts by TheLost
Old Mar 22, 2004, 10:20 PM
joeker is offline
Find More Posts by joeker
joeker's Avatar
Los Angeles, CA
Joined Jan 2004
nice work. I like your paint scheme.
joeker is offline Find More Posts by joeker
Old Mar 22, 2004, 10:26 PM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Glad to see that you spend so much effert to made more beauty!
Some day, the RC pilot also need to dress different nuiforms while flying?
GWS4CEO is offline Find More Posts by GWS4CEO
Old Mar 22, 2004, 10:36 PM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Great Looking plane Have you had a chance to fly her, and if so how do you like the way she looks in the air.
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old Mar 23, 2004, 09:15 AM
gunf1ght is offline
Find More Posts by gunf1ght
gunf1ght's Avatar
Charlotte Douglas, North Carolina, United States
Joined Jan 2004
beautiful aircraft... II/jg out of libya??
gunf1ght is offline Find More Posts by gunf1ght
Old Mar 23, 2004, 09:48 AM
TheLost is offline
TheLost's Avatar
Joined Feb 2004
I've only had a chance to fly her once.. but it was a huge improvement over the old body/paint I had. Easier to tell orientation over the old all blue and grey.
Old Mar 23, 2004, 10:02 AM
TheLost is offline
TheLost's Avatar
Joined Feb 2004
Very good! you know your 109's..
I modeled her after the semi-famous 'Black 6' (airframe No 10639) that was part of the 77th Fighter Group (III JG77) in Libya. 'Black 6' was captured by the British and used to evaluate new allied fighters. In the 1990's she was restored and spent 7 years flying air shows as the only original Benz engined BF109G-2. She now spends her time in the "Milestones of Flight" at the RAF museum.
Here she is right after capture..
Some pictures of 'Black 6' at airshows..
And the crash that ended her flying carrier in 1997..
In truth, this is the picture that made me go 'Hey! that's how I land.. I should paint my 109 like that'
Here are a few more of my 'Black 6'..
Old Mar 23, 2004, 12:15 PM
Tracon is offline
Find More Posts by Tracon
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
Nice 109
Awesome paint job !
Could you tell what type of paint you used and how you appied it ???
Sam
Tracon is offline Find More Posts by Tracon
Old Mar 23, 2004, 12:51 PM
TheLost is offline
TheLost's Avatar
Joined Feb 2004
Originally posted by Tracon
Nice 109
Awesome paint job !
Sam
I fiberglassed it with .5oz fiberglass cloth and Minwax Polycrylic. The paints are your standard Wal-Mart $0.80 water based acrylic paint. I used my el'cheepo airbrush w/canned air for the sand and gray color and a foam brush for the white and yellow bits (el'cheepo airbrush died ). I used blue painters tape to mask off the sections while painting.
Then I used a 'fine' sharpie marker and charcoal pencils (white and black) to add the lines on the wing and fuse.
The Decals are mostly from the GWS Kit but I made a few from Avery full sheet labels and my inkjet (sealed then cutout). Then I covered it again with a light coat of sealant to lock in the charcoal colors.
Old Mar 23, 2004, 01:00 PM
Tracon is offline
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
TL,
Thanks for the info, I have a GWS Spitfire sitting in the closet waiting to be built....I want to make the colors as authentic as possible...
After building and painting a Tiger Moth for my lady friend last week I want to up hold my image for nice finishes !
Picture attached..
LoL..
Thanks again,
Sam
Old Mar 23, 2004, 01:08 PM
TheLost is offline
TheLost's Avatar
Joined Feb 2004
TL,
Picture attached..
LoL..
Thanks again,
Sam
Nice! I'll probably start a TM next week . Did you use the Slope kit or paint over the yellow? Also, what did you use for the wing supports and wire? (I haven't ventured much into the tiger moth build threads.. I don't have a month to spend reading )
Old Mar 23, 2004, 01:28 PM
Tracon is offline
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
TL,
I bought some balsa wood that matched the same width of the wing struts and just ca'ed them to the stock strut...
For the flying wires, I just used 100% polyester thread...
I used the balsa wood mod for the servos also instead of the double sided tape...makes thing a little more dependable..
For more scale like mods:
1. I used some scrap foam from the kit to make the little doors that inclose the cockpit sides a bit.
2. I got some new wire and bent up new landing gear and added the "V" to add scale shocks....I did this by pulling rubber bands through small drinking straws and running them from the "V" down to the wheels...
3. Added the instrument panel by printing it out off the net and scaling the image down a bit to fit.
4. I hinged the control surfaces by using some clear plastic, (Makes for a more scale look without the old tape method)...after reading about using old floppy disk material, I will do that next time and on the Spitfire.
5. I also got the windshield pattern off the net and used it as a template to cut out the clear plastic material.
Used foam safe CA for everything except 5 min epoxy to attach the struts to the wings.
Here's a link to where I went for all the best mods:
http://www.thonotosassafla.com/RC/tmods.htm
Good Luck !
If you get stuck or have any questions, message me !
Sam
Old Mar 23, 2004, 02:03 PM
TheLost is offline
TheLost's Avatar
Joined Feb 2004
Thats what i used for this me-109.. worked great!
Thanks for the info
Yet Another, GWS Me-109 first warbird Aceshigh84 Parkflyers 2 Dec 14, 2004 08:16 PM
Yet another GWS Zero question - rolls left on launch Peter Khor Parkflyers 5 Jul 15, 2002 12:09 AM
Yet another GWS Zero question!!! Hopperfly22 Parkflyers 3 May 22, 2002 09:10 AM
Yet another GWS Zero question... tnsfrk Foamies (Kits) 6 Apr 25, 2002 04:29 PM
Yet another GWS Tiger Moth owner Thomas B Parkflyers 8 Oct 29, 2001 01:11 AM
