Mar 22, 2004, 04:11 PM
United States, UT, Payson
Joined Mar 2003
I've got some little tiny problems.
As the title states, I've got a few little 'Tiny' problems. I have a scratchbuilt Tiny that is ailerons/elevator/throttle. It is powered by a Dual-IPS and a 7 cell 370 mah 2/3 AAA pack. It is pretty hefty at 7 3/8 oz AUW. 10 x 7 APC prop.
The first flight after I 'ressurected' it and put some landing gear on it was a struggle. The flight was short, but the main problem was pitch. I had to hold up so that it would fly level, and it flew with a 'nose up' attitude, but didn't climb well. The made it slow and 'tippy.'
Next flight, I moved the CG back from the spar to 1/4" behind it. It is better, but I can't effectively gain altitude. It will roll in heartbeat, so the ailerons work well, but pitch is a big problem. With the new CG it has less of a 'nose up' attitude, but still refuses to gain altitude. It also got faster with the new CG, but this was expected because of the high wingloading.
It seems as though I am kept on my toes trying to get it to fly well. I want to be able to let go of the stick, and let it fly where I pointed it, rather than it dropping like a rock if I don't hold the nose up. At this extreme I can't trim the 'up' because it'll slow too much and stall.
Any suggestions to get it flying well?
~Chris
